READ FIRST - VG-99 Patch Submission Format+How to SAVE and LOAD PATCHES!
Started by Elantric, January 23, 2008, 09:21:52 PM
The *.MID files here in the VG-99 and VB-99 patch areas are NOT MIDI files.
These files do not "play" MIDI tunes in a media player.
Rather these  *.MID files are VG-99 and VB-99 patches in SMF format which must be used with the appropriate  Roland VG-99 or VB-99 Editor application to load into your target Roland Processor.
VG-99 PATCH SUBMISSION FORMAT.
SAVE ALL YOUR CURRENT PATCHES PRIOR TO USING OTHER PEOPLES VG-99  PATCHES!
When sharing VG-99 Patches with others, there are known issues and hurdles.  The Native VG-99 Editor Patch File format  is the ( *.g9e) file format.
The problem is these patch files have embedded ALL User System configuration settings - (GK Sensitivity, MIDI Channels,  USB audio I / O routing, etc) which tend to clobber the casual user's VG-99 System settings in a negative manner. Hours can be wasted trying  to debug "what broke - all I did was load a VG-99  Patch I found on the net" and I lost all my settings !; ("
Instead - we use the VG-99 Editor's SMF Export / Import function  - and save Only the PATCH data and share these as "*.mid"  SMF MIDI files.
Develop your patch with the Roland VG-99 Editor, and then  save it using the File, Export to SMF, and select PATCH info only. ( Not PATCH+SYSTEM!)
Selecting PATCH keeps other folks getting clobbered with all your System settings.
Enter a Name for your Patch in the message box  - like "Rock12.mid"
Please submit Patches here and state the details.
example
PATCH NAME: Surf Verb Strat
Version: 1.00
Category: Clean
Style: Rock
Description: Clean Neck+Middle PU Strat, thru Twin with Spring Reverb, good for surf!
FileType: mid
Keywords: So others can locate your patch, enter typical search words separated by a comma -  like this:
Adrian, Belew, Big, Electric, Cat, Foxxtone
To Load patches you find here , From the VG-99 Editor use the Import SMF Command: Reads files saved on the computer in SMF format (.mid).
Also be aware I have seen many Macs with Safari  - that will throw all downloaded *.mid files into the Itunes folder - ( OSX thinks these are MIDI Music files) - in general they tend to get lost in the abyss of the OSX hard drive. - and never found again - so pay attention to where you are downloading these - use Firefox Browser and gain more control on where your downloads go on your hard drive.
We are gathering info to create FAQS for performing VG-99 Full Backup / Restore, and a separate FAQ for how to use the VG-99 Librarian.
Fastest way to Learn - Watch this Video
How to use VG-99 Librarian to back up everything!
https://www.vguitarforums.com/smf/index.php?topic=34.0
Jemuso
Hello I´m new in VG 99 forums. Anyone can to orient me how load the patches in Midi i found in this page to my VG 99? I need a text or tutorial that explain me how do it. Also I need know how update the Vg 99. Where are the updates and how do it. If anyone can help me i will be been very thankfull.
I´m from spain. Sorry my bad English.
bob e
Welcome to the group Jemuso!  :)
Check out the tutorial section, some very useful info there.
Don Juan de Marco
Hi and welcome... I hope this one can help... it's  a step by step on how to load files on your VG-99... Take your time and good luck...
http://video.google.com/googleplayer.swf?docId=-7922146080592545276
Quote from: Don Juan de Marco on December 18, 2009, 08:21:53 AM
Some of the information in this video is inaccurate. You may want to read Reply #1 to this topic. https://www.vguitarforums.com/smf/index.php/topic,1071.0.html
How to Load SMF User patches into your VG-99
*** Your VG-99 Device ID has to be set to 1, if it is set to anything else your VG will ignore the patches from this site.
1) Browse the VG-99 Patch area, select and download a patch.
For example -  here is "Norwegian Wood".
https://www.vguitarforums.com/smf/index.php?topic=224.msg687#msg687
2) Right Click on the file "norwegian wood.mid" and save it to a suitable folder on your PC. I have my own specific folder for all my VG-99 Docs and patches.
3) Now connect your VG-99 to your PC via USB cable and launch the VG-99 Editor.
4) Select "Import SMF"
5) From the message box, navigate to the folder where you saved "norwegian wood.mid"
6) Double click the file "norwegian wood.mid", and it will load into the VG-99 Editor and into the VG-99.
gclev
I searched around but couldn't find an answer so thought I'd post here for other's future reference.
Is there there any way to load multiple patches into the vg-99 either through the editor or library instead of just individually into the editor?
In other words, say I want to load 100 patches I downloaded here, is the only way to do that to import one SMF file at a time into the editor and then export them into the vg-99?
