Noisey 5v USB supply
Started by philjynx, July 06, 2017, 02:26:08 PM
philjynx
If you are using the TEENSY, then itself has a 5v to 3.3 volt switching regulator built in,
it should be able filter the supply reasonably well.
I would look at the inputs on your Teensy, if you are using an analog input for A/D conversion, is that filtered with an input capacitor?
Do you use switch debouncing code? or for analog inputs, render the sampled code down to 7 bit steps before using check code to look for input change.
(example: comparing previous sample to current sample,
if(previous_read != current_read) { sendMidi(current_read);  previous_read = current_read; };
if not the same, then the input has changed and send midi output message.
If it is done at 7 bit resolution, the change is less 'trigger happy' than at 10 or 14 bit resolution.)
What happens if you "pull up" the pushbutton inputs quite hard (1k ohm on each).
You are correct, the teensy 3.3v regulator is Linear.  :)
