13 pin DIN Chassis Mount jacks for internal GK pickup installations
Started by Elantric, October 28, 2011, 03:05:56 PM
13 pin jacks for internal GK pickups installations
This one is unique and might be easier for many installers:
http://www.packetradio.com/catalog/index.php?main_page=product_info&products_id=706
BUXCOMM  13PDCMJ
13 Pin Din, Chassi-Mounted Jack
13 Pin Female with Solder pins
cat#  13PDCMJ   $15.95
Chassi-Mounted, 13 Pin Female with Solder pins
BUXCOMM 13PDCMJ is a special made,
13 Pin Din, Chassi-Mounted Jack (female) with Solder pins.
http://www.adam-tech.com/catalog/2012/page_229-239.pdf
http://www.ebay.com/itm/13-PIN-DIN-FEMALE-CHASSIS-PANEL-MOUNT-CONNECTOR-ATARI-KENWOOD-ROLAND-/390671564763?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item5af5d6ffdb
paults
Yes, easier than the Digi-Key version, and easier than the Roland version, because it requires a mounting plate.  I've used that style for MIDI connectors before.  One round hole, two little pilot holes for the screws.  The metal is relatively soft, so don't lean on the screw hole surrounds too much when you tighten the jack into place.
