GP-10 - Output Level
Started by bfantle, November 12, 2017, 03:18:30 PM
bfantle
Hi all,
I am using the GP-10 straight to my PA.  However the signal seems to be pretty low so i had to turn the gain on the PA up very high(along with the volume slider and GP ouput knpb).  Is there a DI box or something that can add an extra boost that someone could recommend.  Or another strategy.
thanks
Barry
Start with a factory reset and then get your GK pickup set up properly.  Read the GK3 pickup setup manual and the GP-10 setup manual.
https://www.roland.com/us/support/by_product/gk-3/owners_manuals/
https://www.vguitarforums.com/smf/index.php?board=11.0
Redvers
It should be good enough to go straight into a mixer. A DI never hurts but I don't think this is what's causing the drop.
I use it all the time straight to PA, no problem with the level.
bfantle
what level do you have the patch levels set to?
Quote from: bfantle on November 24, 2017, 01:33:49 PM
From 30 to 188 depending on the different settings in the patch
