GR-55 - Pedal won't calibrate
Started by Sandaniam, August 27, 2014, 06:30:40 PM
Sandaniam
Help!
I can't calibrate the pedal on my GR-55. I've done this before no problem, but now I get an error that says "Pedal out of range". Tried a factory reset, same thing. It really needs calibration as all volumes and functions are out to lunch. Anyone have this issue before? Isearched the forums, could not find any info on this one. :-[
G. ???
Maybe something physically wrong with the rotary encoder attached to the pedal.
I know that they have failed on a very few of the Boss GT pedals, and the GR-55 uses the same part (AFAIK).
If you are DIY inclined, look inside the GR-55 to check it operates over the full pedal movement range,
and that it's plug is not dislodged slightly from the main board..
Sandaniam
Ok thanks for the advice. Will check tonight.
Shaun Derek
Hi guys
I'm getting the same error on my gr55
"pedal out of range"
Has anyone had the same and what is the answer?
TIA Shaun
* Back up your GR-55  patches
* Perform a system Reset
* Recalibrate the Expression pedal
* Restore your GR-55 Patches
Details are here:
https://www.vguitarforums.com/smf/index.php?action=downloads;sa=view;down=86
https://www.vguitarforums.com/smf/index.php?topic=2953.0
My GR-55 now seems to exhibit unusual EXP pedal ranges.
Some days I get the full 0~127 range, other days it seems to only go 0~115 full range.
Might be time for a replacement rotary encoder.
I had to replace mine. That could be what it is... Make sure everything is tight though before you do
Check the internal expression pedal mechanism and tighten loose parts
Magiamusical
Please post if anyone has fixed this problem, I been having the same issue for over a year, range varies, checked for loose parts, tried to move the sensor but no luck. Been using an external pedal but the idea was to use both pedals.
Godin LGXT, Les Paul Studio w/GK3, JTV89F w/GK3, GR-55
QuoteBeen using an external pedal but the idea was to use both pedals.
Since GR-55 lacks an external Expression pedal input jack , How do you use an External Expression pedal with GR-55?
Magiamusical
Quote from: admsustainiac on May 15, 2016, 08:29:57 AM
I'm using a DIY MIDI controller with an expression pedal that can be assigned to any parameter.
Is the GR55 expression pot the same value as EV5
