Author Topic: DIY - Tools for modern electronics  (Read 1596 times)
Offline Elantric
Re: DIY - Tools for modern electronics
« Reply #1 on: October 27, 2015, 11:05:31 AM »
There are several SMD component guides online
the local Robot guys tend to be the most knowledgible on DIY SMT design strategies
https://www.sparkfun.com/tutorials/category/2
http://www.freetronics.com.au/pages/surface-mount-soldering-with-a-toaster-oven#.Vil7j36rRaQ
http://store.curiousinventor.com/guides
http://makezine.com/2015/04/15/diy-open-source-reflow-oven/
http://www.instructables.com/id/How-to-Solder-SMD-ICs-the-easy-way/
Myself I tend to use larger Resistor quad packs (1206x4)  and avoid anything smaller than 0603 passive discretes ( use 0805, 0603) Avoid 0402, 0201) ,and any ICs with BGA packages
ICs it comes down to availability, DIP through hole IC components are becoming rare and often not available for modern ICs
Last time I designed a PC board for through hole components was 1999 for Ernie Ball Sterling Bass 3 band active EQ "banana" board
compare to my recent Apple mFI approved design here
Offline admsustainiac
« Reply #2 on: April 22, 2016, 11:37:00 AM »
http://hackaday.com/
http://hackaday.com/?s=rigol
[mosaicmerc] over on hackaday.io has upgraded his Rigol DS2072A oscilloscope to a DS2302A, turning an $800 oscilloscope into one that sells for $2500, with all the bandwidth, storage depth, and options of the more expensive model.
http://rheslip.blogspot.ca/2015/09/software-spectrum-analyzer-for-rigol.html
Rigol o-scopes have a long and storied history of unlocking, hacking, and upgrading. The original hack that put Rigol on the map was the DS1052E upgrade that turned a 50MHz scope into a 100MHz scope. The latest low-end Rigol scope, the 1054Z can be unlocked in software to become an 1104Z with 100MHz of bandwidth, SPI, I2C, and RS232 decoders, twice the storage depth, and more triggers.
http://simonselectronics.eu/2015/09/unlocking-features-in-the-rigol-ds1054z/
It appears Rigol’s engineers are designing their products to capitalize on the hacker’s proclivity to buy their tools to get the ‘free’ upgrade. This, of course, sounds just slightly insane, but no one seems to mind.
The process of upgrading the Rigol DS2072A scope is documented over on the EEVBlog, and requires only a USB cable and a computer with the Labview Runtime Engine installed. It’s literally as simple as pressing a few buttons; a far cry from the previous keygen method that was also engineered over on the EEVBlog.
http://hackaday.com/2015/09/22/a-better-spectrum-analyzer-for-your-rigol-scope/
« Last Edit: April 29, 2016, 11:47:37 PM by Elantric »
« Reply #3 on: April 26, 2016, 03:49:39 PM »
Offline snhirsch
« Reply #4 on: June 01, 2016, 07:36:57 PM »
I have a hacked 1052E on my bench.  It's been doing the job here for several years.
Offline Elantric
« Reply #5 on: January 12, 2017, 01:01:19 PM »
No reason not going SMD. Just a matter of initial investment. Buy a good magnification lamp, SMD Tweezer and a great soldering station (Weller etc.) and off you go. Unless components are VERY small it's faster soldering SMD when you get use to it. It's better for the enviroment also, less lead, no cutting etc...
Parts getting placed on wrong locations can drive you crazy
It happens a lot on 1st production runs, at my work we order the Assembler to build a few boards , and allow me to test for BOM (Bill of Materials parts list) errors, then I approve the 1st article "Gold sample" and return it to the Assembler as a reference, prior to the mass production run
Also helps to repair dead electronics, or reverse engineer existing circuits
Get the SMD (Surface Mount Device) Code Book!
https://www.sos.sk/pdf/SMD_Catalog.pdf
Get a in circuit LCR capacitance checker , I use an Agilent LCR Meter
with tweezer probe'
or
http://www.ebay.com/itm/172373714505?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Smart Tweezers ST-5S Digital Multimeter with Spare Ergonomic Bent Probes
Smart Tweezers ST-5S are a professional quality LCR-Reader. Unlike traditional LCR-meters that require both hands and extensive set-up between measurements, Smart Tweezers is able to automatically determine the type of component as an Inductor, Resistor or Capacitor while measuring with a high basic accuracy of 0.2%. When a Surface Mount Device or older through-hole component is grasped between the gold-plated stainless-steel tweezers, Smart Tweezers will identify the component and automatically select the best test range and signal frequency for that component. The measurement values, type of component, secondary values, test frequency and mode are displayed on the screen instantly.
The ST-5S also has manual test parameters within the extensive menus. Every task can be specified with the ability to select the test range with 100 Hz, 120 Hz, 1 kHz and 10 kHz test frequencies, L, C, R, ESR, D and Q measurement test modes; component sorting or any work involving a PCB has never been easier. The unique design and fast, automatic measurements allow users to focus on the task at hand. Navigated with a joystick button, users don't have to enter the menu to change the measurement mode or test frequency.
Smart Tweezers comes in a hard-shelled carrying case, with a Li-Ion battery that holds an 80 hours of continuous use; the 1 oz. weight makes the device ultimately portable. The ST-5S comes with an NIST traceable certificate for professionals who require their equipment to be calibrated annually, a hard-shelled carrying case, and spare bent tweezer probes.
