Mooer Red Truck
Started by admin, June 19, 2017, 12:33:58 PM
Mooer Red Truck
Operating Modes   Live / Preset
Effects (6 + tuner)   Pure Boost, Drive, Distortion, Mod, Delay, Reverb + Tuner
Power Supply   DC 9V, 300ma min center negative
Dimensions   (HxWxD) 370 mm x 96 mm x 51 mm
Weight   1200g
Model   Mooer Red Truck
Mooer Red Truck
The Mooer Red Truck is one of the most full-featured effects strip on the market. Featuring several effects modules within one unit, this is designed for players who prefer the simplicity of single effects over multi-effects and want a portable solution for rehearsals, gigs, or where carrying a lot of gear is an issue. The Red Truck can also be used as the heart of a larger pedal board, with the effects loop allowing for the expansion of the unit.
The all analogue Boost, Overdrive and Distortion circuits provide lush warm tones. A fully comprehensive collection of high quality digital effects including Modulations, Delays and Reverbs with Tap tempo control provide spacious and ambient atmosphere via the stereo outputs. A highly visible and precise tuner will make sure you are always in tune on stage. All the parameters and functions are laid out in front of you just like a traditional pedal board. Easy to view and adjust on the fly.
The Red Truck is compact and easy to transport with the tidy soft-case we have included in the box. No matter where in the world you are going to play and what you need to connect to you can always take a fully professional pedal effects rig with you with ease.
Features
6 effects pedals in 1 - Boost, Overdrive, Distortion, Modulation, Delay, Reverb
Full featured controls for each effect
Built in precision guitar tuner
Tap tempo with dotted 8th subdivision for delay
Integrated effects loop for connecting external pedals or 4 cable method connection with an amplifier
Stereo outputs
Dedicated direct output with speaker simulation for connection to a mixing desk, computer or headphones
Includes a carry case for easy transportation
The Mooer Red Truck is perfect for musicians on the go!
Research and Reviews
Buy smart! Here are some resources for you to further investigate the Red Truck. We're players too and know that all the research doesn't always lead to the right pedal for your sound. No worries, buy with confidence with our 7 day at home trial period.
Weight: 2.3 lb
Price: $249.00
GuitarBuilder
Looks very interesting at a good price!  Too bad the audio in the demo is not very good.
