DAElectronics - iCtrl-R mini MIDI-USB - pocket size controller
Started by Elantric, January 26, 2017, 11:12:40 AM
http://www.daelectronics.com/
iCtrl-R mini MIDI-USB - pocket size controller equipped with gesture recognition technology
size matters...portable and powerful set up! with MIDI, MIDI USB and MIDI on Bluetooth LE you have small dimension lot of connection.
https://www.facebook.com/domenico.alfano.35
When you're on the road, it's not so comfortable to bring along your entire kit and set up. Equipment is large, heavy and setup is a hassle.
Other controllers have larger dimensions and durability issues
That's why we created the iCtrl-R Mini.
dAeLECTRONICS
Each of the 4 buttons has dual functions (click and hold) and you can send 2 program change for each switch (in mode1) or 2 control change (in mode 2) or select 2 scenes (in mode 3 of AXE FX firmware) or send bank up and down and preset a/b/c/d selection for each bank in mode 3 of the Jamup/bias fx firmware
Holding for a second one of the 4 switches you'll have the following 4 modes :
MODE1 : can send up to 8 program change
MODE2 : can send up to 8 control change (you can store the on/off status of 8 effect for each of the patch of mode1)
MODE3 : up to 8 scenes selection in the AXE FX firmware or bank up and down and preset a/b/c/d selection for each bank in the Jamup/bias fx firmware
MODE4 : up to 8 controls for looper mode.
Holding the switch 1 in MODE 1 will let you enter to calibration mode.
Both the external expression pedal and the Vslider will be active when MODE1 to MODE4 is selectedDigitare il paragrafo qui.
The iCtrl-R mini is a pocket size MIDI controller that can send MIDI messages through USB or MIDI out port or...both!
You can use it with all MIDI hardware like the AXE FX II or the Atomic Amplifier and software apps like Amplitube, Jam up pro, Bias FX, Guitar Rig on MAC/PC/iPad and iPod.
We have different dedicated firmware that can be easily uploaded on the controller and let you use it with the above mentioned stuff.
Just connect the controller to a MAC or PC and click a button on the controller !
The iCtrl-R has 4 different modes (you can switch between them by holding switches for one second) and a calibration mode to use the entire range of whatever expression pedal to be connected to the iCtrl-R mini .
In addition you'll have the Vslider that is a sensor capable of sending MIDI continuos control change and control then effects like wah or whammy by moving back and forth the foot from the controller box.
iCtrl-R mini including shipping to Europe
PayPal - The safer, easier way to pay online!
iCtrl-R mini Bluetooth inclusa spedizione verso l'Italia
The iCtrl-R Mini is the first MIDI floor controller equipped with gesture recognition technology, the Vslider, so you can control tones just by moving your hand/foot back and forth from the controller it's a musician dream, featuring:
-A portable and ultra durable design that will last
-Works with iOS, WIN, MAC and any program that supports USB-MIDI
-5Volt power supply through USB (and rechargeable battery on the bluetooth version only)
-V-Slider technology to change sounds with a wave of your hand or foot
-Optional BLE bluetooh for wireless MIDI communication with iPad/iPhone
Works with your favorite MIDI hardware, iOS/MAC/PC software the Atomic Amplifire, the AXE FX II and the Kemper Profiler.
The iCtrl-R is fully USB-MIDI compliant and works with iOS and MAC/WIN devices, along with hundreds of apps such as Amplitube, Bias Fx, Jamup, Guitar Rig, Main stage and more, so you can plug in and get set up quickly and easily.
Size and portability matter.
the iCtrl-R mini is designed and built to be compact and durable.
The enclosure is diecast alluminum and the switches are heavy duty long lasting push buttons and at only 650 grams it's light enough to bring anywhere.
Tech specs.
The iCtrl-R is nicely designed and precision engineered.
Dimensions: 120mm x 95 mm x 35 mm  (approx. 4.37 x 3.70 x 1.17 inch)
Weight: 650grams.
Materials: Diecast alluminum, heavy duty pushbuttons
Gesture sensor: Sensitive proximity sensors that are capable of recognizing gestures and can be used to modulate parameters like wah, volume, pitch, sustain and mapped midi parameters
Processor: ARM Cortex-M0+ processor at 48 MHz
Output: Standard MIDI OUT connector & mini USB that charges the iCtrl-R mini and can be used as a USB-MIDI connection
Power: 5Volt through USB connector and (bluetooth version only) the included rechargeable battery
Footswitches: 4 rugged metal footswitches for preset change and control change
Expression Pedal Input: 1/4″ TRS Input to connect and external expression pedal and real time control any paramater on stage
iCtrl-R Mini/OS/Win Compatibility: USB-MIDI compatible with CoreMIDI on iOS, Mac and PC. Connect quickly and easily to your computer via Micro USB or to your iPhone/iPad using the optional camera connection kit or the Bluetooth 4.0.
dom_alf
Thanks for sharing, I'll be very happy to answer any questions you may have on our iCtrl-R mini !
Greetings from Italy !
Dom
dom_alf
Quote from: dom_alf on January 27, 2017, 07:01:48 AM
Dom
here's a quick video showing the iCtrl-R controlling jamup on iPhone.
https://youtu.be/65XJRxkP6k8
Headless68
Just picked one of these up - will let you all know how I get on with it - looking forward to not needing an EV5 + pedals & just using this live
Headless68
Had a quick test just to make sure it was all functional - hooked up to an iPad via usb / CCK - Bias FX - used midi learn and was able to get FX on/off working in 10 seconds - the VSlider (same as a Dbeam on VG99 but on the floor) seem really responsive it tracks your movement and translates it into pedal adjustment in Bias very smooth and with no noticeable latency. I also like that you can move either horizontal or vertical to trigger the movement. One last thing if you hold your foot in the beam and stay still for a few seconds it 'locks' into that position and you can remove your foot, so you can set a volume or 'cock' the Wah at a certain position.
Seem well built and the foot switch spacing is good, its very compact which is excellent. The only thing Im consciously aware of the mini usb connection on the back  which will need to be treated carefully in live situations. For the VG99 I will just use 5 pin midi (which I have not tested yet)
So far - all good
mooncaine
Thanks for the hands-on review from personal experience!
