GR-55 "Sounds of the Heroes" - soundsderhelden "Legends of Rock" GR-55 patches
Started by Elantric, June 10, 2011, 02:19:52 AM
Patch Description in PDF here
https://www.vguitarforums.com/smf/index.php?action=dlattach;attach=10199
http://www.rolandmusik.de/produkte/GR-55/index.php#anchor
http://www.soundsderhelden.de/download/GR55.SVD
Details and Patch List
http://www.soundsderhelden.de/download/GR-55-Sound-Anleitung.pdf
ROLAND GR-55 sounds of Heroes
To transmit the sounds of the heroes (SDH) for the GR-55 you need a USB stick that works well with the GR-55.
Please insert the USB stick only remove or, if the GR-55 is off - this is the security for the data on the
USB stick contained data.
First, the user's own data are secured GR-55. The next step is that file on your computer
saved and replaced by the SDH file. The GR-55 maintains a backup file named "GR-55.SVD.
First Backup your own patches and settings in the GR-55 data stored on the USB stick
  1. USB stick into the side door of the plug is switched GR-55.
  2. Turn GR-55.
  3. [EDIT] key.
  4. Select with the [PAGE </>] the SYSTEM area of the GR-55
  5. Select with the [CURSOR </>] the menu "Backup / INIT", then press [ENTER].
  6. Select with the [CURSOR </>] menu "BACKUP / RESTORE", press [ENTER].
  7. The "BACKUP"menu and press [ENTER].
  8. The question appearing on the "OK"with [ENTER].
Now, the GR-55 requires about 20 seconds to create the backup file on the USB stick. Appears shortly after the end
"COMPLETE" on the display and the "BACKUP / RESTORE" menu appears again. Switch the GR-55, and remove the USB stick.
Exchange of user data from a USB stick to the SDH file
  1. Connect the USB flash drive of your computer.
  2. Let you view the contents of the USB stick.
  3. Open the "ROLAND" folder, and includes a "Sound" folder.
  4. Copy the file "GR55.SVD" and save to your computer.
  5. Replace the "GR55.SVD" file on the USB stick with the "GR55.SVD"from the "Sounds of Heroes" website.
WARNING: This file may NOT be renamed, as the GR-55 you do not use more then!
  6. Register your USB stick from your computer.
Load  the Sounds of the Heroes file to the GR-55
  1. USB flash drive in the off GR-55 plug.
  2. Turn GR-55.
  3. [EDIT] key.
  4. Select with the [PAGE </>] the SYSTEM area of the GR-55.
  7. The "RESTORE"menu and press [ENTER].
Now required to load the GR-55 about 20 seconds to the backup file on the USB stick. After finishing "PLEASE RESTART" in
Display. Switch the GR-55, and if necessary remove the USB stick.
If you're the GR-55 then turn it on again, then (Press USER button) you'll see the "Sounds of the heroes"for guitar in the field USER
in the squares to 01-1 14-1 (GR-55 GUITAR MODE), or the "Sounds of Heroes" for bass in the squares 01-1 to 05-1 (GR-55
BASS MODE) - see table below.
Sounds of the heroes of guitar or bass
Both the guitar and the bass sounds are in a "GR55.SVD saved. Depending on whether you the GR-55 guitar or
Bass-mode star test, appear the 40 guitar sounds or the 13 bass sounds. As between you and BASS GUITAR MODE MODE
switch, described in the user guide on page 9.
... NOW AND ENJOY THE SOUNDS OF THE HEROES OF THE GR-55!
Make sure you Backup your GR-55 to USB memory stick and store the Backup file (which will have the same name as Gundy's package file) in a safe place, as this will be your entire GR-55 backed up.
Loading Gundy's file will overwrite the entire GR-55, including the System/Global settings, so your GR-55 will be a clone of Gundy's, including the GK P.U. settings.
I might suggest saving the new patches with the Librarian or Editor as patch files, and re-loading your own backup, and loading in the new patches with your own setup & GK settings.
Then some kind soul could possibly save each of the 53 patches From Sounds of the Heroes as individual G5L files and upload them into our patch area.
I'd be seriously curious about the settings on the Santana patch.  Is there any way of extracting the specifics?
Jim Williams
I am uploading the patches in g5l format right now. They are as good as any user patches though.
Skype: (upon Request)
Here is a bit more detail,
I have extracted the guitar mode and bass mode patch sets, as attached below at the bottom of this post.
Also the System settings Gundy appears to have used with this set, which are resonably near factory default.
