Author Topic: FC300 - Changing pedal functions in Control mode  (Read 312 times)
Offline Big Jim
« on: October 13, 2015, 09:20:53 AM »
I have searched the forums but I haven't found anything about this here. I don't even know if it is possible.
Is there a way to change the functionality of a pedal? I know I can set a pedal to let's say a wah and then assign a button to turn it on or off. But my question is this can I assign a pedal to be (for example) A/B balance "AND" a wah? and then program a separate button to switch back and forth between the 2? Kind of like turn one on and the other off at the same time and then vice versa.
jim
« Last Edit: October 13, 2015, 10:15:41 AM by admsustainiac »
"How long does getting thin take?" Pooh asked anxiously. - A. A. Milne (1882 - 1956)
Offline admsustainiac
Re: FC300 - Changing pedal functions in Control mode
« Reply #1 on: October 13, 2015, 10:15:09 AM »
If you are using FC300 with VG-99 - use the VG-99 Editor to reassign the FC300 pedal functions
Offline Big Jim
« Reply #2 on: October 13, 2015, 07:36:19 PM »
But how do you program say ctrl 1 to change the function of pedal 1?
