Author Topic: Re: VG-99 - How to make your Guitar / Mix/ GK switch work on your guitar  (Read 1175 times)
Offline Elantric
Offline Smash
Re: Re: VG-99 - How to make your Guitar / Mix/ GK switch work on your guitar
« Reply #51 on: September 29, 2015, 08:30:50 AM »
So I am sending the mag pup signal down the 13pin cable and am using the guitar out to get the mag pup separately from the VG99 output.
What I want is that when I switch the GK mix control to guitar only I want the VG99 output muted and only the mag pup to sound.
I am expecting this because it's the opposite of the other end of the switch where GK only option definitely mutes the mag pup.
I've tried a different cable and different GK3 - is it me or some VG99 setting or is it not possible to have this option?
What should happen?  ???
« Last Edit: September 29, 2015, 08:51:52 AM by Elantric »
Offline Elantric
« Reply #52 on: September 29, 2015, 08:54:37 AM »
For strategies - start at first post here
http://www.vguitarforums.com/smf/index.php?topic=419.0
« Last Edit: September 29, 2015, 10:09:42 AM by Elantric »
Offline aprilbloom
« Reply #53 on: October 27, 2016, 01:14:44 PM »
Hi All
I have been using the VG 99 for many years now
But today i had this problem ,could someone please help me here...
The GK-3  3 way switch (on the guitar) used to do the following:
UP =   "Guitar" position  =  VG99  B Chain;typical Normal guitar from the Normal PUs,
DOWN =  "GK" (synth) Position is the VG99 A Chain, typical HEX COSM guitar from the GK hex PU,
Middle  =  both A & B Chains combined.
But now after i used a Boss ES 5 to midi control the VG...when i switch the GK3 WAY to B positon (Normal pickup) it automatically turns the patch level to 0.
And the COSM Guitar is still on.but cant hear it as the patch level is at zero...[/b][/u][/b]
Offline Elantric
« Reply #54 on: October 27, 2016, 01:19:43 PM »
Be sure to read this thread from the start
http://www.vguitarforums.com/smf/index.php?topic=16759.0