ROLAND GR-55 System/Global Summary Sat 11. Jun 19:51:49 2011
[Current Patch] = User 05:1
**********System and Midi settings**********
[GK Set] = GK User 2
[Output Select] = Line/Phones
[Assign Hold] = On
[Midi Channel] = 1
[PC RX Switch] = On
[PC TX Switch] = On
[V-Link TX Channel] = 16
[Guitar Midi Out] = Off
[Midi Out Mode] = Mono
[Chromatic] = Off
[String channel] = 1
[Data Thin] = Off
[CTL PDL cc#] = CC#01 Midi Controller
[EXP PDL cc#] = CC#11 Midi Controller
[EXP PDL Bend] = 0
[GK Vol cc#] = Off
[GK S1 cc#] = Off
[GK S2 cc#] = Off
[Midi Map] = Fixed
[Monitor Direct] = On
[Guitar Out Source] = Patch
[Master Tune] = 440Hz
[Tuner Mute] = On
[Test] = Off
[Guitar/Bass Mode Startup Mode] = Guitar Mode
[Player Level] = 100
[USB Input] = 100
[USB Output] = 100
**********System Pedal and GK control**********
[CTL: Pedal Function] = Patch setting
[EXP: Function] = Patch setting
[EXP ON: Switch Function] = Patch setting
[EXP SW: Switch Function] = Patch setting
[GK VOLUME: Function] = Patch Volume
[GK S1: Switch Function] = Bank number dec
[GK S2: Switch Function] = Bank number inc
[EXP Modulation control Mod min] = 0
[EXP Modulation control Mod max] = 100
[EXP ON Modulation control Mod min] = 0
[EXP ON Modulation control Mod max] = 100
[VOL Modulation control Mod min] = 0
[VOL Modulation control Mod max] = 100
**********Guitar Mode set 2**********
[name] =
[Hex PU Type] = GK-3
[Scale] = 10
[PU Phase] = Normal
[PU Direction] = Normal
[S1/S2 Position] = Normal
[Normal PU Gain] = 0 dB
[Piezo Low] = 0 dB
[Piezo High] = 0 dB
[String Distance PU Bridge 1st String] = 20.0
[String Distance 2nd String] = 20.0
[String Distance 3rd String] = 20.0
[String Distance 4th String] = 20.0
[String Distance 5th String] = 20.0
[String Distance 6th String] = 20.0
[String Sensitivity 1st String] = 65
[String Sensitivity 2nd String] = 62
[String Sensitivity 3rd String] = 65
[String Sensitivity 4th String] = 69
[String Sensitivity 5th String] = 65
[String Sensitivity 6th String] = 65
[Play feel] = 3
[Low velocity cut] = 5
[Velocity dynamics] = 5
[Nuance dynamics] = 5
[Nuance trim] = 5
[Down Shift] = 0
**********Bass Mode GK set 2**********
[name] =
[Hex PU Type] = GK-3B
[Scale] = Long
[GK PU position] = 4 string 2
[PU Phase] = Normal
[String Distance PU Bridge 1st String] = 30.5
[String Distance PU Bridge 2nd String] = 30.5
[String Distance PU Bridge 3rd String] = 30.5
[String Distance PU Bridge 4th String] = 30.5
[String Distance PU Bridge 5th String] = 30.5
[String Distance PU Bridge 6th String] = 30.5
[String Sensitivity 2nd String] = 56
[String Sensitivity 4th String] = 65
[String Sensitivity 5th String] = 57
[Play feel] = 3
[Low velocity cut] = 0
[Nuance trim] = 5
[Down Shift] = 0
Guitarbot
Thanks for the work guys.  I didn't want to mess with them til they were in the librarian format.  Yall were quick!  Also, I was surprised to see Gundy's string sensitivity settings were so high.
pappywatts
Absolutely Spiffing work Chaps!
A grateful Brit........... ;D
Yeah I got one of those Smart phones, trouble is it's smarter than the owner....
Variax Kit:JTV69 +GK3,JTV59P +GK2a.
Carvin SH575, Fender Strat USA Roland Ready, Godin ACSA Multiac Nylon usb model.
GR55,GR30,GP-10, VGA7,Baggs Acoustic Reference, Zinky Green Velveteen 18w,JTM45 Head.Yamaha DXR10
#8
All:
How would I go about "examining" the patches for settings if I don't own a GR-55?  What do I need to download?
I want to create some VG-99 counterparts....
(Ah, downloaded the editor: opened the patch...stay tuned...)
Use Gumtown's  GR-55 Floorboard program to load the G5L file and view each patch's settings.
papabuss
Quote from: papabuss on June 12, 2011, 11:10:08 AM
Hi Aliensporebomb
lots of the GR55 patches from Gundy have already been created for the VG99
http://www.soundsderhelden.de/download/VG-99_SDH_Sound-Anleitung.pdf
http://www.soundsderhelden.de/download/SDH_VG-99.g9l (for WIN PC)
http://www.soundsderhelden.de/download/SDH_VG-99.g9l (for MAC)
Hello Papabuss!
