Must Have Accessory List for Mobile Guitarists
Started by Elantric, March 29, 2014, 09:41:01 AM
Stagg Model GIST-300 Foldable Stool with Built in Guitar Stand
New model Gator GTR-SEAT with backrest
Gator G-GIGBOX2
taupo_axeman
Blu-Tack.
I use it for all analogue knobs or settings that can't be digitally saved.  E.g. Input gain on my Mackie DL1608, stomp box pedals, Amp settings.
Since I started this 10 years ago, I've never returned from a gig discovering a knocked dial/wrong setting ::)
https://www.gigbag.app/
Guitars: 1975 Strat, Godin XTSA, Maton Acoustic, Roland GC1
Amp:Tech 21 Trademark 60
P.A.: Mackie SRM 450's, 15 Mackie Active Subs
Floor: Boss GP-10, VG8 EX, VG-88
Studio: Logic Pro, Omnisphere, Korg Triton, Tria Event speakers
www.tasmanhoppers.com/music/
These work 100% with modern micro Xotic / Joyo / Mooer Guitar FX that require external 9V power
https://www.amazon.com/dp/B01AXIEDX8/ref=cm_cr_ryp_prd_ttl_sol_23
5pack 9v Battery Clip with 2.1mm X 5.5mm Male DC Plug for Arduino by Corpco
This is a quick video showing the Behringer CT100 cable tester which tests a multitude of different cables. This is a no brainer for a church/venue to have at such a low cost. It is powered off of two AA batteries.
I test all of my cables about once a month to make sure everything is still functional. The intermittent function is very handy as you can jiggle a cable back and forth once connected into the CT100 to make sure the connectors have good conductivity.
If you haven't already, make sure to check out my new website https://dbbaudio.com for the latest news and updates!
This Pyle version below tests more cable types
Both include a Signal generator calibrated for -10dBu / +4dBu
https://www.amazon.com/dp/B004HJ545G/ref=pd_luc_rh_sbs_03_02_t_img_lh?_encoding=UTF8&psc=1
http://www.pyleaudio.com/sku/PCT60/13-IN-1-Audio-Cable-Tester-(Tests-14-(TRS)-18-(35mm)XLR-(3-Pin)XLR-(5-Pin)Speakon-(4-Pin)Speakon-(8-Pin)RCATTBantamRJ45USB-AUSB-BDIN-(3-Pin,-5-Pin,-7-Pin,-Or-8-Pin)DIN-(4-Pin)
Make sure your audio cables are working properly with the Pyle PCT60
Click here for a larger image
Supports all the most used cable types in the sound recording industry
Affordable, Easy Way to Ensure Your Cables Are Working Properly
The PCT60 is an incredibly versatile 13-in-1 cable tester that quickly delivers accurate continuity information about many different kinds of cables. LEDs on the unit confirm each conductor's continuity and connection. Also includes ground connection status check so you know the tester is accurate. Tests ¼" (TRS), 1/8" (3.5mm), XLR (3-pin and 5-pin), Speakon (4-pin and 8-pin), RCA, TT, Bantam, RJ45, USB-A, USB-B, DIN (3-pin, 4-pin, 5-pin, 7-pin, or 8-pin).
Rugged and Durable Design
Built in a strong, compact metal casing, the PCT60 is made to last, and is a great long-term solution to help keep your audio set-up running smoothly.
Supports All the Most Used Cable Types
With support for nearly every cable type in the sound recording industry, the PCT60 is your go-to for making sure your next performance goes off without a hitch. Or, you can do a little house cleaning and throw out any cable that's no longer working.
