Coherent Sound = CSL Sophia Tremolos
Started by admin, April 22, 2016, 12:54:57 PM
Coherent   Sound    In   Light   –   CSL-Sophia.com   –   in   association   with   Ping   Well    Industrial   Co.,   Ltd.–   is   a
startup   company   dedicated   to   advanced   integrated   tremolo   systems   and   tremolo   stabilizing   systems
dimensioned   as   drop-in   fit   for   vintage   tremolos.
Connect   with   CSL –   NAMM   2016   Hall   E,   Booth   1152:
info@CSL-Sophia.com
https://www.facebook.com/Coherent-Sound-In-Light-Sophia-tremolos-1205479142826516/
Ping-Well.com
CSL-SOPHIA   TREMOLOS   AND   GLOBAL   TUNERS
[US   PATENTS   AND   PATENTS   PENDING]
CSL-Sophia   2:22   and   CSL-Sophia   2:92    standardized   14"    radius    [2.11    string    spacing]   base
plates   offer   a   universal   platform    to   mix-and   match    tuned    tremolo   elements    to   bring   out    the   best   in
your   instrument   and   remain   simple   to   use   [one   2mm   wrench   for   common   adjustments]:
CSL-Sophia   2:92
https://www.namm.org/sites/www.namm.org/files_public/mediakit/WN16/CSL-Sophia%20Media%20kit_0.pdf
! No longer available
Just a note to say thank you again! The response has been overwhelming, over 40k Youtube visits [] -- send inquiries and order to info@csl-sophia.com, hopefully we can get back to you shortly with a basic website and can begin to fill the first orders next month ....
merkaba22
http://cslsophia.com/csl-sophia-tremolo
The CSL Sophia Tremolos are now in production since late 2016 in association with world class tuning peg specialist Ping Well Industries [see Grover Rotomatic] to provide premium no-holds barred Sophia Tremolos and accessories including the Global Tuner and Global Tuner Pro lines [OFR and Ibanez compatable] The CSL HeadPeace Mini, CSL Headpiece, locking riser posts and copper coated lo-noise spring and claw.  Gibson surface mount Sophia 3:22 tremolo in 2018.
The Sophia is the first major upgrade in fulcrum tremolos since the introduction of the OFR and the Fender Two-point tremolos in the early 80's meeting or exceeding the specs of the original with an exceptional feature set and form factor.
       CSL Premium Tremolos:
From world-class Luthier, Gene Baker -- B3/Roscoe Guitars [Senior Master Builder for the Fender Custom Shop '93-'99] on his Charvel equipped CSL Sophia 2:92 Pro with the Global Tuner Pro with Dual Stabilizers:
"Playing performance it feels great, smooth, stays in tune ... Really like the sleek look and no rough or bulky edges to it.... As far as the dual stabilizer goes, it works and helps eliminate palm pressure to maintain pitch and pulls backwards nicely....  easy to feel and hear once the pistons come in contact with the body, there's an added tone transference throughout ..."
          1)       The Pro series, available in both the Deluxe and Macro-tuner versions, feature the Global Tuner Pro with Dual Stabilizers — this system offers the most stable / tonally enhancing [drop-in no mod's required] high performance floating tremolo available today.  The Global Tuner Pro includes the well-respected bell brass spring block for OFRs — CSL adds in Stainless steel to further the improvement — the thumbwheel adjusts spring tension on the fly.
           2)      The Sophia 2:92 Pro Fall 2017 US models includes an extended 6th string slot
           3)      There is  increased mechanical/acoustic response assisted by the extra contact of the dual stabilizer pins. These contacts provides easily perceivable enhanced dynamics and sensitivity to any  experience player.
           4)       Both the Deluxe bridge elements and Macro-tuners feature the dual loading / locking feature for exceptional stability and flexibility.  up to .054 through the Tuner Knob and .075 with the plain end through the nose slot.
           5)       The 2017 headless capable macro-tuners feature 60:1 ratio tuners for a higher level of tuning accuracy and ease of use.
           6)         The CSL HeadPeace Mini fits the standard OFR locking shelf dimensions for simple setup and conversions — dual loading.
           7)        The Drop Tuner is supported by the Dual Stabilizers to maintain the overall tuning of the tremolo to within a few cents [depending on settings] in both tunings.
           8 )          The Global Tuner Pro line is sold sperately retro-fits OFR and Ibanez ....
Accordingly, we, at CSL, think this makes the Sophia Pro
  • second to none.....  It's not just the only system for a floating tremolo that remains believable and stable under extreme whammy use, it makes your instrument sound better —
    www.cslsophia.com
merkaba22
merkaba22
CSL Sophia 2:22 Deluxe for vintage two-point specs ...
Three springblock upgrades include a larger brass model with a built-in TremStop, the Global Tuner and the Global Tuner Pro featuring Dual Stabilizers ....
cags12
This is great - this is the type of Trem Block I was wishing it existed.
Everyday I discover new cool stuffs.
