Author Topic: FC300 - Difference in switching with FS-5L or FS-6?  (Read 1179 times)
Offline clearlight
  • Patron Supporter
  • Senior Member
  • Total likes: 3
  • Rating: 6
  • I'm Ed Clearlight, you may remember me from stop a
« on: May 03, 2009, 01:50:54 PM »
Im trying to use an fs5L with my fc300.
it seems i have to click the pedal twice for things to change....
is this normal?
any help would be appreciated...
« Last Edit: April 29, 2015, 06:19:05 PM by admsustainiac »
My Music
My Band Website
GUITARS: 2x RG1521, 3x RG321 w/gk, Rg721 Fretless Modified, AmStd FatStrat w/gk, various others....
XV5050,Triton etc..
KOMPLETE 7
VGUITAR Stuff: VG99, FC300, RC5-
Offline Brent Flash
Re: FC300 - Difference in switching with FS-5L or FS-6?
« Reply #1 on: May 03, 2009, 01:59:24 PM »
I have had this happen to me when use LATCH in the CONTROL ASSIGN pane. But I don't remember if it happened when I had the FC in SYEX mode or another mode. Are you in SYSEX mode?
Offline Brent Flash
« Reply #2 on: May 03, 2009, 02:13:59 PM »
You may want to check out this thread. It has some info on weird things happening with controller like this.
http://www.vguitarforums.com/smf/index.php/topic,1377.0.html
Offline clearlight
  • Patron Supporter
  • Senior Member
  • Total likes: 3
  • Rating: 6
« Reply #3 on: May 05, 2009, 10:12:45 AM »
well, changing ctl3 to momentary worked but isn't that the opposite of how it should be?
for instance how would i do a momentary?
weird
My Music
My Band Website
XV5050,Triton etc..
KOMPLETE 7
Offline Brent Flash
« Reply #4 on: May 05, 2009, 01:05:29 PM »
weird
The answer to your question is, this is a latching foot switch. Probably not the best choice to use with the FC-300. THe FS-5U may have been a better choice.
Offline clearlight
  • Patron Supporter
  • Senior Member
  • Total likes: 3
  • Rating: 6
« Reply #5 on: May 05, 2009, 06:29:20 PM »
not to beat a dead horse, but
i looked up the fs5u and its says that its "non latching"
is latching what i wanted , as momentary would only  engage the function while stepping....??
My Music
My Band Website
XV5050,Triton etc..
KOMPLETE 7
Offline Brent Flash
« Reply #6 on: May 05, 2009, 06:41:32 PM »
The VG does the latching, that is why your FS-5L is not working as expected. You may be able to go into the FC-300 parameters and select Latch for the switch input you are using it on and that may correct it. I don't know. I use all momentary switches. They work as expected in SYEX mode for the FC-300. In normal mode I have some issues but I think the latching switches may be worse?  ::)
Offline rcknrllmn
« Reply #7 on: August 28, 2013, 05:17:32 PM »
Controlling my VG-99 with the FC-300.  I have several FS-5L's in the control jacks for IA commands.  I have to tap the pedal twice for the desired effect.  Is this because it is latched?  Would it benefit me to get the FS-6 & use it unlatched so I only have to tap once?
« Last Edit: April 29, 2015, 05:53:47 PM by admsustainiac »
Offline admsustainiac
« Reply #8 on: April 29, 2015, 05:58:38 PM »
Read
Which Footswitch do I need? .. Latch or Unlatch?
http://www.vguitarforums.com/smf/index.php?topic=13211.0
VG-99 Control Assign  [toggle] + FS-6  [Latch] = double latching, pedal requires 2 presses to do one function (effect on/off)
VG-99 Control Assign   [toggle] + FS-6  [Moment] = press once to toggle effect on/off, pedal led only lights while held down
VG-99 Control Assign   [moment] + FS-6  [moment] = effect only on while pedal held down, pedal led only on while held down
VG-99 Control Assign  [moment] + FS-6  [Latch] = press once to toggle effect on/off, pedal led toggles with effect status
