Author Topic: VG-99 - Problems with VG99 Editor  (Read 558 times)
Offline tightner
« on: October 02, 2013, 08:41:07 AM »
I've installed the editor, set midi device to 1, set it to 1 on the unit as well. (Win7 64bit)
It kind of works - I can change patches on the unit and see it change in the editor but if I try to change it in the editor it stays on the current patch and won't change. It's just acting weird - I have to keep using task manager to close the program and restart it, sometimes it will come up and I'll get a message "There is no driver installed on your system". I unplug the USBm reboot the program and it comes up and communicates again.
Now, when I finally get it to where it appears to be working, I import the SMF mid file and I see the name and settings in the editor and on the unit BUT the sound doesn't change from what was on the existing patch on the unit.
What am I doing wrong?
« Last Edit: March 02, 2015, 03:40:32 PM by Elantric »
Offline Kevin M
Re:
« Reply #1 on: October 02, 2013, 10:03:52 AM »
What kind of USB port are you connecting to?  The reason I ask is because I had major issues on my system when connecting through a USB 3 port (even though it's supposed to be backwards compatible)
« Last Edit: October 02, 2013, 10:11:04 AM by admsustainiac »
Offline admsustainiac
Re: Problems with VG99 Editor
« Reply #2 on: October 02, 2013, 10:08:47 AM »
Indeed - USB3 Ports prove to be problematic for most folks
Also be sure to read the VG-99 Editor Owners Manual
(this is hidden inside the zip file supplied by Roland, and very few people ever read it or know it exists.
VG-99 Editor 1.01 - How To
http://www.vguitarforums.com/smf/index.php?topic=50.msg78#msg78
http://www.vguitarforums.com/smf/index.php?action=dlattach;topic=50.0;attach=19
« Last Edit: October 02, 2013, 10:11:32 AM by admsustainiac »
