Triple play with Gr55 possible?
Started by Midicity, February 15, 2015, 04:19:30 PM
Midicity
Is there a way or workaround outside of using a computer to gain access to the gr55 wirelessly using the triple play?
alexmcginness
I use a Guitar wing with a Kenton Midi USB host to work my VG-99 without a computer so Im thinking that it shouldnt be a problem to do the same with the Triple Play. Just plug the reciever into the Kenton and run a midi cable from the Kenton to the midi in of the 55 and you should be good to go. Ill try it with my GW and let you know.
Jim Williams
Not as of yet though I have herd rumors of people trying to mod the FTP pickup to work with guitar synths. the problem is the GR-55 won't except midi to trigger its internal sounds so you would have to send the signal to  the 13 pin input. I can't see how this could ever work.
Skype: (upon Request)
