GP-10- Poly mode not working in cubase pro 9.5
Started by imyourcluster, August 03, 2018, 04:44:23 AM
imyourcluster
Hello,
I've just bought the gp-10 and I'm experimenting with external midi triggering.
I'm using a focusrite as audio interface and the gp-10 via USB to send midi messages.
I want to send each string on a different midi channel in order to trigger different midi instruments in cubase at the same time.
Unfortunately even if I set the "Poly Mode" on gp-10 Cubase takes all 6 strings at once on all midi channels..
Am I missing something?
Can please anyone help me to figure this out?
You need MONO Mode to achieve 1 string per MIDI channel.
Read GP-10 MIDI Guitar thread here
https://www.vguitarforums.com/smf/index.php?topic=11913.0
imyourcluster
Quote from: admin on August 03, 2018, 07:48:15 AM
I tried what you suggested, but cubase takes all the strings  at the same time regardless midi channel setting..
If use the standalone version of kontakt works fine (with mono mode)..So I guess it has to do with cubase... any hints?
imyourcluster
SOLVED
I had to set a midi channel filter from "input transformer" in the midi channel strip per each track
thank you
tacman7
I was recording the audio put out by the GP10, before processing.
So you could do things to it before going through the amp sim/fx on the gp10.
Reamping.
That you can do with 3 stereo tracks to get the six strings.
