GR-55 - Funk Guitars Pack!!!
Started by jonathanf106, June 17, 2016, 02:51:45 PM
jonathanf106
I just made some funk guitars by altering frequencies of the EQ for COSM Guitars. If they are too bright or too mild, just go to EZ-Edit and change the setting.
These patches are modified so using only MFX, so if you want to use MOD/Amps, you have to change it through the structure.
**These samples are not produce by me, but these are the tones you gonna get.**
Let me know if there are any questions, and enjoy.  ;)
HecticArt
Thanks Jonathan.
jonathanf106
No problem, this might help as well you tweak the tone of your COSM guitars.
http://www.digitalprosound.com/2002/03_mar/tutorials/mixing_excerpt1.htm
tillthen
Wow ... I love those Funk patches!!  Awesome!!
Any chance that you could tackle a 12 string patch    ! No longer available
jonathanf106
Quote from: tillthen on June 22, 2016, 11:31:08 AM
I don't have to make one, you can, all you have to do is copy one of the patches that you downloaded, change it to acoustic guitar, enable the 12 string setting, adjust the parameters for the EQ and EZ-Edit, it's really simple, if you played around with settings and parameters before.
use this a tweaking tone guide for the EQ parameters.
DreamTheory
HoosierMan
I just happen to be working on a new funk inspired recording project and your funk patches came just in time.  I will definitely be checking them out!
turenko
 :) :) Thanks for the patch! awesome!!
Brian Moore iGuitar 9.13
KRAMER Richie Sambora 1989 with gk-3
Squier Japan 1989 with Gk-2
Takamine EF 291M(E) with Gk-3
JiveTurkey
burn007
these are fantastic. Thanks. I was looking for a new sound and this is just what I needed.
ricmus
Hi, nice work. I loved them.
Best wishes.
