Patch dowmnloads-does not sound like it's suppose to
Started by pépéro, September 21, 2014, 10:37:53 AM
pépéro
Is there something I did wrong when downloading patches that might explain that it does not sound even close to what it was suppose to ? One of the patche I downloaded was suppose to use a Gibson L4 but rather, it was a strat. Same thing with effect settings that were not corresponding to what could be expected. It happened with a few patches I downloaded. I'm sure that the guys who created those patches did well. Someone can help me to understand ?
Pépéro
Pretty common problem.  This usually follows a minor tech screwup (like trying to write a patch prior to selecting the GR-55's midi port).
To correct: reboot, only run *ONE* GR-55 related app at a time (editor OR librarian OR DAW), and make sure device/port is selected properly in the editor or librarian before attempting to write patches.
More here:
https://www.vguitarforums.com/smf/index.php?topic=9808.msg70328#msg70328
And here:
https://www.vguitarforums.com/smf/index.php?topic=11599.msg84224#msg84224
Hope this helps,
