Author Topic: VG-99 - Can the GK-3 volume knob be reversed?  (Read 513 times)
Offline adamlee011
« on: December 09, 2014, 08:07:40 PM »
Hi everyone. I'm new to the forum and to the vg99. late to the game, I know but I have had a vg88 since they came out :) Anyway I haven't had any luck finding an answer to this or (obviously) a way to make it happen. I have a gk2a on an old Ibanez and now a gk3 on an sz. the gk3 knob is great being so large and all, but I'm constantly, unknowingly, turning it down when pressing the buttons on the module. I would like to swap the min and max on the knob (reverse it). I thought i read that all the controls on the gk are really just midi controlers so if there isn't a setting specifically for that, couldn't the knob be set so min is 127 and max is 1 or vise versa? I know nothing about midi really yet other than controlling a couple plugins with edrums and keyboards and even that knowledge is pretty basic.  Hey I'm a guitarist  :-\. Anyone have any suggestions? Thanks for reading. And thanks for all the amazing info and patches here. Without this forum, I'd feel quite alone in the world of vguitar.
« Last Edit: September 19, 2016, 05:22:33 PM by admsustainiac »
Offline Brent Flash
Re: VG-99 - Can the GK-3 volume knob be reversed?
« Reply #1 on: December 09, 2014, 08:29:16 PM »
Do you have the EDITOR set up to use with the VG99? The reason I ask is that the instructions for doing what you want is so much easier to explain on the EDITOR than on the VG99 control surface.
Offline Elantric
« Reply #2 on: December 10, 2014, 03:14:03 PM »
Launch the VG-99 Editor and click Control Assign
Find the GK Volume Knob -
and make these changes:
Target Min = 127
Target Max = 0
(leave the Source Active Range: Low = 0 < High = 127)
« Last Edit: September 19, 2016, 05:15:05 PM by admsustainiac »
Offline adamlee011
« Reply #3 on: December 13, 2014, 11:06:23 PM »
(Image removed from quote.)
Target Min = 127
Target Max = 0
I do have the editor installed but I've only delved but so deep into it so far. Thank you guys very much!
Offline adamlee011
« Reply #4 on: December 15, 2014, 07:19:37 PM »
unfortunately it's not allowing me to do that. the max value has tomremain higher than the min value. bummer. trying to swap the volume values to the left there isn't doing it for me either. unless i'm missing something. it had no effect.
Offline admsustainiac
« Reply #5 on: September 19, 2016, 05:15:55 PM »
Leave the GK VOL Source Active Range: Low = 0 < High = 127)
But select your target FX parameter, and make these changes to reverse the GK VOL control action
Target Min = 100
Target Max = 0
« Last Edit: September 20, 2016, 02:33:02 AM by Elantric »
Offline mooncaine
« Reply #6 on: September 20, 2016, 12:57:27 AM »
Actually, the Target setting only goes from 0 to 100, so don't panic. Set the min to 100 and the max to 0. Kapow! Thou hast reversed thy knob.