Is there a way to drag and drop those 100 files so they'll be quickly uploaded?
Thanks!
Download the Detailed Instructions on how to Use the VG-99 Librarian  - see attached PDF files below (PC/ Mac)
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=51.0;attach=22
https://www.vguitarforums.com/smf/index.php?topic=51.msg5468#msg5468
Brent Flash wrote>
Subject: Using the Editor and Librarian
Here is how it works. The Editor and the Librarian both make .mid files but they are not interchangeable. If you make it in the Editor it will only open in the Editor. Same with the Librarian.
So, the way I do it is make all my patches in the Editor. File/Export SMF/Patch. I have each patch saved from the editor in a folder.
It is also a good idea to do your system just in case you accidentally overwrite it with a patch someone else made that includes the system. That way you can just load it back with File/Import SMF...
Once you have a bunch of patches to get started do File/Import SMF... and WRITE the patches in the positions you want them in with the Editor. I know the Librarian is what you are suppose to do this with but it is easier this way. (IMHO) Use the Librarian for changing the whole USER BANK.
Once you have a USER BANK basically set up then you can start using the Librarian. What you do is open it up and click on READ ALL at the top of the window in Patch mode. (WARNING, THIS WILL TAKE A WHILE) Then you will do: File/Export SMF/All Data
Save this indicating in the name that it is Patch data because even thought it says All Data it is only all the data in that mode.
Then switch the mode to System and repeat the process for the System data.
Then switch the mode to GK Settings and repeat.
Then Favorite Settings and save making sure you indicate in the name what kind of data it is.
Once you have done this you are now ready to create a file that contains all of this data. (This is what is so weird about this program. It has two levels that work separate from each other.)
Go to File/Duplicate. This will make a file in the other section of the Librarian. This file you can save and open but it does not load into the Main Librarian window so this is what is a little weird. Go to File/Save As and name it maybe with a date so you can keep track of updates and maybe have more than one file for backup.
Anyway now we have two windows with the same data. The Main window and the one you created with the duplicate command we will call the file window. Both windows can read and write to the VG-99. The Main window can do ALL or Selected but the file window can only do patches one at a time and can't write system, GK, etc.
Pretty straight forward until you go to use the Librarian again. The next time you open the Librarian it will open the Main window with nothing in it. You can open your file and use it to rearrange patches one at a time but if you want to read or write a bunch at once you need them in the Main window. So you have three choices.
1. You can read the entire memory of the VG-99 again. (Don't do this it takes too long unless the VG has totally different patches from the ones you saved.
2. You can copy and paste them from the file window or...
(Here is a good place to put a note about copy and paste. There is an added feature that can give you grief if you don't pay attention to how it works. Under Edit you have Cut, Copy, Insert, Replace, Delete, Exchange. If you do the regular CONTROL V or Command V key stroke for paste you will insert the patch and move all the following patches down a number so you normally would want to replace and the key shortcut is CONTROL R on PC or COMMAND R on the Mac.)
3. You can go to File/Import SMF/All Data
What I do is import the All data file we created in the Main window with the File/Export SMF/All Data. This saves me from having to read the whole VG-99 memory each time I use the Librarian or copying and pasting from the File window.
When ever I am editing patches in the Editor I always have the librarian open and make changes to my working banks as I go remembering to export the Main window in the Librarian anytime I make changes and saving the file window when changes are made there.
At this point you may ask yourself why use the Librarian at all. Well, I would not except for that in my case I do need to replace the entire memory of the VG depending on what group or performer I am playing with. Some groups do the same songs but in different keys so I have transposed patches that allow me to play in the original key even though they perform it in another. Also I usually have an order that I can keep track of where my patches are with the group I am playing with so in my case it is of some use even though it is a major pain.
I hope this information will take some of the mystery out of these tools for some of you. I know when I first started with them it was trial and error the manuals were not much help.
This document "INFOCUS02.pdf" is a "MUST READ" for all GR-55  / VG-99 owners, it walks you through how to use the  Roland Librarian.
http://www.roland.co.uk/assets/media/pdf/INFOCUS02.pdf
gclev
Thanks adm.
I had read Brent's useful post about using the editor and librarian. One of the first things I did when I got my vg99 (3 days ago) was to use his procedure to back up my patches.
Playing around with loading new patches got me wondering if there was an easier way to load multiple patches at a time.
I guess not.
pinkfrued
I have a b9l bulk patch file. I opened it in Librarian with the intention to export each patch as it's own .mid file. The Import and Export SMF areas are greyed out for some reason. Any idea what I'm missing? It will not open in Editor. Thanks!
*.B9L file can only be used with a VB-99 and not compatible with VG-99