1/4'' (TRS)
1/8'' (3.5mm)
XLR (3-pin)
XLR (5-pin)
Speakon (4-pin)
Speakon (8-Pin)
RCA/TT/Bantam/RJ45
USB-A/USB-B
DIN (3-pin, 5-pin, 7-pin, or 8-pin)
DIN (4-Pin)
Product Description
The PCT60 is an incredibly versatile 13-in-1 cable tester that quickly delivers accurate continuity information about many different kinds of cables. LEDs on the unit confirm each conductor's continuity and connection. Also includes ground connection status check so you know the tester is accurate. Tests ¼' (TRS), 1/8' (3.5mm), XLR (3-pin and 5-pin), Speakon (4-pin and 8-pin), RCA, TT, Bantam, RJ45, USB-A, USB-B, DIN (3-pin, 4-pin, 5-pin, 7-pin, or 8-pin).
https://www.bhphotovideo.com/explora/audio/tips-and-solutions/6-irreplaceable-audio-tools
MusicNomad MN227 The Octopus 8 'n 1 Tech Tool
Five hex wrench sizes: 10mm, 12mm, 14mm, 1/2", 7/16"
Compact 6" design with ergonomic handle
Great for tightening input/output jacks, control pots, tuning machine bushings and screws
Reversible Phillips & flat blade screwdriver
Made with strong ballistic nylon material to avoid scratching your Hardware or finish
https://www.amazon.com/MusicNomad-MN227-Octopus-Tech-Tool/dp/B06VX1DL9N/ref=lp_10076970011_1_2?srs=10076970011&ie=UTF8&qid=1491892007&sr=8-2
Korg Beat Boy  $49
https://www.amazon.com/Korg-KORG-BEATBOY-Beatboy-Tuner-Metronome/dp/B00F0GQ6TS/ref=sr_1_1?ie=UTF8&qid=1496701062&sr=8-1&keywords=Korg+Beatboy+Tuner%2FMetronome
http://www.korg.com/us/products/tuners/beat_boy/
Perform backed by 100 full-fledged rhythm patterns
Use the tap tempo feature to adjust the tempo intuitively, or use the tempo adjustment buttons to make fine adjustments
Adjust the volume of the drum machine to fine tune the mix balance with your guitar sound
Tuner function ensures that your pitch is accurate
Overdrive/distortion effect for electric guitar
Recorder allows 16-bit/44.1 kHz PCM recording and playback
Approximately 20 minutes of recording, with a maximum of 100 tracks
USB port allows your recorded phrases to be easily backed-up to your computer
Internal mic supports acoustic instruments
Built-in speaker lets you immediately listen back to recorded sounds
http://www.korg.com/us/support/download/manual/0/274/2043/
ammoon Flanger FX-02 3-in-1
Multifunctional Restringing Tool Motorized String Winder Strings Cutter Bridge Pin Remover with USB Charge Cable for Banjo Guitar Bass Mandolin Ukelele
https://www.amazon.com/gp/product/B01LYCVA9U/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Meet the new Roadie
( but I might wait a year for the Harbor Freight version ;)
Quote from: Majiken on February 09, 2015, 12:56:50 AM
That Pyle PDC22 looks like a clone of my Palmer PAN04- for $15?!?!?!?!?
http://www.palmer-germany.com/pro/en/PAN-04-DI-Box-2-channel-passive-PAN04.htm
You gotta be kidding, if the performance is anywhere close that's an absolute steal!!! How lucky you guys living in the States are, at least in terms of musical equipment prices....
and same as ART dPDB and Nady DI passive boxes - just different silk screen
http://artproaudio.com/images/products/dpdb/dpdb_top_lg.jpg
Details on a Jenson JT-DB-E Transformer swap
http://www.jensen-transformers.com/transformers/direct-box/
https://www.amazon.com/JENSEN-JT-DB-E-Direct-Box-Transformer/dp/B01LRLJMAO
http://www.radialeng.com/comparing-dis.php
http://truetone.com/ma-meter/
The 1 SPOT mA Meter (that's "milliamp meter" for all you non-engineers), is a simple device for measuring the power consumption of your guitar pedals.
You're probably used to seeing power supply outputs with ratings like "100mA", which is the maximum that output can provide for a pedal. And you might have wondered whether it was enough to power your particular pedal(s). The mA Meter answers that question for you by showing exactly how much current your DC powered pedal really needs*.
No more scouring the Web for information about your pedals that might not even be accurate. Just plug your pedal into the mA Meter and see for yourself how much power it needs!
And as an added bonus, we've even thrown in a cable tester as part of the mA Meter... perfect for those last second cable checks at the gig.
