Author Topic: VG-99 - Need help installing vg-99 device driver on windows 8  (Read 968 times)
Offline Devan24
« on: October 18, 2013, 11:06:05 PM »
Hi everyone, I'm new here and new to the Roland Vg-99. I'm figuring out everything quite well except for one major issue. I cannot use the editor to upload patches to the vg-99. When I open the application it states that I need to setup the midi device. When I go to the settings and try to change the input/output devices there are none available? I open up the control panel then device manager and notice an exclamation point next to the vg-99. It's telling me the device driver is not installed. I don't understand this because when I plugged the vg-99 in it installed the driver. I have tried uninstalling and reinstalling the driver several times. Idk why the driver isn't installing properly even though it says the driver is there? Any help would be much appreciated.
« Last Edit: August 10, 2015, 01:52:12 PM by admsustainiac »
Offline admsustainiac
Re: Need help installing vg-99 device driver on windows 8
« Reply #1 on: October 19, 2013, 11:49:26 AM »
You MUSt install the VG-99 USB Driver first - else nothing else related to VG-99 and connected computers will work.
Read VG-99 Top Things to Know
VG-99 FAQ: TOP THINGS TO KNOW
http://www.vguitarforums.com/smf/index.php?topic=13.0
Read
Installing VG-99 USB Audio/MIDI Driver
http://www.vguitarforums.com/smf/index.php/board,17.0.html
VG99 Win 8 Driver is here - Must Read the installation Guide included in the Zip File:
http://www.rolandus.com/products/details/849/475/downloads/
IMPORTANT NOTICE: When the Windows SmartScreen is displayed upon installing the driver, please perform the following procedure:
1. Click [ More info ]
2. Click [ Run anyway ]
* Skip Step 1 If your PC is not connected to the internet.
http://www.rolandus.com/support/eula/vg99_win8d_v100.zip
Using the VG-99 Editor
http://www.vguitarforums.com/smf/index.php/topic,50.0.html
« Last Edit: October 19, 2013, 12:01:05 PM by admsustainiac »
Offline Devan24
« Reply #2 on: October 19, 2013, 04:17:30 PM »
So there is a driver for the usb as well as the Vg-99? I tried installing the usb driver but that isn't working. It says ready to install the driver, connect the vg-99 and turn on the power, the driver will install automatically. When I do that it just sits there. It never says installed and I can't click next.
Offline Elantric
« Reply #3 on: October 19, 2013, 04:28:50 PM »
Sounds like you trying to use a USB 3.0 port? ( that will not work with the VG-99)
VG99 Win 8 Driver is here - Must Read the installation Guide included in the "ReadME" HTML file in the Zip File:
VG-99 Driver Ver.1.0.0 for Windows® 8
(Note)
In no event shall Roland Corporation ("Roland") be liable to end-users for any damages whatsoever, including but not limited to financial damages for loss of business profits or business information arising from the use of, or inability to use this product. The foregoing provision is effective even if Roland has been advised of the possibility of such damages.
*   All files and other material contained in this folder are copyrighted by the Roland. Any alteration, modification, duplication, distribution, or reproduction of this material is prohibited. Additionally, Roland reserves the right to make changes to these programs and files without prior notice.
*    Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
*   ASIO is a trademark and software of Steinberg Media Technologies GmbH.
*   All product names mentioned in this document are trademarks or registered trademarks of their respective owners.
About this driver
This is the VG-99 driver for Microsoft® Windows® 8.
This driver also supports ASIO(Steinberg Audio Stream I/O Interface) 2.0.
*   For touch-enabled PCs, replace the word "click" in this document with "tap" when operating.
System requirements
This driver has the following requirements.
Operating System
Microsoft® Windows® 8 (64-bit Edition/32-bit Edition)
*   This driver will not work on Windows RT.
Computer
Windows-compatible PC equipped with USB port
*   This product cannot be used with a USB 3.0 port that is not compatible with USB 2.0 specification.
*   If this product does not work correctly when connected to a USB 3.0 port, you will need to connect it to a USB 2.0 port.
