GR-33 - Using Roland GR-33 as controller for kemper?
Started by jackzucker2000, January 07, 2016, 08:20:23 AM
jackzucker2000
Anyone have instructions or FAQ on how to set this up?
vablows
I don't think there is a FAQ, but I use the GR-55 to control my Kemper.
It is basically plug and play as far as MIDI goes for patch change if you set the Kemper MIDI PC # to the GR-33 they will match each other.
Volume pedal is CC #7, but I use CC #1 for mine so the expression pedal can double as wah in Kemper.
In Kemper menu there is a way to select to auto change Volume pedal to Wah when engaged.
I then use the stop/start for wah, is turns on as soon as you move the expression pedal then stops quickly after you stop moving it.
Any other specific needs you have, maybe I can help?
WA to VOl is in the system settings.. For me I use the Kemper to control my GR55
