VGuitar Forums
Please login or register.
Advanced search
Pages: [1]   Go Down
Author Topic: Cool little "Musical Scratchpad" program - RiffWorks T4  (Read 2534 times)
Kenmac
  • Senior Member
  • Offline Offline
« on: October 28, 2008, 03:27:16 PM »
I don't know if anybody here reads "Computer Music" magazine but it's a magazine from England that is distributed to many countries worldwide and it deals primarily with virtual instruments and effects, DAWs (Digital Audio Workstations, eg. Sonar, Cubase, Logic, Reaper, etc.) as well as recording techniques and reviews amongst other topics. Every month they include an 8.4 gig DVD packed with samples, software (both free and demo versions) along with video(s) featuring various producers (usually dance oriented) demonstrating their recording techniques. Anyway there's one piece of software in the September issue I thought I'd tell you about. It's on the DVD included with the magazine and it's free for both Mac and PC users. It's made by Sonoma Wire Works and it's called "RiffWorks T4". Here's what it says in the magazine about it:
"A free version of Sonoma Wire Works' RiffWorks guitar recording software. RiffWorks T4 offers a cut-down feature set compared to the standard edition, with the major limitation being that there are only four tracks available rather than the full 24. It also includes AmpliTube Duo LE rather than AmpliTube Live, Studio Devil BVC, and a single demo drummer instead of the nine virtual drummers found in the standard version. There's also no ReWire or REX file compatibility here, and 1125 display resolution support is also missing. Despite these limitations, RiffWorks T4 is still a highly usable app that boasts some amazing features, considering it's free. It should be very appealing to computer music novices in particular.
When you run the program for the first time, a tutorial guides you through the creation of a virtual drummer track, setting up effects, and recording a guitar part, known here as a riff. Once you've recorded one of these, it can be duplicated to build up the basis of a full track. As well as the amp effects, RiffWorks also features a built-in filter shaper, an EQ, a compressor, a modulator and delay and reverb effects, for creating a wide variety of useful guitar tones. Likewise, the virtual drummers style can be tailored to suit the track you're working on, with settings like Variation, Intensity and Ambience. RiffWorks is clearly designed as a less intimidating alternative to more complicated recording software - the interface has the feel of guitar recording hardware, for example, and the program appears to be quite deliberately limited.
Also, VST (Virtual Studio Instrument) plug-in support is restricted - you can't use instruments, and effects without their own interface won't even load up. There's no way to import your own WAV files, either, which means you have to use the supplied virtual drummer for beats. This is a great way for guitarists who are unfamiliar with software recording to get their hands dirty, though - especially as it doesn't require a cash investment. You can even collaborate online with four other musicians using the RiffLink feature, which includes a chat client."
BTW, for those of you who are new to recording on the computer, it may be a little tricky to set up at first but the help file makes things pretty clear. I was messing around with it last night and at first I was going to use the VST amps but then I decided to try the VG-99s USB function. The (very short) track I'm attaching took me less than 15 minutes to put together and it could've been even shorter than that if I hadn't have made a couple of flubs. Three out of the four instruments I'm using here were ones I programmed myself on the VG-99. (I'll be uploading them later.) The bass is one I named "FilterOWBass". It has a shorter attack and a punchy type of sound. The synth type sound uses the Wave instrument and I called it "DualWaveSolo" then there's a track which you have to listen for rather closely which uses the VARI model and I've called it "Vari&WarmCrunch". I had to turn it down as it was overpowering the Wave sound as well as the last guitar part which uses the "Summers" (Andy Summers) setting that I downloaded from here, I believe. Yep, I just checked, it's not a preset.  :)  BTW the MP3 file I've attached is looped so if you want to download it and use it in your DAW of choice be my guest. The progression is C#minor, B, F#minor and A. Another thing, I haven't even experimented with the effects in this RiffWorks program so that's something else I'll be checking out. Once again I highly recommend searching out the September issue of Computer Music magazine even if just for this program alone. I feel more motivated to try more things now because sometimes even a user friendly DAW can be a little intimidating or uninspiring.
EDIT: Okay, I just found out you don't have to buy Computer Music magazine to get this program.  :-[ Just go to http://www.sonomawireworks.com and you can download it for free but I still recommend checking out the magazine as it's a well written and informative magazine. Here's my MP3 file.
