Author Topic: FC 300 help  (Read 483 times)
Offline loopman
FC 300 help
« on: August 20, 2013, 09:28:55 AM »
Hi guys and colleagues,
I need to send the Midi Play, Midi Stop and Midi Rec messages from my FC-300 to my Cubase, thus to trig the Play/Rec/Stop functions on Cubase.
I've tried different ways, but there is no result  >:(
How can I have to set the FC-300 to send these kind of messages?
Help me, thanks a lot
Offline shawnb
Re: FC 300 help
« Reply #1 on: August 20, 2013, 11:27:37 AM »
I'm pretty sure you'll need to work in PATCH mode.
Page 42 in the manual shows which MIDI and MMC commands are available in PATCH mode.  I'd read up on MMC, & see if Cubase supports it (I suspect it does).
I've not done this before so that's about as far as I can help you!
Address the process rather than the outcome.  Then, the outcome becomes more likely.   - Fripp
Offline musicman65
Re: Re: FC 300 help
« Reply #2 on: August 20, 2013, 12:39:22 PM »
If not found in PATCH mode, take a look at CONTROL mode. PATCH is very useful for sending Program Change (PC) commands whereas CONTROL can send strings of PC and CC commands if I recall correctly.
bd
Offline loopman
Re: FC 300 help
« Reply #3 on: August 21, 2013, 03:46:45 AM »
problem solved!!  ;) ;D
I've turned the Midi Merge function of my Edirol midi keyboard to Off, now everything works great!!
Thank you Roland!!
