AMT PANGEA CP-100FX Cab IR Sim / FX/ MIDI Controller / D.I.
Started by Elantric, August 04, 2016, 09:29:09 AM
http://media.amtelectronics.com/amt-pangaea-cp-100fx/
http://amtelectronics.com/new/amt-pangaea-cp-100fx/
"AMT PANGAEA CP-100FX - IR-Cabinet Simulator and Effects Processor
AMT team is very pleased to present you our new product AMT PANGAEA CP-100FX. This is not just switching cabinet emulator, combined with the effects processor: AMT PANGAEA CP-100FX - is a customizable tool for both professional, a lot of touring guitarist, as well as for the novice his career man.With AMT PANGAEA CP-100FX can qualitatively simulate the sound of any guitar cabinet, downloading the corresponding impulse responses (IRs) guitar cabinets. You can store up to 99 presets with different IRs in structure with built-in guitar effects processor (or not) in the internal memory of the device.
AMT PANGAEA CP-100FX has two basic modes of operation with the IRs to choose from:
1 MODE:
Download one mono IRs with the parameters:
24 x 48 kHz Bit 85.33 ms long (4096 sample) with a total delay of the signal 1,5 mS
MODE 2:
Separate loading two mono IRs with the same parameters as in mode 1, configurable for volume and pan, for a total delay of 1.8 mS signal.
Logically predictable interface AMT PANGAEA CP-100FX, controlled by OLED display and buttons makes operation of the device convenient and comfortable.
EFFECTS UNIT AMT PANGAEA CP-100FX contains the following modules:TUNERTuner to tune a musical instrument.PR - Pre. Amp.pre-amp emulation and vacuum triode overdrive.AFR pre-amplifier (Pre Amp.) - Is governed by classical tone controls, control GAIN - preamplifier sensitivity. Parameters VOLUME - adjusts the output level indicator is displayed. This module (Pre. Amp) is for connecting the pedal overdrive without using an external preamp.Main characteristics:- Five editable and storable parameters;- Pre output level indicator. Amp.
PA - Power Amp.
Emulation overloaded power amplifier.
Pre-installed set of standard diagrams AFC tube amplifier output stages and two single-ended with two types of lamps, such as the 6L6 and EL34.
- Four editable and storable parameter;
- Output level indicator Slave.
EQ - Parametric EQ
Five-band parametric equalizer.
- Gain ± 15db, F1 = 20-220Hz, Q1 = 0,1-10
- Gain ± 15db, F2 = 260-460Hz, Q2 = 0,1-10
- Gain ± 15db, F3 = 600-1000Hz, Q3 = 0,1-10
- Gain ± 15db, F4 = 1000-3000Hz, Q4 = 0,1-10
- Gain ± 15db, F3 = 1000-11000Hz, Q5 = 0,1-10
HPF - filter suppressing low frequencies.
LPF - filter high frequency suppression.
Presence - the parameter that regulates the upper frequency increase of the area of the middle band
DL - Delay
The effect of the delay sound (stereo output).
Delay (delay) is the effect of the recording of the input signal segment and reproducing it through a certain period of time. This entry can be repeated one time or repeatedly.
Main characteristics:- The range of the delay time from 10 to 2730 mS (mile seconds);- Twelve (12) edited and saved parameters;- Two off, adjustable separately for the time, volume and pan. The main signal delay with adjustable parameter F_Back and second, the time delay which is adjustable from 0 to delay the primary;- Delay outputs are LPF and HPF filters that apply only to the delayed signal;- Adjust the frequency and depth of the delayed signal modulation;- "Reverse" mode - repeats are played backwards
PH - Phaser
The effect creates a "rotating" the sound based on the phase shift signal.
- With the amount of phase shift of the cells 4, 6 and 8;
- Six editable and storable parameters.
FL- Flanger
Flanger effect is based on the principle of modulated delay line time withdrawal, and the effect Chorus, but uses a shorter delay, adding regeneration (or repeats) to the delayed signal. This leads to the creation of additional coloration.