I see it's a dreaded .g9l file which I can open in the librarian and see that it's 62 different patches but I want to extract particular one or two particular patches out of that whole set so I don't have to wipe out my current VG-99 setup/programming just to try them.
Is there an easy way to do this?  I'd preferably want to do it this way since I have gigs coming up and if my whole VG-99 the way it currently is gets wiped out I'll likely turn pale and keel over.
papabuss
Hi
you can mark those which you want to load up and those you won't ..
If you choose seperate ones it's a midi file so it doesn't overwrite your main settings
Hope I could help you
Greetings
I was able to copy the patch I wanted from the list in Gundy's patch set and paste it into a new untitled document but it appears that it still saves it as a .g9l format file.  I'll try it....it didn't seem obvious how to save it as .mid
Quote.it didn't seem obvious how to save it as .mid
Using the VG-99 Editor - here is how to save as a SMF *.MID file
https://www.vguitarforums.com/smf/index.php?topic=64.0
* How to use the VG-99 Librarian
https://www.vguitarforums.com/smf/index.php?topic=1071.0
And
This document "INFOCUS02.pdf" is a "MUST READ" for all VG-99 owners, it walks you through how to use the  Roland Librarian.
http://www.roland.co.uk/assets/media/pdf/INFOCUS02.pdf
But FWIW - there already exists a direct VG-99  "Sounds of the Heroes" here:
https://www.vguitarforums.com/smf/index.php?topic=60.0
Quote from: Elantric on June 13, 2011, 09:56:53 AM
And
Elantric:  Thanks - I've known how to backup and restore my own patches but the librarian was always a bit confusing - why was there multiple file formats for saving and restoring?  I understand the g9l files had multiple
patches and the .mid files were single patches but the whole thing seemed cobbled together goofily.
OK I'll read the infocus (wish I'd found that two years ago).  Oof!
Great patch'es !!
Thanks Gundy for sharing them with us.
These tones sound very alive..
celestmark
Anyone game on creating some quick audio samples for each of these? I'll be playin' with this later! Thanks for the work and makin' VGuitars G-55 place so awesome!   ;D
Bluesman
Quote from: gtrjimmy413 on June 10, 2011, 09:44:50 PM
Am having some problems getting any usable sounds from these patches, have downloaded in g5l format as per above and loaded into GR-55 via librarian...all good so far...., the patches sound very flat and all the same, they certainly don't replicate the Artist names or sounds. I deliberately did it this way so as to not overwrite my existing settings and patches. Am I missing something simple?
Or should I back up my existing settings/patches, upload the original file and then reinstall my own patches afterwards, will this make a difference or stuff up my original User Patches?
The names on the patches sound great and it would be good to try them out, any help appreciated.
PS I have downloaded many other patch files from the site, auditioned and modified to my taste in Gumtowns Editor, loaded to GR-55 and all work well.
Thanks from Brisbane Australia.
Robert Cray Fender Stratocaster - GK-3
Fender Stratocaster HH
Maton 225ac
Roland GR-55
Line6 Pod HD 500
Samson Auro D412A's Behringer B1800A's
Reason 6
Sedgewick
Bluesman:
I have also experienced a similar problem with the librarian.  The GR-55 changed the name on the display, but nothing else changed.  After I closed the librarian, shut off/on the GR-55 and re-started the librarian, everything worked as expected.
There are many useful and different patches within the Gundy Keller file.
Bluesman
Quote from: Sedgewick on November 28, 2011, 06:44:50 PM
Bluesman:
Did you use the gl5 files or the original Gundy Keller files?
Maton 225ac
Roland GR-55
Line6 Pod HD 500
Reason 6
Sedgewick
Bluesman:
It was the gl5 file that had all of the patches in it.  I was trying to "preview" my way through the list when I noticed that only the names were changing.
QuoteOr should I back up my existing settings/patches, then install the patch file to Audition it and see if I want it  ]  and then [use the GR-55 Librarian to resort my patches and include new patches I get from VGuitarForums ] and then ReSync the GR-55 Patches with the Lbrarian
Correct. This is the best approach to take prior to trying Any GR-55 patch you obtain from the net.
https://www.vguitarforums.com/smf/index.php?topic=4013.msg27145#msg27145
JCRob
Hey guys I loaded the .gl5 file on the Librarian, but it only shows the 40 Guitar Patches.  Although I want them, I mainly play in Bass Mode.
Did I miss something in the process?? Has anyone uploaded the gl5 version of the Gundy Keller file in Bass Mode??  'Cause I looked over the bass area, and couldn't find anything.
Probably because 90% of us here are Guitar players, I figure the"Sounds of the Heroes"  Bass patches were not converted into GR-55 Librarian format yet.
Why not start at the top post in this thread, do the conversion, and share?