Logged
baranger1
  • Guest
Re: Cool little "Musical Scratchpad" program - RiffWorks T4
« Reply #1 on: October 28, 2008, 06:26:35 PM »
Thank you!
Very cool.
Now please let us here more of your tune!!!!
Sounds great.
I want more:-)
Bill
Logged
Kenmac
  • Senior Member
  • Offline Offline
« Reply #2 on: October 28, 2008, 07:21:10 PM »
Thank you!
Very cool.
Sounds great.
I want more:-)
Bill
Thanks very much Bill but I'm afraid this is all I've recorded. This was an experiment basically but I was pretty pleased with the way it came out and so I thought I'd not only tell the forum members here about this software but also post this for anybody that wants to use it in their DAW. I also want to thank you for recommending the Roland Mobile Cube amp which I used for monitoring. I was really getting fed up with having to use headphones and surprisingly enough I'm *still* using the same batteries that came with the amp. I'll definitely be using RiffWorks for any noodling or chord progressions. This really is an inspiring little program and the VG-99 is a great match for it. BTW I'll be uploading my patches this weekend.
Logged
feloniouspunk
  • Global Moderator
  • Senior Member
  • Offline Offline
    • My ever changing school website.
« Reply #3 on: October 29, 2008, 08:25:06 AM »
Cool sounding patches!  How many guitar tracks is that and are they all the 99 except the drums?
Logged
"Okay Vinnie, where is five?"
Kenmac
  • Senior Member
  • Offline Offline
« Reply #4 on: October 29, 2008, 12:52:33 PM »
Thanks Feloniuspunk, there are 4 guitar tracks. I programmed three out of the four and the first is the altered Filtered Bass patch I created, then another one comes from the Wave synth, the third is from the Vari model and the fourth is an Andy Summers patch I downloaded from here in .g9l library format. I think it was from the Paul Hanson collection.
Logged
Rojoyinc
  • Senior Member
  • Offline Offline
  • -Ron
    • PortraNET
« Reply #5 on: October 29, 2008, 06:52:32 PM »
I bought this years ago - and the upgrade a year or two ago... though I don't use it often - it's a bit restrictive...  Forcing you to set the bar length and - well I never know how long I'm gonna go.
But it is pretty simple to use and if you don't mind short loops, it's kinda fun.  but often I'll have a little mistake or timing issue I want to fix and can't.
I'll check out the free vers.  I didn't know there was one.  Line6 has been selling this with their guitar port of MANY years.
Logged
Ron, GR, MI
Strats (John Mayer & AmDlx Ash) Fretlight
Gibson LP cust
Tayor T5 Koa, Solidbody walnut custom
Alesis DM5, MM6 synth
Line6 UX8, Mesa LonestarSP, Fender Acoustasonic
MicroCube, Fender Champ 600, BR-600, DP-02CF PortaStudio
HarmonyMan, VocalistLive4, CuBase, SECURITY SYSTEM ;-)
Kenmac
  • Senior Member
  • Offline Offline
« Reply #6 on: October 30, 2008, 10:57:21 AM »
It's a pretty cool little tool. I'm surprised they didn't make a free version of this back when they first introduced it. Sometimes you don't feel like setting things up in your DAW and you just want to play or maybe try some chord progressions or other ideas without really committing them and that's when this comes in handy. I'll be using this for the MP3 demos of the patches I'll be uploading this weekend.
Logged
  • Global Moderator
  • Senior Member
  • Offline Offline
    • ASB Web
« Reply #7 on: December 09, 2009, 03:16:49 AM »
I stumbled across this thread and for those who have this program and want to know the possibilities,
Todd Rundgren recorded his recent "Arena" CD in its entirety using RiffWorks T4.  The whole CD.
Pretty cool.  I'd like to know who did his drumloops though.
Logged
http://www.aliensporebomb.com/
Kenmac
  • Senior Member
  • Offline Offline
« Reply #8 on: December 09, 2009, 04:15:59 PM »
Yeah I read about Todd using it for the "Arena" CD as well. It says a lot about the software when a professional like Todd Rundgren, who probably has access to some of the best gear around, uses it exclusively for that particular project. As far as drumloops, it wouldn't surprise me if Todd did them himself.
Logged
Pages: [1]   Go Up
