Author Topic: FC-300 RRC2 Ethercon RJ-45 Connector housing - where do can I get a replacement?  (Read 387 times)
Offline M2
I use the FC-300 to control my VG-99. Part of the housing of the RRC2 OUT Connector on the FC-300 somehow broke, so I can no longer control the VG-99. It looks like I just need a new socket assembly for the RRC2 Out Connector. Can I buy this part somewhere, and how hard is it to replace, as I want to avoid the horrendous charges if I take this to an official Roland dealer.
Thanks for your help,
M2
« Last Edit: August 04, 2016, 03:52:01 PM by Elantric »
M2 Musik Pub
Online Elantric
Contact Roland via telephone with a Credit Card 9am-5pm PST weekdays
Roland Corporation U.S.
5100 S. Eastern Ave.
Los Angeles, CA 90040-2938
Customer Service Tel: (323) 890-3700
When you contact Customer Service,  tell them you want to purchase  the FC-300 RRC2 Board with Connector
http://www.vguitarforums.com/smf/index.php?topic=2563.0
Was looking for pictures of the PCBs of the FC300 on the internet and couldn't find any. So I had to take one myself.
I did not expect to find this many boards. I found:
* a main board with the small buttons, the displays, and connectors for power and midi.
* a seperate board with the jack connections for external pedals
* two boards for the footswitches and leds
* a small board for the rrc2 connection
* a small board for the led of expression pedal 2
* two small boards for the potmeters of both expression pedals
and avoid stepping on your plugs at gigs - they tend to crack internal PC Boards
« Last Edit: August 04, 2016, 01:38:20 PM by Elantric »
Offline M2
Thanks Elantric. Yes, I have a trouble ticket with them.
M2 Musik Pub
Online Elantric
in my experience Roland US "Trouble Tickets" online  will get you nowhere and weeks for a response
I pick up the telephone and talk directly to the Roland Customer Service Parts sales  - and say"
I'm an independent repair shop and want to purchase   the FC-300 RRC2 Board with Connector
and they typically sell this to me  - I estimate it will cost $50
« Last Edit: August 04, 2016, 01:38:51 PM by Elantric »
Offline M2
Thanks very much!!!
M2 Musik Pub
Online Elantric
Here in USA  - Roland / Boss Customer service is still in the dark ages - they respond to telephone calls
Part of the reason Reeves Gabrels dropped using the VG-8 at live gigs is because of the complete lack of Roland Customer Support when he needed emergency GK 13 pin cables and replacement jacks mid tour while touring with David Bowie back in the late 1990's
http://www.guitarmoderne.com/artists/the-ultimate-reeves-gabrels-interview
From 1996 on, I started to think of the PA as my amp, even though I had two 600-watt power amps and four 4x12s on stage. The cabs weren’t miked, they were just for monitoring; everything went straight from the VG-8 to the house. I had three VG-8s: A, B, and a spare. I rewrote all their presets. Since I got no help from Roland, I painted them so you couldn’t tell what they were.
« Last Edit: August 04, 2016, 01:47:38 PM by Elantric »
Offline M2
Saw the Earthling Tour with Reeves and yes, he indeed painted them over.
M2 Musik Pub
Offline M2
Hi Elantric,
Sorry for the dumb question but why do I need to buy the entire board when it's just that the bottom part of the black plastic housing inside the connector jack itself has somehow chipped off?
M2
(Image removed from quote.) and avoid stepping on your plugs at gigs - they tend to crack internal PC Boards
M2 Musik Pub
Online Elantric
Its 90% confirmed this is the type used
Neutrik # NE8FAH-C5
http://www.mouser.com/ProductDetail/Neutrik/NE8FAH-C5/?qs=yAJ577jGV73mSHthIeMdNw%3D%3D&gclid=CjwKEAjwz4u9BRCbioK3stnBznESJADA75xbKh1kCkRubv1mMOD7wbCEYCKKo_9r1cwoAJ4JkFA1ihoCCd_w_wcB
http://www.neutrik.com/zoolu-website/media/download/13409/Drawing+NE8FAH-C5
http://www.mouser.com/ds/2/289/Product_Guide_-_Section_Data_Connectors-882111.pdf
post pics (inside and outside of your damaged FC-300
Typically the FC-300's  RRC2 PC board has damage   or you damage it during unsoldering - resoldering  the new replacement Ethercon RJ45 jack
« Last Edit: August 04, 2016, 03:54:16 PM by Elantric »
Offline M2
Thanks, Elantric. I will work up the courage to open the board.  By holding the inserted cable at a certain angle I can intermittently get the board to power up and communicate with the VG-99. What it does as it is currently broken - it powers up the FC-300 but the FC-300 does not revert to the current patch in the VG-99 and the two do not communicate. That's why I am hoping it's just the Neutrik connector and perhaps my guitar/amp tech could do the work.
Neutrik # NE8FAH-C5
M2 Musik Pub
Offline M2
I called Roland to order this part and FYI they do not sell this single board any more, you have to special order multiple internal boards as a sngle package, takes 4 to six weeks and is $245 dollars.
M2
M2 Musik Pub
Online Elantric
Might try here
http://www.fullcompass.com/brand/ROL_Roland/Guitar-Parts2.html
or
Neutrik # NE8FAH-C5
« Last Edit: September 19, 2016, 03:18:00 PM by Elantric »
Offline M2
Thanks very much! They do not have the part so I am ordering the Neutrik connector and praying that was the only component that was damanged....
Might try here
or
Neutrik # NE8FAH-C5
M2 Musik Pub