*   Even if connected to a USB 3.0 port, the performance of the product will not change.
*   This driver cannot be used in a virtual Windows environment, such as Hyper-V or Virtual PC.
*   Mac computers running Microsoft Windows are not supported.
Cautions and Limitations
Sound interruption or other less-than-perfect outcomes may be experienced if your computer's performance and specifications are somewhat inadequate. The types of applications you use and the way in which you use them can also influence the experience you receive.
On some computers, the driver does not load correctly if the VG-99 is already connected when Windows is started up. As a result, it will not be possible to use the VG-99 via USB. If this occurs, wait until after Windows has started to turn on the power of the VG-99 (or to connect it).
If the VG-99 does not work correctly after resuming from Sleep mode, you should exit all applications that use the VG-99, and then turn the power of the VG-99 off and on again.
If the USB cable is disconnected and reconnected while the VG-99 is in use, or if the power of the VG-99 is turned off, then on again, it may stop operating correctly. If this occurs, after resuming, you should exit all applications that use the VG-99, and turn the power of the VG-99 off, then on again.
If your computer was experiencing a heavy processing load, such as when accessing a CD-ROM Drive or network while the VG-99 was being used, the VG-99 may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again. If you are still unable to play back or record, quit all programs that are using the VG-99, then turn the VG-99 off and then on again.
Audio clicks and pops may occur during playback or recording if you connect or disconnect other USB devices (such as USB memory) or turn another USB device on/off while using the VG-99.
In some cases, you may not obtain the expected level of performance if you're using a USB-connected hard disk at the same time as the VG-99. Do not use a USB-connected hard disk as the storage destination for the audio that you're playing back or recording.
Installation
*   To reinstall or update the driver, refer to "To reinstall."
Start up Windows with all USB cables disconnected.
(except for keyboard and mouse)
Exit all applications before you begin the installation.
On the Start screen, click the Desktop.
Double-click the Setup icon.
*   If a confirmation screen regarding Windows SmartScreen appears, click [Run anyway].
A confirmation screen regarding User Account Control will appear, click [Yes].
The message "VG-99 Driver will be installed on your computer. ---" will appear. Click [Next].
*   If any other message appears, follow the directions of the message.
Click [Next] to begin installation.
If a dialog box regarding Windows Security appears, click [Install].
The message "Ready to install the driver. ---" will appear.
Use a USB cable to connect the VG-99 to your computer, then turn on the VG-99.
The driver will be installed automatically.
When the "Installation has been completed." message appears, installation has been completed.
Click [Close] to close the "Driver Setup" dialog box.
If the "System Settings Change" dialog box appears, click [Yes] to restart Windows.
Refer to "Before you begin," and make the necessary settings for using the VG-99. You won't be able to use the VG-99 unless you make these settings.
*   If you are unable to use the VG-99 after connecting it, it's possible that a problem has occurred. Refer to "Troubleshooting."
Before you begin
To open the Control Panel
If you need to open the Control Panel, perform the operation described below.
Move the mouse pointer to the upper right or lower right corner of the screen to display the charms.
*   On touch-enabled PCs, swipe from the right side of the screen to display the charms.
Click "Settings" and display the "Settings charms."
In "Settings charms," click "Control Panel" to open the "Control Panel."
Input/output device settings for your application
In order to obtain optimal performance from your applications, specify the input/output device for your applications as described below. (For details on making these settings, refer to the owner's manual for your application.)
*   Ensure that the VG-99 and the application are set to the same sampling frequency. If the sampling frequency settings do not match, error messages may be displayed and recording/playback errors may occur.
*   If you are unable to select the VG-99 device, a problem may have occurred. Refer to "Troubleshooting."
Audio input/output device
Of the total audio input/output channels provided by the VG-99, there are 2 INs and 2 OUTs
[WAVE OUT Devices]
OUT (VG-99)
*   If you've specified a different name in the "Sound" settings of the Control Panel, the name you specified will be displayed.
