FTP - Volume fading out.
Started by melodymann, June 07, 2013, 12:26:40 PM
melodymann
Hey Guys,
Just got my FTP through the group buy (thanks Elantric!) I have tons of bugs to work out but
something seems wrong. If I turn the volume on the unit all the way up it begins a long fade
out to nothing. Turning it down, then up, starts the long fade again! In fact even tapping the
knob brings it back, only to fade(ever so slowly) out again. If I back off on the volume just
slightly it seems ok. This can't be normal. Is anyone else having this problem?
Terry
Sounds like a problem. ( I have two FTP's and neither acts like that, nor have I ever experienced that type behavior)
I assume you are using the applications and FTP GUI Control panel?
I advise contact Fishman Customer support asap.
it might be related to the variable assembly quality of the FTP Controller.
When I got my first FTP last March, nothing worked until I removed and then re-installed the FTP Controller plastic cover
Details here:
* Check for Stuck Button and controls on your FTP Controller
https://www.vguitarforums.com/smf/index.php?topic=8400.msg60844#msg60844
