GT-100 - No sound with patch from Glenn Deleaune.
Started by DocMetal, November 05, 2017, 12:21:01 PM
DocMetal
Hello, I have purchased theGT-100 & GT-001 Total Patch Bundle. Good job, all work fine !
But I have problem with the pack (only this pack)  "Direct to Front of Clean Channel Amp orAmp FX Return Patches for GT-100"
I have no sound for all patchs of this pack.  :-(
Can you help me please ?
Thank you.
QuoteHello, I have purchased theGT-100 & GT-001 Total Patch Bundle. Good job, all work fine !
The " "Direct to Front of Clean Channel Amp orAmp FX Return Patches for GT-100"" are programmed for running into an amp -
try disconnecting your Headphones from GT-100
contact Glenn here
https://www.glenndelaune.com/
https://www.glenndelaune.com/patch%20downloads.htm
DocMetal
Yes, I plug the GT100 into the Fxreturn of my amp.
Connect GT-100 to BTS and review the patch for any Mutes - Zero Volume settings
Verify nothing is connected to GT-100 FX Loop - that can potentially block the GT-100 signal flow
DocMetal
Hi,
All work fine now ! GD is a good guy, he answer me immediately. The problem is on the setting of the Volume pedal settings, vol min & vol max are both to 0. Just a little turn knob and the sound is coming.
Thank you for all.   :-)