- Adjustable delay time;
- Two forms of the modulating signal (sine or triangle
CH - ChorusEffect Chorusimitiruet choral sound of musical instruments. The effect is realized by adding the original signal its own copy, or copies, shifted in time by the magnitude of the order of 20-30 milliseconds, with shift time changes continuously.Main characteristics:- Five modify and save settings:- Four types of chorus:1) - a delay line;2) - two of the delay line, a signal modulated in antiphase left and right channel, creating a stereo effect;3) - a delay line 3, a three-phase sinusoidal modulating signal simulating "the effect Leslie";4) - the same as 3), only the left channel signal are mixed to direct in opposite, also creating a stereo space.
ER - EarlyReflectionEarlyReflection - numerous early reflections of the signal. The effect gives the sound density and volume.Main characteristics:- Two change and save the setting.RV - ReverbReverb - effect creates a certain acoustic environment of the original sound by emulating the characteristics given room or space.
Main characteristics:- Seven modify and save settings.TR - TremoloTremolo - the effect of cyclical changes in the volume.Main characteristics:- Two kinds of modulating signal: sine or square;- Four change and save the setting.
FEATURES OF THE OPERATION OF THE UNIT AMT PANGAEA CP-100FXThe AMT PANGAEA CP-100FX all pulses are loaded with a microSD card.The device has a full-fledged file browser that allows you to "roam" on your card, and listen to the sound of the pulse in real time. Saves all pulses in the internal memory of the device, in particular preset effects settings with FX.In addition, access to the internal memory can also be arranged through a USB connection to a PC - for storage or sharing presets, as well as downloading software updates. At the same time the computer will recognize the device as well as in the case with the device AMT PANGAEA CP-100: a standard "flash" memory.
For each preset has 16 controllers. That is, you can assign a 16-ty of key parameters (volume, modulation speed, power on / off, etc.) that can be customized to any midi controller (or on an external expression pedal, for which there is a connection socket). Thus, you have the opportunity to manage one preset with 16 parameters in real time. At the same time the expression pedal, of course, is calibrated.The device has a switchable master volume and three-band master EQ to correct for a specific case.On the side panel there is a S / PDIF output signal with two connection modes - the master output or Dryvyhod - output directly to ADC.
General Specifications
A / D - D / A converters 24 bits;
Sampling frequency: 48 kHz;
Section DSP: Processor ADSP-21489;
Simultaneous Effects: 10;
Preset Memory: 99 user presets (1-99);
Dimensions: 210 x36 x67 mm (W x H x D);
Device weight: 0.7 kg.
Power Requirements:
Adapter: AMT Input AC100 - 265 V, 50-60 Hz, Output 12V;
Current consumption AMT PANGAEA CP-100FX 230 mA.
http://amtelectronics.com/new/manuals/Pangaea-CP-100FX-Users-Guide-Rev-A-ENG.pdf
AMT CP100FX Cab IR Sim / FX/ MIDI Controller / D.I.
Manual
AMT is proud to introduce to you the new AMT Pangea CP-100FX. The CP-100FX is not just an impulse guitar cabinet emulator, however an extremely powerful effects processor as well.
The AMT Pangea CP-100FX will allow you to create a quality sound emulation of any guitar cabinet by loading appropriate impulse responses (IRs) of guitar cabinets; anywhere, with no DAW/VST/computers required.
All impulses are loaded from microSD card. The device has a build-in file browser, which allows to walk around your card and listen to impulse sounds in real time. All impulses are stored on device's internal memory, in a particular preset,  including settings for FX effects. Additionally, the internal memory access can also be made with the help of a PC via USB connection, for preset storage and exchange or loading of software updates.
Every preset has 16 controllers (effect blocks). So you can designate 16 key parameters (loudness, modulation rate, on/off parameters, etc.), which can be configured for any MIDI controller (or for an external expression pedal, for which there is a plug connector). Hence, you have a possibility to control 16 parameters in a single preset in real time.
Modes of IR File Operation:
MODE 1: Loading of one mono IR with with 24 bit х 48 kHz 85.33 ms long (4096 samples) with the total signal delay of 1.5 ms (milliseconds).
MODE 2: Separate loading of two mono IRs with the same parameters as in MODE 1, adjustable for volume and pan with the total signal delay of 1.8 ms.
CP-100FX Internal Effects Blocks:
(TN) Tuner: Integrated chromatic guitar tuner.
(PR) Preamp Simulator: The preamp simulator section of the Pangea lets the user adjust the overall tone stack/gain characteristics of any given patch, just as using a real amplifier. Adjustable 5 parameters are (Low, Mid, High, Gain, and Volume).
