GR-20 and midi-out to computer VST Instruments
Started by zap514, January 02, 2012, 04:57:53 AM
zap514
Hey Everyone!
I'm so happy I found this forum, just got my GR-20 a couple of days ago and have played around with it for a while with both the built in sounds and some computer VST's.
everything works great except ONE thing. it seems that all my plugins that use the Kontakt player only track the high E-string. If I look at the virtual keys on the plugin all keys get pushed down
regardless of what strings I'm playing but only the high E-string actually triggers the sound. Does anyone here know how to solve this? all other regular VST-plugins that I have tried have had no problems what so ever.
Any ideas?
Sedgewick
Zap:
The GR-20 has two different MIDI output modes ( Mono and Poly ).  In one of them, everything is output through one MIDI channel, in the other each string is output through it's own channel.  Your software is likely set to read the channel from one string. Change the MIDI mode on the GR-20, and you should get the rest of the string signals.  See pages 28 & 29 in the user manual for how to switch modes.
