Author Topic: VG-99 - DIY Mono FX Loop Insert for Normal Guitar PU feed.  (Read 4712 times)
Offline glennfin
Re: VG-99 simple FX Loop for Boutique pedals off Normal Guitar PU feed.
« Reply #25 on: April 05, 2014, 02:22:46 PM »
You're very welcome Elantric!.  ;) Glad to contribute to the VG-99 group.  8)
I've been having a blast today running my Triaxis in the new VG-99 send/return loop.  :D
Thanks Glennfin - Fantastic contribution to our community!
Thanks for your effort in creating this document.
I will make a PDF  and repost as a backup In the VG-99 Reference Download area
Online Elantric
Re: VG-99 - DIY Mono FX Loop Insert for Normal Guitar PU feed.
« Reply #26 on: April 10, 2015, 05:52:12 PM »
A downloadable  PDF version is in the VG-99 Reference Download area here:
http://www.vguitarforums.com/smf/index.php?action=downloads;sa=view;down=87
Online Elantric
« Reply #27 on: March 04, 2016, 10:27:57 AM »
Next time you are debugging "why can't I hear my Normal PU's in my VG-99 / GR-55 / Gp-10 using one 13 pin cable   - be sure nothing is connected to the 1/4" outputs jacks
Just wanted to point out that Godin LGXSA and xtSA 1/4" Output jacks feature the similar circuit as the Fender Roland Ready / GC-1 Strat below.
the Fender Roland Ready Strat / Roland GC-1 Strat's 1/4" output jack is a unique switching jack - The goal is to have a "stock Strat" when using the 1/4" output jack  - so anytime you insert a 1/4" plug into the GC-1's 1/4" "Normal PU Output"  jack  - this isolates removes the normal passive Strat Electronics signal output from entering into the GK Internal active buffer (which might load down the passive PU's and reduce high frequencies) and removes the ability to send normal mag PU tone down Pin #7 of the 13 pin Cable
Offline gron
« Reply #28 on: May 12, 2016, 12:45:30 PM »
Thanks glennfinn,
This sounds like a great mod - Can anyone tell me if these instructions would translate smoothly to a VB-99?
While I suspect this circuit would be much the same I'd rather hear if from someone with a more educated opinion before I start choppin'
Online Elantric
« Reply #29 on: May 12, 2016, 01:46:20 PM »
Should be identical to the VG-99 instructions here
