GR-55 - Has anyone made any guitar into leslie patches a la Badge?
Started by gibvictory, September 17, 2014, 05:48:28 PM
gibvictory
I have not had my Gr55 for very long. Worked out most things I need it to do so far and having fun. One thing I have not been able to get is a grinding Hammond sound. Then I thought why not a guitar into leslie like Badge or It Don't Come Easy. I did a search and nothing came up. Any ideas? I've been using my AxeFx. Kinda gets the job done live but I would love to see the look on my bandmates faces with a more realistic patch.
I have to say this site is a great resource. It's been very helpful. Even though I've been using a GR33 for several years I consider myself a novice. The barely acceptable latency allowed limited use. Mostly soft synth patches. Always had to mix in a little guitar to mask it. I know there are complaints about the GR55 but it's a vast improvement for my needs. Love the COSM and improved latency. That's why I bought it. My sincere thanks to all the contributors.
Here is a patch I did using a wurly type keys and the Rotary effect.
The EXP pedal mixes in the keys and at a certain point triggers the rotary speed to ramp up from slow to fast over a period of a few seconds, and ramp back down as the pedal is moved back to about half way.
It was originally designed as a bass patch, but will load in for guitar.
If you want guitar to go through the effect, change the Routing and Structure settings.
https://www.vguitarforums.com/smf/index.php?topic=11490.msg89317#new
the patch is attached at the bottom.
gibvictory
