Author Topic: VG-99: Native drivers for Windows 7 (32-bit & 64-bit)  (Read 3354 times)
Offline DigitialGuitarist
« on: December 21, 2009, 10:34:33 AM »
I just noticed that Roland recently released native VG-99 drivers for Windows 7 -- both 32-bit and 64-bit:
VG-99: V-Guitar System
http://www.rolandus.com/products/productdetails.php?ProductId=849
VG-99 Driver Version 1.0.1 for Windows 7 32-bit Edition
http://www.rolandus.com/support/downloads_updates/eula.php?FileName=vg99_win7_v101.zip.
VG-99 Driver Version 1.0.1 for Windows 7 64-bit Edition
http://www.rolandus.com/support/downloads_updates/eula.php?FileName=vg99_win7_x64_v101.zip
(Moderator Edit)
Please read the attached PDF - its crucial information all VG-99 owners running Windows 7 64 must understand. (the HTML source is the "Read ME" folder in the Roland USB driver zip file)
This document is available by clicking "READ ME" during the VG-99 USB Driver installation (see pic)
« Last Edit: April 17, 2015, 05:42:53 PM by admsustainiac »
Offline Brent Flash
Re: VG-99: Native drivers for Windows 7 (32-bit & 64-bit)
« Reply #1 on: December 21, 2009, 10:45:59 AM »
Welcome to the group DigitialGuitarist!  :)
I hear these new drivers are not working that good. You have any problems with them?
« Reply #2 on: December 21, 2009, 11:05:08 AM »
Thanks for the warm welcome :)
I had trouble installng the original 1.0.0 drivers for Win7 x64.  But within moments after that, the 1.0.1 drivers were released.  And so far, everything for 1.0.1 has been smooth -- at least for me.
Offline s0c9
« Reply #3 on: December 22, 2009, 01:55:30 PM »
The 1.0.1 drivers state on the website that they are "fixes" for the 1.0 install process not completing, and no MIDI drivers being installed.
I installed the 1.0.1 [x64] version and so far they have been great !  No longer need the UA4FX drivers.
Offline Paresh
« Reply #4 on: April 04, 2013, 12:32:50 PM »
I'm just about to make the jump to win 7 also. I dnloaded (but didn't install) the driver. Will read the pdf next. Anything else I need to know so i do it right? Thanks!!
paresh
Online Elantric
« Reply #5 on: April 04, 2013, 12:41:30 PM »
The Roland factory Win7 Drivers  for VG-99 are now working well
Use the specific VG-99 USB driver for your specific Win7 version (32 bit or 64 bit)
Get them here:
http://www.roland.com/support/article/?q=downloads&p=VG-99
Offline noals
« Reply #6 on: July 14, 2015, 09:32:02 AM »
hi, i can't get this thing to work.
i downloaded the drivers from roland : vg99_win7_x64_v101.zip
i have windows 7 x64 up to date.
the installation goes well but "VG99EditorLibrarian101" just don't work.
it's just the same problem with the editor or librarian.
1/ it ask for midi configuration.
2a/ if i set the usb drivers in the vg-99 to advanced, "vg-99 midi" or "vg-99 control" shows up but it's pointless since i don't want to use the midi, i want to use usb.
2b/ if i set the usb drivers in the vg-99 to standars then it don't shows up but i can set the midi with my sound card anyway through the vg-99 isn't connected to my sound card via midi because again, i don't want to use the midi, i just want to use the usb to put sound in the vg-99.
4/ and then if i try to import the sound from the vg-99 to the editor or if u try to import the sound library from the vg-99 to the librarian, i just have an error message telling me that there is a connection problem, the vg-99 isn't connected or whatever through when i change the usb driver mode from advanced to standard, the vg-99 is well recognized by windows and i have a little message that tell me that it's ready to go.
do i actually need to connect the vg-99 in midi to edit or import sound in the vg-99 ?  ???
edit: i don't think my firmware is up to date, maybe that's the problem but if i can't save my sounds before updating, it's kind of a pain as well.
how do i check the version of my firmware ?
thx.
« Last Edit: July 14, 2015, 09:35:46 AM by noals »
Online Elantric
« Reply #7 on: July 14, 2015, 09:42:24 AM »
You have to be on latest VG-99 firmware 1.04  - or the VG-99 Editor will not run.
http://www.vguitarforums.com/smf/index.php?topic=14.0
For answers read the VG-99 FAQ
http://www.vguitarforums.com/smf/index.php?topic=13.0
After you install the Roland VG-99 USB Driver  and set it to Advanced Mode  your computer will see the VG-99 as three separate devices:
1) VG-99 ASIO Audio Device
2 ) VG-99 MIDI DEVICE
3 ) VG-99 MIDI Control device.
In the VG -99 Editor, in the Setup MIDI , make these assignments
MIDI IN = VG-99 Control
MIDI OUT = VG-99 Control
You must also set the VG-99 Editor connection "Set Up MIDI Devices =  "Roland VG-99 CONTROL" for "VG-99 Input/Output."
Read the VG-99 Editor Help file ( it was included in the Roland download file -"VG-99EditorManualE.htm"
http://www.vguitarforums.com/smf/index.php?action=dlattach;topic=50.0;attach=19
Connections and Settings
1. Following the instructions in the VG-99 Owner's Manual, install the driver.
2. Following the instructions in the VG-99 Owner's Manual, connect the VG-99 and your
computer. You cannot run VG-99 Editor if the VG-99 and the computer are not properly connected.
3. Turn on the power to the VG-99, then start up VG-99 Editor.
4. If you are using a USB connection and running VG-99 Editor for the first time, be sure to
select "Set Up MIDI Devices..." from the "Setup" menu to open the dialog, then select
If connecting through means other than USB, specify the port connected to the VG-99.
5. For "Device ID," select the same number as the "DEVICE ID" parameter on the VG-99
(SYSTEM -> MIDI -> DEVICE ID).
* Do not disconnect the USB cable connecting the VG-99 while VG-99 Editor is
running.
* If the USB cable is disconnected and reconnected while the VG-99 is in use, or if
the power of the VG-99 is turned off, then on again, it may stop operating correctly.
If this occurs, after resuming, you should exit all applications
« Last Edit: July 14, 2015, 10:27:49 AM by Elantric »
Offline noals
« Reply #8 on: July 14, 2015, 11:41:40 AM »
that solved the problem, thx.
Offline Slappy_G
Windows 7 (64-bit) driver link is broken!
« Reply #9 on: November 29, 2015, 01:25:23 PM »
Admittedly, I'm a total n00b here, and this may be a dumb question, but the Win 7 x64 driver 1.01 link is broken and I have gotten no response from Roland.  All that is listed on the site for 64-bit Windows 7 is the 1.00 version.
Was 1.01 pulled for some reason, or are you guys installing the Win8 driver, or do you have another source - dropbox, etc, for the 1.01 version?
Appreciate the push in the right direction - just purchased a VG-99 + FC-300 on eBay and trying to get my PC ready when they arrive.  I'm an old hand with the VG-88, but looking forward to the new toys.
