GP-10- Guitar amp settings for GP10?
Started by imaginenewmedia, February 09, 2017, 09:09:07 AM
imaginenewmedia
I've had my GP10 for about 6 months and I love it in my studio, plugged in direct. However i cant get a decent sound out of my guitar amp. (Marshall 4010 JCM400, 50 w combo) Everything sounds like a nest of bees. I have to turn all the tone controls down to zero (except bass) and go into the low sensitivity input and turn down the gain control to minimize distortion and it still sounds like a buzzy tin can. I've tried changing the output settings in the GP 10 (amall amp, combo etc. ) It doesn't seem to help much. Any ideas from any gigging musicians out there?
Thx, Andy
Cups
If you are using the gp-10 for modelled amps then run it through the effects loop
Return. If you are using the Marshalls preamp sound then turn off the go-10 amp sims.
Adjust GP-10  Output Mode to your taste
Must remove Headphones to hear the various 1/4" Output modes
imaginenewmedia
Quote from: Cups on February 09, 2017, 09:17:31 AM
Yeah thought about the effects loop, unfortunately no effects loop on this amp. Tried turning off the amp modelling. Much better Thanks! ( I wonder if theres a way to turn off amp modelling globally with a footswitch, that wouls save me modifying all my patches)
imaginenewmedia
Quote from: Brak(E)man on February 09, 2017, 10:14:25 AM
It sounds best in a PA
Yeah I was reluctant to do that as I cant hear myself in the mix, but I guess could use headphones on the GP10 (which switches the output to PA mode anyway) and monitor myself. I'll give it a shot. (i'll get those great stereo sounds too)  Thanks!
imaginenewmedia
Quote from: admsustainiac on February 09, 2017, 09:26:12 AM
Yeah i tried that, combo setting was best, but still not optimal. Will try thru PA as Brak(E)man suggested and monitor GP10 with headset. Thanks!
Quote from: imaginenewmedia on February 17, 2017, 06:56:33 AM
You can also use the headphone out and connect two powered monitors.
I use that from my Boss looper sometimes , works great.