(PA) Power Amp Simulator: The power amp simulator section of the Pangea defines what type of amplifier head settings will reflect in the overall tone. Adjustable 4 parameters are (Volume, Presence, Slave, and Type). User is able to choose 6L6 or EL34 tube settings under the Type option.
(EQ) Equilizer: The equilizer block of the Pangea presents the user with a wide range of parameters to dial in the perfect sound. Adjustable parameters are (EQ, HPF, LPF, and Presence). The following break down the controls of each of these parameters.
EQ
- Gain ±15db, 20-220Hz, 1-10
- Gain ±15db, 260-460Hz, 1-10
- Gain ±15db, 600-1000Hz, 1-10
- Gain ±15db, 1000-3000Hz, 1-10
- Gain ±15db, 1000-11000Hz, 1-10
HPF - High pass filter 20 Hz to 1,000 Hz.
LPF - Low pass filter 1,000 Hz to 20,000 Hz.
PRESENCE - Regulates high frequency blend in the mid frequency range.
(DL) Delay: The delay block of the Pangea contains the following adjustable parameters.
MIX - Sets the amount of dry/wet signal passing through the effect.
DELAY TIME -  Sets the time between delay repetitions, ranging anywhere between .01 to 2.73 seconds of delay.
TAP - Defines the multiplier for time tapping when using tap tempo.
DELAY FEEDBACK - Determines how many repetitions of the delay sound will be reproduced.
LPF - Low pass filter passes through frequencies below the cutoff frequency and attenuates everything above.
HPS - High pass filter passes through frequencies above the cutoff frequency and attenuates everything below.
D PAN - L/R panning for first delay line.
D2 PAN - L/R panning for the second delay line. D PAN and D2 PAN can be set to L/R for stereo ping pong effect.
D2 VOLUME - Volume level for the second delay line.
D>D2 - Defines the relative offset of the second delay line from the first delay line.
HPF - High pass filter passes through frequencies above the cutoff frequency and attenuates everything below.
DMOD - Controls the depth of the delay modulation (similar to tape delay modulation).
MRATE - Controls the rate of the delay modulation.
DIRECT - Sets the direction of the delay, forward or reverse.
(PH) Phaser: The phaser block adds lush sounding 2, 4, 6, or 8 stage phase effects to the signal path. Adjustable parameters are as follows.
RATE - Sets the rate of the low frequency oscillator LFO, making the effect slower of faster. Phaser rate range is .048 Hz to 4.85 Hz.
CENTER - Assigns the frequency that the phaser notches will oscillate around.
WIDTH - Controls the amplitude of the LFO, widening or narrowing the effect.
FBACK - Feeding some of the filter's output back into it's input can increase the contrast between the peaks and notches, intensifying the effect.
STAGE - Sets the number of filter stages (2, 4, 6, or 8 stage phasing).
(FL) Flanger: The Flanger effect in the Pangea has the following adjustable parameters.
LFO - Defines the waveform shape of the LFO. This may be set to Triangle or Sine wave.
RATE - Sets the rate of the LFO, making the sweep of the effect slower or faster. Can be adjusted from .024 Hz to 9.6 Hz.
DELAY - Specifies the delay of the second signal path changing the color of the effect.
(CH) Chorus: Four preset styles of chorus are available in the Pangea (Chorus square wave, Stereo Chorus square wave, Multiple Chorus sine wave, and Stereo Multiple Chorus sine wave). Adjustable parameters are as follows.
DELAY - Specifies the delay of the second signal path changing the color of the effect..
TYPE - Sets the type of Chorus applied to the signal chain.
(ER) Early Reflections: This effect blocks emulates room acoustics. Unlike reverb, early reflections are sounds that you hear directly after the direct sound, before the reverb effect is applied.
TYPE - (Small Room mono, Small Room stereo, Medium Room mono, Medium Room stereo, Large Room mono, Large Room stereo).
(RV) Reverb: Adjustable reverb parameters are as follows.
TIME - Controls the decay time, how long the reverb trail will sound.
SIZE - Sets the size of the reverb room being applied.
DAMP - Shortens the higher frequencies in the reverb signal, simulating warmer smoother reverb enviornments.