[WAVE IN Devices]
IN (VG-99)
[ASIO device]
When using the VG-99 with an ASIO-compatible application, select "VG-99" as the ASIO setting for your application.
*   To prevent an audio feedback loop or double monitoring, make settings on your application to turn monitoring off or use ASIO Direct Monitoring.
*   When using the VG-99 with ASIO, we recommend that you set your application so that it does not use the Microsoft GS Wavetable Synth. (In order to decrease the load, and for convenience when changing Audio Buffer Size of the driver.)
MIDI input/output device
*   In the Windows Media Player, the MIDI input/output device of VG-99 cannot be used.
Please select the following device in your MIDI compatible application.
[MIDI OUT devices]
VG-99 CONTROL
VG-99 MIDI
[MIDI IN devices]
VG-99 CONTROL
VG-99 MIDI
Setting the playback/recording device in Windows
Set VG-99 as the default device to allow its use in "Music" and Windows Media Player.
Open "Control Panel," click "Hardware and Sound," and then click "Sound."
*   If the icon view is selected for the Control Panel, click "Sound."
In "Playback," right-click VG-99's "OUT," and choose "Set as Default Device."
*   If the above WAVE ports cannot be selected, a problem may have occurred. Refer to "Troubleshooting."
Similarly, in "Recording," right-click VG-99 "IN," and choose "Set as Default Device."
Click [OK] to close "Sound."
To change the settings
To change or verify settings
When changing driver settings, always make sure to first quit all applications using the VG-99. This is unnecessary when only checking the settings.
*   Exit not just Desktop applications but Windows Store Apps as well. Please wait for about 10 seconds until these applications exit completely.
*   If the Windows monitoring function is enabled, it won't be possible to change the driver settings. Refer to "Could the Windows monitoring function be enabled?" and disable monitoring.
Display the Start screen and click "VG-99."
*   On the Start screen, if "VG-99" does not exist, then open the "Control Panel," switch "View by:" to the icon view (Large icons or Small icons), and then click "VG-99."
The "VG-99 Driver Settings" dialog box will appear.
To modify the settings, make the changes and click [OK]. To simply check the settings, be sure to click [Cancel] after viewing the settings.
*   For details on the setting items, refer to "About the items in the Settings dialog box."
Audio Buffer Size
You can adjust the audio input/output buffer size. (By default, this will be the sixth position from the left.)
Decreasing the buffer size will shorten the latency and improve realtime performance, but might make it more likely that you will experience audio clicks and pops, depending on your computer's processing power and the song data load.
Increasing the buffer size will lengthen the latency, but will make audio streaming more stable, and it will be less likely for audio clicks and pops to occur.
In general, you'll probably want to decrease the buffer size for better realtime performance if you're playing a software synthesizer in real time, or if you're monitoring an audio input that's being passed through your DAW software.
Conversely, you can increase the buffer size to prevent audio clicks and pops if you're recording or playing back song data that contains numerous tracks and presents a heavy processing load.
By changing the buffer size as appropriate for your situation, you can obtain the right balance between realtime performance and audio streaming stability.
* Note!
If you use an application with an audio equipment test function, after changing the buffer size, carry out a test.
ASIO Buffer Size
This is the minimum buffer size that can be set by the ASIO application.
*   Depending on the application you're using, there may be other buffer sizes that can be set in addition to the minimum buffer size, and the buffer size shown here might not match the actual buffer size.
For details on setting and checking the buffer size, refer to the owner's manual for your application.
"Use Smaller ASIO Buffer Size" check box
If this check box is selected, the buffer size when using ASIO-compatible applications will be made smaller.
If you experience pops or clicks when this check box is selected, deselect this check box.
*   You must deselect this check box when adjusting the "Audio Buffer Size."
"Use ASIO Direct Monitor" check box
Check this if you are using the ASIO Direct Monitor function with an ASIO-compatible application.
The "Light Load" check box
Normally, you should leave this check box cleared.
*   The modified setting will take effect after you turn the power of the VG-99 on/off.
"Show README" button
This button displays the README file (this document).
Information
This field shows the driver version.