* Input voltage range: 9-24Vdc; Max current displayed: 999mA
Vertech VW-1 Smart Winder
PRODUCT DESCRIPTION
Vertech Smart Winder Automatic Guitar Tuner - Patented
For Guitars and Ukuleles
Strong motor for tuning a guitar or for use during string changes
Audible beep to help identify when the string is in tune so you don't have to look at the display
Long Lasting Rechargeable Battery - charges with standard USB connection
Includes tuner and USB charging cable
The Vertech hand-held guitar tuner will quickly and easily tune each guitar string. It is very simple to use.
Turn on the Smart Winder by pressing the power button for 1 sec.
Place the tuner on the tuning key to be tuned.
Pluck the string
The Smart Winder will automatically tune the guitar string to pitch and make an audible beep when in tune.
Go to the next string...it is that easy!
The Smart Winder is not designed to be used like the Roadie to quickly change to different alternate tunings. The unit must be in the displayed range of the string(note) before the tuner will automatically tune the string. Use the up/down keys to manual tune the string to the desired note and then let go to let the Smart Winder automatic tuning of the string.
The strong motor and long battery life will allow you to use the Smart Winder to make quick string changes.  Use the up arrow key to wind the string.  Pluck the string when you are getting close to see the current string pitch. Stop manual tuning when the desired string pitch is displayed to allow the unit to complete the tuning process for you.
The Smart Winder will charge with any standard USB charging port.
$39
http://www.philadelphialuthiertools.com/luthier-tools/misc-tools/vertech-vw-1-smart-winder-automatic-guitar-tuner/
mooncaine
Quote from: Taupo_Axeman on February 07, 2016, 01:12:37 AM
Blu-Tack.
Nice!
I use Scotch brand removable mounting putty (less sticky than blu-tack) on guitar pickguards as a place to hold extra picks. If it's too sticky, just drop it (the putty) on the floor a few times. When it picks up dust & dirt, that'll tone down the stickiness. I also use it on the painted surface of my guitars, but these are modern, cheapo guitars with polywhatever finish and I don't care if the putty marks the guitar anyway.
https://www.amazon.com/dp/B01DW371FS
9V battery snap connect for effects pedals, with right angle "L" plug
Connect a 9V batter to a power connect to power an effect pedal without a battery
Can be used with most effects pedals
Ideal for the Stagg BLAXX series effects pedals for guitars
5.9" length
Description
The IEC Power Cable+ is an IEC cable with an integrated accessory outlet, so now you have an extra outlet on the stage which is perfect for mobile devices, pedal boards, and other electronics used in gigging situations. Built with 12AWG conductors, these cables feature 100% more copper over standard 18AWG cables supplied with most amplifiers. The larger conductor size prohibits any possible current degradation of inferior cables, while the 10ft length allows you to reach most outlets without the need for extension cords or power strips. Available in F-plug, G-plug, and NEMA plug types.
12 AWG 10' power cable
Features integrated accessory outlet
Standard IEC cable also available
D'Addario is known for innovative, problem-solving, quality musical accessories, offering a complete line of award-winning accessories including cables, picks, tuners, capos, straps, humidifiers, maintenance tools and more.