DETUNE - The amount of pitch modulation for the processed signal.
(TR) Tremolo: Tremolo is an amplitude modulation effect controlled by a low frequency oscillator LFO, creating a pulsing/vibrating effect. Adjustable parameters are as follows.
INTENS - Sets the intensity of the tremolo effect. When set to maximum, the sound completely fades out between pulses.
RATE - Sets the rate of the LFO, making the effect slower of faster. Range of rate is .048 Hz to 14.5 Hz. Tap Tremolo can also be used in this setting.
LFODIST - Allows user to choose between Sin
(RF) Resonance Filter: The resonance filter is designed to cut certain frequency ranges out of your guitar tone, similar to how wah-wah pedals function. This block contains the following adjustable parameters.
FTYPE - Filter type (LPF, HPF, BPF).
FMOD - Selects one of the following ways to control the cutoff frequency (LFO low frequency oscillator, DYN varies upon input signal, EXT expression pedal).
LOFREQ - Sets the lower limits for frequency cutoff, ranging from 26 Hz to 560 Hz.
HIFREQ - Sets the upper limit for frequency cutoff, ranging from 560 Hz to 6545 Hz.
RES - Sets the resonance of the effect, saturation time..
DYNTH - Threshold sensitivity of the input signal.
DYNATT - Assigns the attack time.
DYNREL - Assigns the release time.
VOLUME - Sometimes high resonance values can boost the signal too much causing unwanted distortion. This parameter is used to balance the volume of the effect block.
(GT) Noise Gate: The Pangea also includes a noise gate; which greatly helps reduce noise, hiss, and hum under certain overloaded signal conditions.
THRESH - Sets the threshold of the noise gate.
ATTACK - Determines how fast the gate opens.
DECAY - Determines how fast the gate closes.
(CM) Compressor: Compressors reduce the loud volume of sounds and amplifies quiet sounds, smoothening the dynamics of the overall signal. It can also be used as a sustainer, making your notes sound longer.
THRESH - Signals above the set threshold level gets compressed and the overall signal is amplified.
RATIO - Sets the compression ratio, ranging from 2:1 to 24:1.
VOLUME - Sets the output volume of the compressor effect block.
ATTACK - Determines how fast the compressor will react after the signal gets louder than the threshold, ranging from 5 ms to 30 ms.
KNEE - Smoothes the compression gradually applying the ratio. Softer knww reduces the audible difference between uncompressed and compressed sound.
Specifications:
- A/D – D/A converters 24 bit
- Sampling frequency 48 kHz
- DSP block ADSP-21489 processor
- Concurrent effects 10
- Preset memory 99 user presets
- Input AC mains 100-265VAC, 50-60 Hz, output 12VDC (minus – center)
- Consumption current 230mA
Contents:
0:59 AMT Pangaea CP-100FX Online
1:36 Unboxing
3:21 Weight & Size
3:36 Disassembly
4:32 Latency test/Science sh**
5:56 Update/Backup/Restore
7:35 Navigation/Menus/Effects
12:31 Controlling the Pangaea
14:32 Sound Test
30:18 Inputs and Outputs
32:39 Shootout: IR vs real cab
36:02 Summary
lumena
You, Mr. Sustainiac are an enabler.
Cool box looks like a very nice one. AMT preamps have always been good - this looks great for the price.
I like that there was a cat in the demo, cats improve the sound of all demos.
(It is known)
Quote from:  lumena on June 02, 2017, 12:32:24 PM
and home breaker/ loss leader for a few here if GAS is not kept in check ;0
just remember to re-sell the old gear to fund the new
Steve, sounds like you should practice what you preach LOL ;D
vtgearhead
I'm glad to know I'm not the only person on the forum who continually accumulates gear and never seems to have any going in the other direction...
JiveTurkey
Waiting for my replacement unit right now. That little glitch aside; this box is a great match for the GR guitar tones. Or just about any preamp pedal you will throw at it for trad guitar tones.
vtgearhead
I just picked up one of these from a seller on TGP.  Will post my impressions after I've had a chance to play with it.
FIRMWARE
http://media.amtelectronics.com/download-the-latest-firmwire-for-amt-pangaea-cp-100fx/
get the free IR Cab Pack
http://amtelectronics.com/new/product/amt-truecab-ir-ma-1960a/
AMT Electronics TrueCab IR - Impulse Response Library
Dear friends, AMT Electronics team is happy to announce breaking news!
