To modify a GR707 or not
Started by Brak(E)man, February 17, 2017, 07:37:11 AM
Quote from: chrish on October 05, 2017, 08:50:04 AM
No it's the French guy. Last time I checked recently dr. Joness isn't making that gear anymore.
https://reverb.com/item/5704947-roland-gm-70-roland-gr-24-pins-midi-converter-custom
That would make a very expensive boat anchor
the GM-70 has the highest latency of any Guitar to MIDi interface
Need to look for Yohan Damour
https://www.facebook.com/search/top/?q=Yohann+D%27amour&init=public
https://reverb.com/item/4948521-roland-gr-13-to-24-pins-converter-for-gr-300-gr-700-gr-100-gm-70-korg-z3
QuoteHOMEMADE GUITAR CONVERTER 13 TO 24 PINS
YOU CAN CONTROL GR-300 GR-700 ......
WITH
YOUR GK-2 GK-2A GK-3....
ASK FOR OPTIONS (fuzz, 13 pins thru out.....)
24 TO 13 PINS and more Also availlable ask
THANKS
#27
Quote from: admsustainiac on October 05, 2017, 08:53:14 AM
that GM 70 linked to above at Reverb.com was converted by Yohan Damour to include the bc13 circuitry inside for the 24 pin to 13 pin conversion.
Apparently the conversion doesn't alter the original GM70 pitch to MIDI function.
My understanding is the 13 pin out Jack is an added feature and would not include the built-in latency.
In other words it's a separate bc13 circuit that parallel uses the 24 pin in Jack for;
1.The original GM 70 pitch to Midi
2. The added bc13 circuitry
Here's his quote from Reverb.
"Original fonction (24 pins GR MIDI CONVERTER)
-24 TO 13 PINS CONVERTER INSIDE (BC-13 CIRCUITS INSIDE)"
I agree that I would not want a GM 70 to do pitch to MIDI, however the value in used GM 70's now is for parts, specifically the 24 pin Jack.
QuoteIn studio use The GM-70 modified is great cos you can assign
anything to the GR Guitar control knobs (cv1 cv2...)
for stage the box is more flexible but you control only volume and S1/S1 like GK2;
Yohan