http://www.accessories.daddario.com/pwProductDetail.Page?ActiveID=4115&productid=1161&productname=IEC_Power_Cable_10_&sid=d945ded4-ac7f-48ec-8795-806b1ff72112
https://www.amazon.com/DAddario-Accessories-Power-Cable-America/dp/B078V6DS9F/ref=sr_1_1?ie=UTF8&qid=1539232919&sr=8-1&keywords=PW-IECPB-10
http://www.p3international.com/manuals/p4330_manual.pdf
Advanced surge protection circuitry
Soft power-up eliminates harmful voltage spikes
Displays max/min volts
Measures amps, watts, PF & leakage current
10 Outlets Design
Advanced Surge Protection Circuitry
SoFeet Power-Up Eliminates Harmful Voltage Spikes
https://www.amazon.com/gp/product/B004OG94VW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Handy for your DSP pedal board  / computer rig if you play live  - might save the gig should a brief power failure occur mid set
CyberPower EC850LCD Ecologic Series Uninterruptible Power Supply
https://www.bhphotovideo.com/c/product/1008436-REG/cyberpower_ec850lcd_850va_ups_standby.html
Can be adapted for testing Gk 13 pin cables
Konstant Lab - Eurorack Cable Tester
https://reverb.com/item/11240411-konstant-lab-eurorack-cable-tester
Konstant Lab Cable Tester is device for testing all kind cables used in eurorack modular synth. Cable Tester uses an automatic switching circuit that switches voltage between wires in cable. You can check cables with 16 and 10 wires and 3.5mm Jack patch cables. Cable testing is simple. Just insert connectors into the tester sockets. Turn on power switch. Red and yellow LEDs blink. Each LED represent one wire in cable. If some LED don't light, some wire is broken. If LEDs light does not match with the wire number, cable is bad made. If all LEDs light, there are some short in cable. You can pause blinking with pushbutton.
Cable Tester can be powered from a 9V battery, from an external Power brick 6 - 25V with center positive barrel connector and from eurorack PSU via 10 wire power cable (like module).
Features:
                    Dimensions:     90 x 100mm
                              Tested cables: 10 wires flat cable
                 16 wires flat cable
                 3.5mm patch cable
                              Power:              9V battery
                                                       DC power brick 6-25V 5.5/2.1 Barrel center positive
                                                       Eurorack PSU via 10 wire cable (like module)
Quote from: admin on February 08, 2018, 10:30:22 AM
PRODUCT DESCRIPTION
Pluck the string
$39
This works very well - ( handier than a set of Tronical Tuners  )
However price is now doubled - now $79
Quote*The Jowoom Smart Tuner is a version 2 of the original Vertech Smart Winder VW-1. New features include a faster and stronger winding motor (almost twice as fast), a semi-automatic tuning mode for use in string replacement (wider tuning range), ability to set custom tunings and larger tuning key adapter.
https://www.philadelphialuthiertools.com/luthier-tools/misc-tools/jowoom-t2-smart-tuner-automatic-guitar-ukulele-tuner/
https://www.ebay.com/itm/Jowoom-T2-Smart-Tuner-Automatic-Guitar-Ukulele-Tuner/113262168457?hash=item1a5ef38989:g:BD4AAOSwlKlbpNxx:sc:USPSPriorityMailSmallFlatRateBox!93401!US!-1:rk:1:pf:0
https://www.amazon.com/Automatic-Acoustic-Auto-Tuner-Professional-Rechargeable/dp/B07G8J1XQ3/ref=pd_cart_vw_1_4?_encoding=UTF8&pd_rd_i=B07G8J1XQ3&pd_rd_r=DT8ZXSEGQBKBSJ9TAECP&pd_rd_w=uQsVI&pd_rd_wg=ZR9q2&psc=1&refRID=DT8ZXSEGQBKBSJ9TAECP
https://www.jowoom.com/
https://www.facebook.com/Jowoom/
This is pretty cool
Its a Bluetooth Receiver  in small metal case, with a TF/MicroSD card slot and an internal MP3 audio player
Connect this to the 3.5mm TRS Aux port on your MFX ( GP-10, Ampero, GE300, Headrush, ) fill the MicroSD card with backing tracks or band practice tracks.
$7.00
Bluetooth 4.2 Receiver Wireless Audio Adapter with 3.5mm Aux Stereo Output
Description
4.2 Portable Wireless Bluetooth Receiver, 3.5mm Stereo Receiver Car Kits, Hands-free Car Audio Adapter for Home /Car Audio Stereo Music System
Super Long Working Time: Independent TF card mode, power failure memory, Buckle up for 18 hours of nonstop music streaming, radio, phone calls and get fully charged within 3.5 hours.
Advanced Smart Bluetooth V4.2 Chip: Adopt the new upgrade Bluetooth V4.2 chip, the multi-data transmission makes more stable, the wider wireless coverage and the more efficient low-power operation Support to connect with 2 phones at the same time.The product automatically power off after 5 minutes without a Bluetooth connection.
