GR-55 - How do I connect an external wah?
Started by Opustaylor, August 14, 2014, 10:12:51 AM
Opustaylor
If I want to connect an external wah pedal to the GR55, how would I connect it? Thank you.
Most here write a GR-55 patch that employs the GR-55's built in Wah Wah
Your options are very limited, if the external Wah is used
1) Guitar normal pickup output > Wah > GK guitar input
2) Wah on GR-55 output (least desirable option)
3) Use built in Wah effect from the GR-55. ( the easiest option)
Quote1) Guitar normal pickup output > Wah > GK guitar input
Since the GR-55 lack a normal 1/4' Guitar Input jack , There will be soldering involved - or requirement for other product purchase
Read about all your options here:
GR-55 FAQ: TOP THINGS TO KNOW
Or using two extra regular cables to your guitar.
Guitar normal pickup jack > cable to Wah
Wah + cable > to GK-3 normal guitar input (assuming you use a GK-3).
another option: GR-55 Guitar out > Wah > guitar amp via pedalboard.
vtgearhead
Quote from: Opustaylor on August 14, 2014, 10:12:51 AM
I ended up installing a pair of "break" jacks to insert my Cry-Baby pedal in between the guitar mag output and the GR-55 electronics.  After a lot of experimentation, I just couldn't warm up to the GR-55 wah emulation.
