Author Topic: FC300 - to control a Roland SPD-S Drum sampling pad module?  (Read 506 times)
Offline mostlyjazzer
« on: August 15, 2014, 10:31:15 PM »
Greetings everyone.
In an attempt to use the storable loops on the SPD-S percussion sampling pad, using a foot control,and that
I'm trying to avoid buying a looper rc-50 or other type of looper pedal,
(because I already own a SPD-S that can store many loops on many patches),
and also the fact that I own a Roland FC-300 midi pedalboard;
! was wondering if that FC-300
could be used to enable a start/stop command on given pad(s) on a given patch of the SPD-S.
So for example patch number 1
has a bassline loop on pad 1,
and a percussion loop on pad 2 etc..
and by pressing a particular pedal on said pedalboard (FC-300) I could control the play/stop function of any pads (limited by the amount of footswitches of the FC-300 of course (5 + 2 CTRL switches).
Is this doable? Is a play or stop command possible to execute from a midi pedalboard to the SPD-S?
I appreciate your opinions/experience and also alternatives if you know of any.
« Last Edit: April 29, 2015, 05:47:35 PM by admsustainiac »
Offline shawnb
Re: Using a FC-300 to control a Roland SPD-S Drum sampling pad module?
« Reply #1 on: August 16, 2014, 12:59:49 AM »
Short answer: yes (95% confidence).   You can program the fc300 to send just about any midi sequence you can think of, even sysex.
I haven't done exactly what you're saying, though, so you'd need to check the fc300 section of the forum to help find the manual & read up.
http://www.vguitarforums.com/smf/index.php?topic=30.msg57#msg57
Address the process rather than the outcome.  Then, the outcome becomes more likely.   - Fripp
« Reply #2 on: August 16, 2014, 04:29:38 PM »
Thanks for the reply shawnb. Looks like I first need to build some familiarity with the midi protocol, and then see the particualrs on both devices.
