Zoom F8
Started by Elantric, July 10, 2015, 09:56:24 PM
http://www.sweetwater.com/insync/summer-namm-2015-zoom-f8/
The Zoom F8 Multitrack Field Recorder is a serious portable recorder on a budget. This professional unit is ideal for serious filmmakers and sound designers. Eight super-low-noise preamps record at up to 24-bit/192kHz resolution to give you the highest-quality audio for any project. A large LCD display and dedicated gain knobs and PFL/Solo switches for each channel make the F8 easy to operate in any situation. This compact unit also boasts remote app control, BNC Time Code I/O, onboard limiters, and much more.
Zoom F8 Multitrack Field Recorder Features at a Glance:
A professional 8-in/4-out field recorder
8 XLR/TRS combination inputs with microphone preamps and phantom power (+24/+48V) accommodate most analog connections
Track professional Broadcast Wave Format (BWF) multitrack audio at up to 24-bit/192kHz
Records onto two SD/SDHC/SDXC storage media cards with up to 512GB capacity
iOS app for wireless control
Time code and USB
Time code I/O is provided on BNC connectors. A USB port enables firmware updates, file transfer, and allows the F8 to be used as an 8-in/4-out USB audio interface operating at sample rates up to 96 kHz.
USB Class:    USB 2.0 High Speed
Specifications:    44.1/48/96 kHz, 16/24-bit, 8-in/4-out
( works as 8-in/4-out Audio interface for iPad too)
Built-in Slate mic
Large LCD display makes navigation and setup extremely easy
Runs on either 8 AA batteries, 12V adapter, or DC battery packs via 4-pin Hirose connector
Includes camera mount adapter, 2 x TA3 to XLR cables, and 12V Adapter
Photo Gallery
https://www.zoom.co.jp/products/handy-recorder/zoom-f8-multitrack-field-recorder