To reinstall
Delete the driver as described in "To uninstall."
*   When you uninstall, the settings of the Driver Settings dialog box will be initialized. For details on the setting items, refer to "About the items in the Settings dialog box."
Install the driver as described in "Installation."
To uninstall
Exit all applications before you begin the uninstallation.
Open "Control Panel" and click "Uninstall a program."
*   If the icon view is selected for the Control Panel, click "Programs and Features."
In the list, choose "VG-99 Driver", and click "Uninstall/Change."
If a dialog box regarding User Account Control appears, click [Yes].
*   If you are asked to enter the password for an administrative account, sign in to Windows as a user whose Account Type is Administrator, and then perform the uninstallation.
The display will indicate "The installed VG-99 Driver will be uninstalled." and click the [OK].
When the message "Uninstallation was completed." is displayed, click [OK] to restart Windows.
« Last Edit: August 10, 2015, 01:51:36 PM by admsustainiac »
Offline Elantric
« Reply #4 on: October 19, 2013, 04:29:04 PM »
Troubleshooting
Cannot install/uninstall the driver
Is the VG-99 set to Advanced mode?
Set the VG-99 to Advanced mode.
Are you signed into Windows with the appropriate user rights?
You must sign in to Windows as a user whose Account Type is Administrator.
*   For more information regarding this, consult your computer system administrator.
Cannot select/use the VG-99 device
Was the driver installed correctly?
If you can't use the VG-99 even though you've installed the driver, the driver might not be installed correctly. Use the procedure described in "To reinstall" to reinstall the driver.
Could the VG-99 be in use by other software?
Exit all applications that are using the VG-99, and turn the power of the VG-99 off, then on again.
If this does not solve the problem, use the procedure described in "To reinstall" to reinstall the driver.
Is the VG-99 WAVE/MIDI device name displayed?
If the device name is not displayed, exit all applications that are using the VG-99, and turn the power of the VG-99 off, then on again.
Did the computer enter a Sleep mode while the VG-99 was connected with its power turned on?
Was the USB cable disconnected and reconnected while the VG-99 was being used, or was the power of the VG-99 turned off, then on again?
If the USB cable is disconnected and reconnected while the VG-99 is in use, or if the power of the VG-99 is turned off, then on again, it may no longer operate correctly. If this occurs, exit all applications that are using the VG-99, and turn the power of the VG-99 off, then on again.
On some computers, if the VG-99 is connected while Windows starts up, the driver will not be loaded correctly, and it will not be possible to use the VG-99 via USB.
If this occurs, start up Windows before you turn on the power of the VG-99 or connect it.
A number such as "2-" is now displayed at the beginning of the device name
Could you have connected the VG-99 to a different USB port?
If you connect the VG-99 to a different USB port, the operating system may automatically add a number to the beginning of the device name.
Even if this occurs, it will not cause any problems with the operation of the VG-99.
*   If you want to restore the device name that does not have this added number, connect the VG-99 to the same USB port as when you installed it, or reinstall the driver as described in "To reinstall."
The screen indicates "Device currently used by another application." and driver settings cannot be made
Is it being used by Windows Store Apps?
The driver settings cannot be changed while it is being used by an application.
No sound is heard; cannot playback or record
Did you make settings as described in "Before you begin" so that the VG-99 driver could be used?
The VG-99 cannot be used unless you make these settings. Refer to the sections on "Before you begin."
Could you have entered Sleep mode during playback or recording?
During playback or recording, did you turn the power of the VG-99 on/off, or disconnect and reconnect the USB cable?
If you turn the power of the VG-99 on/off or disconnect and reconnect the USB cable during playback or recording, the VG-99 will no longer be able to play back or record. Stop playback or recording, and then start playback or recording once again. If you are still unable to play back or record, quit all programs that are using the VG-99, then turn the VG-99 off and then on again.
Try adjusting the audio buffer size of the driver
If the size of the driver's audio buffer is too small, sound may not be produced, or it may be impossible to carry out normal playback and recording.
