RJM MasterMind LT
Started by Elantric, January 23, 2017, 12:06:04 PM
RJM MasterMind LT
https://www.rjmmusic.com/products/mastermind-lt/
https://www.rjmmusic.com/manuals/Mastermind%20LT%20Manual-3.1.pdf
http://www.rjmmusic.com/wiki/index.php?title=GT/PBC_Editor_Manual
7 buttons, each with a multi-color LED. Buttons are completely user configurable for color and function
16 button pages that can be set up to perform different functions, control multiple devices, etc.
A large main LCD display shows the preset number, preset name and/or song name
Phantom power capability allows you to run the Mastermind LT with a single MIDI cable – no separate power supply needed
More than one Mastermind LT can be connected together and used in multiple locations on stage
Expression pedal input which allows sending of continuous control MIDI messages to your effect devices
External switch input allows you to add an additional 1 or 2 buttons to the controller for tap tempo or any other purpose. External switches have a single color LED and can be configured to do anything that the internal switches can
Function switch output allows you to control channel switching on amps, 1/4-inch switching inputs on pedals, etc. Two switches are provided using a 1/4-inch TRS jack
USB support for direct connection to a PC or Mac. The Mastermind LT can be bus powered from the USB port
USB thumb drive input allows you to save and restore settings to a thumb drive
On board editing menus allow basic configuration for devices, MIDI CC, PC and Note messages
Editor software for PC and Mac allows additional configuration, including complete control over the configuration of buttons
Built for the rigors of the road with high quality components throughout
2 year limited warranty
Made in the USA
Number of instant access buttons, preset buttons and bank size are all user definable – any button can be assigned to any function
768 presets, 16 pages of buttons and 16 connected devices
Preset buttons can send a program change to all 16 devices with a single tap
In addition to sending program changes to each device, preset buttons can also send up to 10 other MIDI messages (any combination of CC, PC, Note or Sysex)
IA buttons can send up to 20 messages (any combination of CC, PC, Note or Sysex)
Accepts one expression pedal using a TRS jack, high or low impedance
External switch input: 1 TRS jack for a total of 2 switches. Momentary switches required
Function switch output: 1 TRS jack for a total of 2 switches. Electrically isolated
7-pin DIN connectors for MIDI input and output
USB "A" connector for connection to a USB thumb drive
USB "B" connector for connection to a PC or Mac. (Bus power supported)
Phantom power received over MIDI jacks
Dimensions: 11.5 (W) x 5.0 (D) x 2.75 (H) inches / 29.2 x 12.7 x 7.0 cm
Weight: 1.9lb / 0.86kg
Power requirements: 9-12VDC @ 150mA, center positive or negative, 2.1mm ID / 5.5mm OD barrel connector
mdortona
Hi Steve,
Have you tried this with the Ipad CCC and/or the Tripleplay? Will it work with iOS? It would be the answer to my prayers ;D
Matt
Best to contact RJM directly
https://www.rjmmusic.com/contact-us/