Wide Compatibility: Support the most of Bluetooth devices, Support Chinese and English models,Small But Amazing Fill Your Life With Wireless Notebook/ Tablets/ Mobile Phone/ Car Stereo/ Headphone/ home audio system, no obstacle can reach up to 10 meters.
Convenient Dual Connections: Enjoy an easy and quick switch between two devices actively connected to the Bluetooth adapter and play music from either devices; straight-forward controls with buttons to adjust volume, play / pause music, or answer calls . And Echo cancellation and noise suppression (CVC) function
All Metal Material: Surrounded by an integrated molding, Use rigorous process to interpret the attitude that does not follow the crowd. suitable for all kinds of occasions
Product description
Bluetooth music receiver (hands-free) is a high-tech wireless device that can receive mobile phones or other audio devices by bluetooth technology. This music receiver can be used for all audio input, such as car audio or home audio, with a 3.5mm audio adapter. So you can enjoy high quality music at home, office or in the car by the device. You can also dial and answer the call by the device. It can realize the functions for handsfree, enjoy the music stored in the phone, and even listening the internet radio.The product is with embedded echo cancellation microphone, it can easily switch between music and phone calls by one button.
Features:
1.All metal housings, smart small size, suitable for all kinds of occasions
2. Built-in DSP independent amplifier, HIFI sound quality, super anti-interference
3. Independent TF card mode, power failure memory
4.Voice prompt, coming call in Chinese and English
5. Support Bluetooth hands-free call function
6. Support Bluetooth A2DP stereo
7. Support Chinese and English models
8. Support to connect two phones simultaneously.
9. Support Bluetooth handsfree/answer/ hang up/ reject/ redial call and other telephone functions
10. Echo cancellation and noise suppression (CVC) function
11. The product automatically power off after 5 minutes without a Bluetooth connection
Technical Data:
1. Bluetooth V4.2+EDR,Further transmission distance: 10m
2. Frequency: 2.4GHz
3. Limit working voltage: 2.80V-4.20V
4. Working temperature: -20°-50°
5. Effective distance of Mic.: 0-1m
6. 3.5mm stereo audio input
7. Micro USB charging port
8. Bluetooth Pairing Name: BT710REV
9. Working time:up to 18 hours
10. Standby time: 100days
11. Charging time: 3.5hours
Package
1* Bluetooth Music Receiver
1* USB cable
1* User manual
https://www.ebay.com/itm/163500747477
Cherub WST-670 CabTune
Very fast, accurate Tuner -recharge via USB
https://www.amazon.com/gp/aw/d/B089QRBZQ8?psc=1&ref=ppx_pop_mob_b_asin_title
I consider this a must have item
When learning new tunes I rely on my own chord charts, often with my own voicings.
So I have a song book with my own tabs/chords-typically just need it to jog my memory during band rehearsal until I get everything  learned and programmed in my muscle memory for songs I never played before.
This auto inker guitar chord stamp for 5 frets covers my needs-from Japan
https://www.amazon.com/gp/aw/d/B00N6MCWFU?psc=1&ref=ppx_pop_mob_b_asin_title
And Blank page 5× 7.5" notebook
https://www.amazon.com/dp/B07CRF884D?psc=1&smid=A1ZBN2S2N5F7DZ&ref_=chk_typ_imgToDp
https://bretpimentel.com/jazz-chord-symbols-a-primer-for-the-classically-trained/
Once learned, I don't use chord charts at live gigs
And frankly I'm 300% faster just using my Sony PCM M10 recorder with variable speed and A/B repeat -or a few YouTubers who provide decent chord charts
I own every guitar tab/chord app, but it's tedious work
Instead I might just print out a Lyric sheet with intro, Verse  , Chorus , Bridge , outro all triple spaced , then stamp my own chords as needed.
Or
Just have the chords and no lyrics
But curious what other apps on IOS/Android /Mac/Windows do others use to document chords to songs Swiftly ?
For me nothing beats old school lead pencil & paper & guitar chord stamper and place the dots where my fingers go.
