GR-55 - Rainsong by Zep patch
Started by Guitarbot, October 05, 2011, 10:01:10 AM
Guitarbot
Hear it here:
http://www.reverbnation.com/bobbyguitarbotdeveaux#!/artist/artist_songs/1484321
greekjgg
How do you load this? it's not the standard file type for GR-55
Setup:
GR55
Rocktron Talkbox
TC Helicon Voicetone C1
Tech 21 Power Engine 60
Use the Roland GR-55 Librarian app.
then select "File", then "Import SMF"
greekjgg
Quote from: Elantric on February 13, 2012, 09:41:50 AM
Will try that! Thanks!
Setup:
GR55
Rocktron Talkbox
greekjgg
So I click "import SMF", this opens my download folder and I select the midi file. When I select the file the download folder closes and then nothing happens. I don't see the file in the librarian. Am I missing something?
Setup:
GR55
Rocktron Talkbox
The ZepRainsong.Mid file loads right up using Gumtowns GR-55 Floorboard Editor
see attached for a G5L version
greekjgg
Ok, finally got it to work. Not sure what the difference was. Now about 25% of the patches I downloaded earlier don't work. Is there something I'm not doing correctly?
Setup:
GR55
Rocktron Talkbox
Guitarbot
Hi,
Sorry I didn't see your post earlier or I would have sent it to you in any format you needed.  Hope you find it useable:)
