FTP - Show us your Triple Play Guitars
Started by merman93, April 20, 2013, 12:18:34 PM
merman93
New category needed for pics of FTP equipped guitars?
Here is my Ibanez RG 1550m with FTP installed.
Ibanez RG 1520 GK
Ibanez RG 420 GK
Ibanez RG 920 (GK KIT)
Ibanez RGA 121 (GK 3)
Roland GC 1/G 505/G 707
Hamer Phantom A7 (24 pin)
BX 13 (24 -13 pin converter)
GP-10
FishmanTripleplay (2)
VG 88 2.0
Apple Imac/Logic 9
MOTU Utralite 3
Kemper (2)
Gemini 2 Active FRFR
There is a similar thread over here
https://www.vguitarforums.com/smf/index.php?topic=33155.0
But I admit telling folks to:
"Go to FutureGuitarNow.com for all the  latest news, tips and advice for your TriplePlay Info!"
is like herding cats. ;)
Suggest book mark this
https://www.vguitarforums.com/smf/index.php?board=458.0
But actually - thanks Merman!
Here is my FTP (at this hour!).
Its currently on a Godin xTSA - had to relocate the bridge PU to make more room for the FTP PU.
How to install Tripleplay on Godin xTSA
1) Unscrew all 4 mounting screws for the stock xTSA Bridge PU
2) Slide the stock xTSA Bridge PU 1/4" towards the Neck - to make room for the FTP PU.
3) Use clear Packing Tape and tape down the stock xTSA Bridge PU
4) Now that there is room, Mount the FTP PU and Controller.
ShawnB's Gibson SG with Tripleplay & GK-3
ShawnB has the most interesting install to date!
It also serves as a good visual reference for comparing the size of the FTP Controller vs the GK-3.
Also observe the small plastic piece ShawnB fabricated to mount the hex PU's on  - this type "plastic bit" may be required as a "Mounting Shim" on some guitars to create a flat surface to mount the FTP PU.
When the FTP PU straddles half way between your pickguard and half the Guitar's wood body, it may be too wobbly to be properly supported and stay in position.
There seems to be a perfect match of FTP mounted on JTV-69
Burr Johnson Signature
Zummooz at FGN
https://www.vguitarforums.com/smf/index.php?topic=33229.msg246216#msg246216
TPguitarman
My Peavey AT200 autotune guitar with Fishman TriplePlay installed
merman93
Nice Peavey TPguitarman !!! That is a perfect install.
Ibanez RG 1520 GK
Ibanez RG 420 GK
GP-10
VG 88 2.0
Apple Imac/Logic 9
MOTU Utralite 3
Kemper (2)
kenact
I'm still waiting for the Godin Session Custom TriplePlay to ship.  :(
Danoblaster Baritone w/GK-3
Gretsch Nashville, Viking
Fender Strats
Fret King Supermatic
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
TPguitarman
Quote from: merman93 on May 05, 2013, 12:22:38 PM
Thank you merman93 for the compliment.... :)
TPguitarman
Also Thank you Elantric for the FTP Group Buy... :)
USpirit
sorry if this has been answered but a quick search did not show, can the ftp be fitted to an acoustic guitar?
I assume it can - use steel strings will help too
But dont complain that you still hear your standard tuned regular guitar strings when applying Alt Tunings to the FTP Synths ;)
USpirit
#9
thanks for the answer.
I would never complain about that ;)
I use gk3 and vg-99 with acoustic now and was wanting to do something similar, pads washes etc.
I have yet to hear from anyone who actually has installed ftp on steel string acoustic so was wanting to hear if anyone actually had before committing to buying one.
and sorry if this has turned into a bit of a thread hijack but it is sort of related :)
thebrushwithin
@uspirit....it should work, but the problem to overcome will probably be thr height of the pickup, fitting under the strings. It was for me.
merman93
#11
A more detailed pic of the FTP Install on my Ibanez Prestige RG 1550,( left),  and my Ibanez Prestige RGA 121. Due to installation clearance issues, My luthier is fabricating a combo mount and bridge pickup surround for my Les Paul. When completed I will post pics.
I removed a GK 3 from the RGA 121 above, you can see the mount holes. Lots of mounting space on this one.
Actually just enough width clearance on the RG 1550 for the FTP. On both of these high end Ibanez guitars the bridge radius is not adjustable, it matches the fretboard radius of 430 mm. The action can raise or lower, but the radius is constant. When the hex mags are at the minimal distance from the D and G strings, the distance from both E strings is still well within tolerance, and raising the sensitivity slightly evens it all out, but an adjustable radius hex pickup, like the trusty GK 3, would be a welcome update on the next gen Triple Play.
BTW, My luthier shimmed the neck on a stock Strat at his shop to see how it felt, providing the clearance necessary for an FTP install on most Strats. It may not bother anybody else, but it didnt feel right for me, so I'm having the pickguard routed on my Andy Timmons Signature model for the FTP mount to install flush , providing the needed clearance without changing neck angle. This will work on most Strat type guitars with height clearance issues.
Ibanez RG 1520 GK
Ibanez RG 420 GK
GP-10
VG 88 2.0
Apple Imac/Logic 9
MOTU Utralite 3
Kemper (2)
baatkarlo
#12
My Steinberger Transcale Synapse with TriplePlay.
Eat sleep get up play. Eat sleep get up play. Eat sleep get up play.
HarrySound
merman93
Quote from: baatkarlo on June 19, 2013, 05:32:24 PM
Beautiful Steinberger !!! I see there isn't much room for the controller. How is the overall system?
Ibanez RG 1520 GK
Ibanez RG 420 GK
GP-10
VG 88 2.0
Apple Imac/Logic 9
MOTU Utralite 3
Kemper (2)
Spider
Schecter Omen 6 (with custom wiring and PU) aka "Triple on one"
Spider
Quote from: whippinpost91850 on July 21, 2013, 01:28:35 PM
Spider, Very nice !!!
Thanks. From more then 2 months it is most used guitar at home. This is dangerous because could cause question like "why you don't use this and this and this guitar? what for do you have it? :P
superawesomegreat
(hopefully I understand how to post pics here)
The stickiness of the pickup mounting pads was no match for my textured pickguard.  Luckily, one of the tune-o-matic brackets [barely] fit the posts of my VM Jag's bridge, and didn't require me to raise it, taboot.
superawesomegreat
Derfc
superawesomegreat
Derfc, are those atari invaders waterslides or stickers?  I need something like that to cover up some dings and dents on an offwhite tele body and it's already got this sticker on it...
Derfc
Quote from: superawesomegreat on September 12, 2013, 09:20:07 PM
Neither, actually.  They're vinyl clings sold as 'drink markers' that I found on clearance at Target.  I threw them on the guitar for the heck of it, but they've stayed in place just fine through a couple of gigs already.
Looks like Amazon sells 'em for less than $5:
http://www.amazon.com/Kikkerland-Drink-Markers-Set-6/dp/B007IA2T68
superawesomegreat
Quote from: Derfc on September 16, 2013, 05:41:21 AM
Thank you, Derfc.  Trigger pulled.
Meanwhile, in the 24th century...
