Show us your VGuitar gear ...
Started by GrinPicker, March 09, 2009, 12:28:36 PM
If you fit big enough wheels, you can push it to the gig...     ;D
rolandvg99
My revised VG-99 setup with a Motu 8M, Mac mini 2011 server with 16GB ram and dual 500 GB SSD, iConnectMIDI4+ and an ART HeadAMP4Pro. The VG-99 is mounted on a sliding rack shelf.
My little Soundcloud corner
QuoteMy revised VG-99 setup with a Motu 8M, Mac mini 2011 server with 16GB ram and dual 500 GB SSD, iConnectMIDI4+ and an ART HeadAMP4Pro. The VG-99 is mounted on a sliding rack shelf.
Thats a lot of 5 pin MIDI I/O  - what are you using the 5 pin MIDI for?
rolandvg99
Quote from: Elantric on July 06, 2015, 10:37:21 AM
Mainly for remote control of my VG-99 from my iPad and system wide tap tempo from my Molten Voltage TEMPODE. I also use it when connected to my Yamaha 01V96 for remote control when not booting my mac.
Headless68
My case will hold VG99 + GR30 + VG8 + space at the bottom for floor board pedals & GKPX-14 switch
It 'should look similar to a JC120 (with wheels!) when complete
So live it's just this box + amp + guitar and near zero setup time
Will post the finished thing
Headless68
Just about done - have to finish the floor board yet when I decide which midi pedal (probably Icon G-Board if it works with itrack dock)
Now it's as simple as lid and front off - 1xStereo out to amp - pull out the floor board - plug the already connected GK cable to my guitar & power up - 30 seconds set up time :-)
Headless
rolandvg99
Headless68
Icon G-board is on its way - a good second user one came up at the right price, so I hope it does work with the iTrack Dock :-)
...And I can finish the pedal board now, two more CTL switches for the 'V's and the G-board will be midi control for the looper on the ipad
I'm looking to build one of these asap
Sixeights's Universal USB Host MIDI Control box
https://www.vguitarforums.com/smf/index.php?topic=15154.msg110782#msg110782
ConstruKction
#259
My luthier sent me a couple of photos as he was working on installing the GK-3 pickup (in reverse position) on my Japanese 69' reissue Mustang.
Gallery Link
I'm expecting a call tomorrow, or after tomorrow when he's done soldering, I'll haul the VG-99 over there to test in on spot to see whether everything is soldered correctly.
Fingers crossed!
Congratulations!
Good to see Fender still uses real wood in the Mustang Body ( not a speck of  Plywood!)
Meltdown
#261
My live gear.
2x VG99
FC300
Home made US20.
Footcontroller 1 of FC300 used to morph sound from one VG into the other.
Effect tail like delays, reverb are retained into next preset.
No amps used. 4 channels go direct into the P.A. system.
Monitoring through in-ear system.
Visit my website!
http://www.tachyonmusic.com
Headless68
Great Idea - MORE VG-99's !
;D
Headless
krysh
sold my gr-55 to buy a SY-300, so nothing special:
my 2 ct's, yours,
krysh
sy-300 newbie and bass- and guitarplayer from hamburg, germany
Nice fx rig covers a lot of ground
Is that the Godin Montreal on far right?
krysh
#265
Quote from: Elantric on July 25, 2015, 04:20:15 PM
whos, mine?
well then, no. it reads GUILD on the headstock.
my 2 ct's, yours,
krysh
Sorry - I was on a smartphone earlier,  and it completely cut off the whole right 1/3 side of your pic!
krysh
Quote from: Elantric on July 25, 2015, 06:23:40 PM
sorry for you. ;)
well, a lot pedal space - it's only what I need on a stage, isn't it? ;)
my 2 ct's, yours,
krysh
Quote from: Meltdown on July 25, 2015, 09:46:05 AM
My live gear.
2x VG99
FC300
Home made US20.
I'd love to hear an example of you using this system live.  I aspire to such madness!
krysh
Quote from: aliensporebomb on July 25, 2015, 07:15:06 PM
+1
my 2 ct's, yours,
krysh
JolietJake
Yep.  If I must pick ONE device, it's my '55.
erokenn
My spalted maple Custom 24 with GK GT3 kit installed. Use it with my GR-55  ;D
Jim Williams
Here is a shot of the pedal board I am working on. I will be doing some final wiring to get it up and running. there are a few add-ons that are still in the works concerning the midi but everything else is covered.
Skype: (upon Request)
krysh
was able to reduce the floor space a bit, and now the complete rig (an older Carr "the Vincent" for guitar only and an epifani UL 502 and a custom 1x12" cab for the SY-300):
my 2 ct's, yours,
krysh