In such cases, you should refer to "To change the settings," and increase the size of the buffer.
Sound played by your computer is inaudible or too soft
Could you have turned down the volume of the device or application in the Volume Mixer?
The system's Volume Mixer lets you adjust the volume for each device or application.
Open the "Control Panel," and switch "View by:" to "Category."
Click "Hardware and Sound," and then click "Adjust system volume."
The Volume Mixer will appear. From the "Device" pulldown menu, choose the device that you're using for playback, and adjust the volume.
*   Alternatively you can open the Volume Mixer by right-clicking the speaker icon located in the lower right of the Desktop and choosing "Open Volume Mixer."
Are you using voice communications software?
If you're using voice communications software, the volume of the audio device might be automatically adjusted according to the status of communications.
If so, disable automatic volume adjustment as follows.
In the "Communications" tab, change the setting of the item "When Windows detects communications activity" to "Do nothing."
Part of the playback is wrong: e.g., notes are broken off prematurely, or some notes are lost
Problems may be solved by making the settings shown below.
Try adjusting the audio buffer size of your software
If your software allows you to adjust the audio buffer size, try changing the setting.
Normally, clicks and pops can be eliminated by increasing the buffer size.
If your software does not allow you to adjust the buffer size, or if adjusting the buffer size in your software does not solve the problem, you may be able to solve the problem by changing the driver’s audio input/output buffer size.
Try adjusting the buffer size as described in "To change the settings."
Try updating the driver of your display adaptor
You may be able to eliminate clicks and pops by updating the driver for the display adaptor installed in your computer.
Windows Update / Microsoft Update
You may be able to solve the problem by updating your system with "Windows Update" or "Microsoft Update" provided by Microsoft.
Check the power management settings
Open "Control Panel," click "System and Security," and then click "Power Options."
*   If the icon view is selected for the Control Panel, click "Power Options."
In "Choose or customize a power plan," choose "High performance."
*   If the "High performance" plan is not shown, click "Show additional plans."
In the High performance area, click "Change plan settings."
Click "Change advanced power settings."
In the Advanced Settings, click the “+” symbol for "Hard Disk," and click the “+”symbol for "Turn off hard disk after" to open it.
Click "Setting (Minutes)," and click the down arrow to change the setting to "Never."
Click [OK] to close the Power Options window.
Close the "Edit Plan Settings" screen.
"Performance Options" settings of System Properties
Open "Control Panel," click "System and Security," and then click "System."
*   If the icon view is selected for the Control Panel, click "System."
At the left, click "Advanced system settings."
*   If you are asked to enter the password of an Administrator account, sign in to Windows as a user whose Account Type is Administrator, then perform the settings again.
Click [Settings] of the Performance section, and then click the [Advanced] tab.
Select "Background services," and click [OK].
Click [OK] to close "System Properties."
Do the sample rate settings match?
You must set the sampling frequency that's been specified through the audio settings of the application so it matches the VG-99's sampling frequency.
If the Windows monitoring function is enabled, the input sound might be heard in duplicate (doubled), or a feedback loop (oscillation) might occur.
If so, disable the Windows monitoring function as follows.
In "Recording," select VG-99's "IN," and click "Properties."
Open the "Listen" tab, and clear the check box "Listen to this device."
Click [OK] to close "Properties."
Audio clicks and pops occur in the playback or recording immediately after the system has started up, or immediately after the computer has been woken from a Sleep state
Wait a few moments before you perform playback or recording.
Clicks or pops may occur in the sound if a LAN is operating
Try disabling the LAN in the Device Manager.
Such problems may be solved if you check the "Light Load" check box in the Driver Settings dialog box.
If you wish to modify or verify the settings, use the procedure described in "To change the settings."
*   The modified setting will take effect after you turn the power of the VG-99 on/off. Unless you experience problems, use the unchecked (initial) setting.
Playback or recording is interrupted, and then you cannot resume playback or recording
Was your computer experiencing a heavy processing load?
If your computer was experiencing a heavy processing load while the VG-99 was being used, the VG-99 may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again.
[/i]