Features on Smart Tweezers ST-5S:
Automatic and manual L, C, R, ESR, Q, Z and D measurements
Automatic and manual test range selection
Adjustable test signal levels
Diode, polarity, and short testing
0.2% Basic accuracy
Stainless steel, gold-plated tweezers as probes
Instantly displayed measurement values, along with secondary values, test mode and frequency used
Li-Ion battery with micro-USB connection, USB cord included
Hard-shelled case
NIST Traceable Calibration Certificate
1 oz. weight
Spare bent, ergonomic tweezer probes
Physical Specifications
Operating Temperature:   0 °C to +50 °C
Storage Temperature:   -40 °C to +70 °C
Relative Humidity:   0 % to 90 % (0 °C to 35 °C)
0 % to 70 % (35 °C to 55 °C)
Altitude Operating:   0-2000 meters
Battery Type:   3.7 V LiPO rechargeable 150 mAh
Typical Charge Time:   2.5 Hours
Electromagnetic Compatibility (EMC):   Susceptibility and Emission: CE 89/336, FCC 15 part B
Size:   14.0 x 2.5 x 3.0 cm (3.94 x 0.9 x 1.5 in)
Weight:   53 grams (0.11lb)
Warranty:   1 year
Basic Specifications
Measured Parameters:   L, C, R, ESR, D, Q
Measuring Frequencies:     100 Hz, 120 Hz, 1 kHz, 10 kHz
Measurement rate:   1 time per second
Resistance:   0.05 Ohms to 9.9 MOhms
Capacitance:   0.5 pF to 4,999 µF
Inductance:   0.5 µH to 999 mH
Dissipation Factor:   0.001 to 1000
Accuracy Specifications
Accuracy is specified at 18°C to 28°C (64°F to 82°F), with relative humidity to 90%.
Resistance:
Accuracy:   0.2% in range 100 R to 10 K, 0.5% in range 1 R to 1 M
Capacitance:
Accuracy:   0.2% in range 10 nF to 10 µF, 0.5% in range 100 pF to 1 mF
Inductance:
Accuracy:   0.2% in range 10 mH to 100 mH, 0.5% in range 100 µH to 1H
« Last Edit: January 12, 2017, 01:16:05 PM by Elantric »
« Reply #6 on: February 18, 2017, 11:35:34 AM »
Cross platform LabNation ScopeMeter
USB Dual channel O-Scope, 8 channel Logic Analyzer (SPI,I2C,I2S,UART) Signal Generstor, Android ,IOS,Win,Mac, Linux.
www.lab-nation.com
« Last Edit: February 19, 2017, 04:50:24 PM by admsustainiac »
« Reply #8 on: March 01, 2017, 02:03:50 PM »
« Last Edit: April 05, 2017, 12:44:54 PM by admsustainiac »
« Last Edit: April 20, 2017, 04:08:14 PM by admsustainiac »
Offline HAMERMAN409
« Reply #12 on: April 18, 2017, 02:33:46 PM »
I found this handy when I wanted to do some work at home and didn't have a "real" function generator:
https://itunes.apple.com/us/app/audio-signal-generator-including-sweeps-noise/id768229610?mt=8
Offline Elantric
« Reply #13 on: April 18, 2017, 02:37:48 PM »
Agreed!
i like the "Pro" version
https://itunes.apple.com/us/app/audio-signal-generator-pro-incl-sweeps-noise/id895074703?mt=8
and his "Multi-Tone" Generator app
https://itunes.apple.com/us/app/multitone-generator/id1143928697?mt=8
MULTITONE GENERATOR WITH SUPPORT FOR AUDIOBUS AND AUDIOBUS REMOTE!
This is the all-new MultiTone Generator! An amazingly flexible and powerful frequency generator!
Works with Audiobus and Audiobus Remote!
CREATE up to 16 tone combinations. Play them individually or combined.
PLAY TEST TONES Sine, Rectangular, Triangular and Sawtooth.
PLAY FREQUENCY SWEEP TEST TONES in both directions (minimum to maximum frequency and maximum to minimum frequency).
Use the SWEEP REPEAT / WOBBLE function.
Play back different kinds of NOISE – White, Pink, Violet, Grey, Brown, Blue
Fully CUSTOMIZABLE Frequency Min-Max ranges and Sweep time range.
The MultiTone Generator is AMAZINGLY INTUITIVE and SIMPLE!
« Last Edit: April 18, 2017, 04:50:59 PM by Elantric »
Offline Elantric
« Reply #14 on: April 28, 2017, 11:41:47 AM »
https://www.amazon.com/all-sun-Oscilloscope-Multifunction-Multimeter-Precision/dp/B01MQHFZCY/ref=cm_rdp_product
Debugging audio gear , biasing Tube Guitar amps, and occasional embedded controller development, This unit works very well for my needs.
The built in Signal Generator, and decent oscilloscope and fast intuitive controls and operation and multimeter as a bonus makes this permanent place in in my mobile audio electronics tool bag
not bad for battery power 6 hours per charge  @$220
http://www.ebay.com/itm/Digital-Handheld-Scope-Meter-Multimeter-50MHz-Bandwidth-Oscilloscope-US-Ship/261985359934
« Last Edit: April 28, 2017, 11:59:09 AM by Elantric »
Offline Elantric
« Reply #15 on: May 03, 2017, 01:43:22 PM »
« Reply #16 on: June 02, 2017, 04:29:01 PM »
Use this Speaker Impedance online calculator
http://www.speakerimpedance.co.uk/
