Author Topic: FC300 Expression pedal 1 issues with VG99  (Read 117 times)
Offline Nobulusprime
« on: May 06, 2017, 06:53:03 AM »
I'm hoping someone can help me here, as I'm at a loss...
I'm struggling to get the Expression pedal 1 on an FC300 that I just bought to function properly.
It won't assign to anything using the RRC2 cable. It does appear to work as a wah on some patches and it won't switch off even when you turn the WAH off! I've replicated the assigns of Expression 2 and to see if it would work but no joy.
All the patches I have downloaded from the forum that use the Expression pedal 1 aren't working properly...
The pedal and switch is working over midi fine so it's not a mechanical issue.
The operating system is 1.02 so it's up to date and I have performed a factory reset
Could it be the RRC2 cable? Or is there some internal assign/disable feature in the unit itself that I've missed?
Please help.
Offline Brent Flash
Re: FC300 Expression pedal 1 issues with VG99
« Reply #1 on: May 06, 2017, 07:40:29 AM »
First thing we need to know, is the FC in SYSEX mode? Next thing we need to know is, are you making all assignment setting on the VG-99? And then make sure that the VG-99 SYSTEM / CTL / FC 300 settings are all on ASSIGNABLE(PATCH).
« Reply #2 on: May 06, 2017, 07:57:14 AM »
Thanks Brent - genius! The expression 1 wasn't set to assignable patch! So easy
Thanks again mate
Sean