Our first five Impulse Response (IR) packs are finally released. Developed by our engineers this library perfectly complements AMT PANGAEA CP-100 and AMT PANGAEA CP-100FX.
Download a FREE demo IR pack right now.
Worldwide sales: http://amtelectronics.com/new/shop/
http://eshop.amtelectronics.com/index.php?dispatch=news.view&news_id=42
http://amtelectronics.com/new/big-truecab-update/
Majiken
Is this a poor man's Kemper?? Looks like (acoustic) instrument IRs can be loaded too, eh? That would take away my 13-pin need....  Steve, Snhirsch, what's the word, you gents seem to like it?
Trying to ring out old gear to be able to ring in some new, darn this forum  :P
www.majiken.rocks
Majiken
www.majiken.rocks
vtgearhead
Not a poor man's Kemper, but perhaps closer to an Atomic Amplifire.  It doesn't have built-in high gain overdrive capability, but if you provide crunch from an external pedal or amp it can round out the sound quite nicely. I have mine in the effects loop of a Katana 100w combo and use the built in IR player, echo and chorus.  MIDI control capability (as client or controller) is comprehensive and flexible.  Documentation is terse, but complete and useful.
My only complaint is that it really needs a PC based editor.  The control arrangement is not too bad, but when trying to juggle a bunch of patches I like a good view of what goes on in each of them without the need for menu diving.
Majiken
www.majiken.rocks
JiveTurkey
Quote from: snhirsch on July 19, 2017, 06:54:16 PM
I wish they would have incorporated a few of their preamps into this box. There is a preamp block, but it offers basic eq with no real gaining possibilities. I can see an editor being useful yet I actually liked the UI on device and didn't feel like it was lacking in that regard.
I sold mine and got a Kemper instead; so my Kemper was an AMT replacement  ;D FWIW; the acoustic presets that shipped with the AMT were pretty solid. Coming from someone who doesn't own an acoustic, at least.
vtgearhead
Quote from: JiveTurkey on July 20, 2017, 05:13:50 AM
In my secret identity as 'vtgearhead', I was the purchaser of your unit :-).  The IR player really adds a nice feel to the sound of my Katana combo.  The engineer in me was concerned about heaping a guitar speaker IR on top of another guitar speaker, but I really like the result.  IRs are specific to one drive level and the ones I settled on represent conditions I would never drive my Katana speaker to during performance.  So, it's a way to get that inimitable Marshall 4x12 (sealed cabinet) "thump" at modest overall SPL.
JiveTurkey
Quote from: snhirsch on July 20, 2017, 09:52:26 AM
I wondered  ;D Not too many out in the wilds as of yet. Glad to see you have it dialed in! The Katana is already great on it's own so it's probably just a case of giving that extra bit of polish to the proceedings!
Should I create a AMT PANGEA CP-100FX patch sharing area?
JiveTurkey
gtlist
so, NUX Cerberus and AMT PANGEA CP-100FX are  seems like new competitor. For me, I use Roland Gp-10 directly connect to the main mixer. sound pretty good but amp and cab of gp-10 is not that impressive. I know fractal and kemper. just exceed my budget. so these guys are pretty interesting. I hope someone compare these two.
Fender Stratocaster American Deluxe hss with gk3.Tom Anderson Atom wraparound bridge.
Tom Anderson Crowdster plus+ with gk3.
Steinberger GTPro hsh with sustainer pu and Gk3
Taylor 814CE,   Taylor GS Mini, Epiphone masterbilt dr500mce, martin xt1
Roland Gp-10, voicelive 3, Boss Sy-1000
vtgearhead
I'm reasonably happy with the CP-100FX, but growing disenchanted with AMT themselves.  All my e-mail to them is ignored and after almost two months of repeated tries at registration I've given up on access to their forums.
The Russia folks are responsive -
try these
support @ amtelectronics.com
webmaster @ amtelectronics.com
but they refer to the sluggish USA sales office
QuoteWe do not sell our products in USA directly
We have a partner www.amtelectronicsusa.com
So please address them
Best Regards,
Alexander Korotaev
AMT Electronics//Tech Support
