change from loop to one shot mode without stopping the loop?
Started by geormiet, December 17, 2013, 11:03:02 PM
geormiet
I'm guessing there's no way to do this?     It seems like its not even possible to do it if an individual track is stopped, if there is another track playing.
I don't think so.  I think as a general rule, you cannot change track parameters while the track is running, which is a bit of a pain.
If you have the STOP MODE set to "Loop end" you get almost the same thing, though.  It will loop as long as you want it, and it will play thru to the end once you press STOP.
geormiet
Thanks for the reply.   I didn't have high hopes for this one :p
The big difference between  loop end stop vs one shot mode, is that you can tap the play button while in one shot mode to immediately retrigger the beginning of the loop.    A really cool dj-ish feature which I didn't realize was possible on the rc300 after more than a year of using it.
