Electro-Harmonix Super Space Drum and Crash Pad
Started by Elantric, January 12, 2016, 02:56:37 PM
EHX's rich history was marked by many revolutionary pedals but one of our most distinctive lines was a group of analog drum synthesizers that included the Crash Pad and Super Space Drum.
Like the original from 1980, the new Crash Pad can create an array of drum sounds and other-worldly oscillation sweeps, as well as process external sounds thru its resonant filter. Plus, it's been updated to respond to expression pedal/CV input for external control over the filter in real-time.
A faithful reissue of the cult-classic released in 1979, the Super Space Drum uses analog synthesis techniques to create mind-blowing sounds ranging from deep kicks to high toms to sci-fi drums. Trigger it from the built-in pushbutton or an external (non-MIDI) electronic drum pad. Pass external sounds through the gated amplifier via the aux input. The Super Space Drum lets you create, control and manipulate a stunning array of synthesized sounds.
