Deal Alert Thread
Started by Elantric, February 17, 2011, 08:40:36 AM
onemoreguitar
SANYO-Xacti-ICR-XPS01M-Digital-Sound-Recorder $59.99 (its $149 everywhere else)
Woot one day deal
http://sellout.woot.com/
http://us.sanyo.com/Digital-Sound-Recorders/SANYO-Xacti-ICR-XPS01M-Digital-Sound-Recorder
Warranty: 90 Day Sanyo
Condition: New
Features:
  • Super-Slim, Sleek Design "World's Thinnest, Lightest Recorder"
  • Uncompressed Linear PCM Stereo and MP3 Stereo Recording Modes
  • Stereo playback
  • Touch Sensor Panel Controls
  • 2GB micro-SD Card Included
  • Micro SD/SDHC Card Slot (accepts up to 8GB)
  • Built-in High Performance Stereo Microphones
  • Removable Li-ion Battery Pack with Direct Battery Recharging (no need to replace batteries)
  • Built-in FM Tuner with 20 Station Presets
  • Large Full Dot Matrix LCD Display
  • Scene Select Recording Mode (3 scenes)
  • Mic and Line Level Recording Modes
  • USB 2.0 Cable Connection (Micro USB)
  • Microphone Sensitivity (High / Mid /Low / Manual)
  • 50% to 200% Playback Speed Control of MP3 files
  • Remaining Record Time Indicator
  • WMA and MP3 Data Playback
  • Seamless Integration with Digital Audio Editors
  • Up to 40Hr Use with Internal Li-Ion Battery
The Details:
  • This linear PCM digital sound recorder offers pristine, uncompressed linear PCM stereo recording performance in a very sleek, compact, touch-panel design
  • One of the thinnest (0.37 inches or 9.4mm) and lightest (1.623 oz. or 46g) portable PCM sound recorder in the world today
  • Stereo recordings will playback in stereo
  • Ideal for recording live performances, rehearsals, music lessons,  professional recording sessions as well as for general business  recording uses (meetings and lectures)
  • Well suited for use with music production/editing software applications such as Garage Band, Logic Studio, Logic Express and Pro Tools (raw PCM files can be directly imported into these applications without any need for data or file conversion)
  • Offers two recording formats:
    - Linear PCM, format, which records original sound without compression
    - Highly versatile MP3 format
  • Linear PCM recording records at 44.1kHz, 16 bit sampling rate enabling sound reproduction up to a maximum of 21KHz
  • MP3 recording captures high sound quality of 44.1kHz, 320k bit sampling which enables sound reproduction up to a maximum of 20KHz
  • Features a unique, touch sensor panel for transport control functions (Play, Pause, Forward, Rewind), Menu and Mode functions
  • Large, full dot matrix LCD display which can be operated with backlight on or off for additional power savings
  • 2GB microSD card included
  • Expand the capacity by inserting up to an 8GB microSD/microSDHC card, allowing you to enjoy hours of high quality PCM recording without constraints.
  • The use of high-sensitivity microphones and large-apertures deliver a pristine, clear sound
  • The microphones capture sound from a 360 degree angle in a very balanced, uniform manner
  • Noise levels are greatly reduced when compared to conventional designs
  • Recording input level adjustments allow you to switch between Manual (ALC OFF) and Auto (ALC ON) modes
    - Manual mode allows you to fine tune the volume in increments from 0 to 60 using a recording level meter and Peak lamp
  • The use of a recording peak limiter ensures reliable recording by suppressing distortion from abrupt, loud, transient sounds
  • A clear voice function reduces low and high frequency noise, making it easier for you to listen to the principal audio section
  • Presets recording settings (Scene Select) are used for setting the  appropriate recording mode; there are three microphone recording scenes  and three line-level recording (dubbing) scenes
    - Dictation: Suitable for up close recording, such as interviews and voice memos
    - Meeting/Lecture: Reliable recording of meetings and lectures by increasing microphone sensitivity
    - Music: Detailed recording that captures musical intonation by manual adjustment of recording level
    - Headphone: Optimum setting for dubbing recording, by connecting to the headphones socket with an audio cable
    - Portable: Optimum setting for dubbing recording, by connecting to the  line-out terminal of a portable CD player with an audio cable
    - Component: Optimum setting for dubbing recording, by connecting to the  line-out terminal of a component stereo system with an audio cable
  • Additional record modes can be adjusted in order to properly set the sound recorder
    - The built-in recording peak limiter allows you to minimize sound distortions during recording when the volume suddenly increases
    - An equalizer allows you to adjust the recording input level for each frequency band
    - You can select between seven preset levels and User which allows you to modify the input level of five frequency bands
    - The low cut filter allows you to record sound clearly by attenuating  low frequency sounds at 300Hz or below; this is useful for reducing  background sounds from wind noise outside or from air conditioners in a  home studio
  • The playback speed can be adjusted to 21 levels between 50% and 200% speed, without affecting the pitch of the sound
  • You can also skip through a file during playback at preset intervals; 5 sec, 10 sec, 30 sec, 1 min, 5 min, 10 min and 15 min.
  • The sound recorder supports WMA and MP3 file formats making it a portable music player
  • Its built-in FM radio tuner receives and can records FM radio broadcasts for up to 24 hours
  • It allows up to 20 station presets to be stored
  • When used in conjunction with SANYO's iFrame-compatible Dual Cameras, this digital sound recorder provides a seamless way of bringing PCM quality audio tracks into a video editing session; the combination allows for much faster importing, editing, and sharing your movies across multiple platforms and devices
  • Features a high capacity SANYO Lithium-Ion battery which provides up to 40 hours of use
  • The battery can be recharged using the supplied USB cable
FreeTime
I just saw one of those at a guitar show in Edmonton; someone was selling off their GR300 along with some odds and ends, so they are floating around in this part of the world too. He was asking $80.
Tascam DP-008 8-Track $175
$200, Use coupon code HM25CS for additional $25 off = $175 total +shipping
Nice point & shoot recorder when your brain hates diving thru menus to record that hit song idea.
http://www.hellomusic.com/ec/DealMain.aspx?did=10170
You Rock Guitar MIDI Guitar
$150, Use coupon code 30OFFOCT for additional $30 off = $120 total +shipping
http://www.hellomusic.com/ec/DealMain.aspx?did=10283
bbob
GR-55 with GK and You Rock guitar on www.hellomusic.com today
Line 6 Original POD Floorboard $50
At the Line 6 Store  - last of the production units available
Great Deal on Line 6 Floorboard! GET ONE BEFORE THEY'RE GONE! These will not be available again!
paults
I'm remembering my AxSys amp....
Guitarbot
I still have my AxeSys.  Love that amp.
Korg PX5D -  $99 here:
    http://www.activemusician.com/item--EM.PX5D
    Shipping is extra $, and Music123 wouldn't price-match,  - but many go to their local Guitar Center and picked them up for $99
These make excellent guitar practice rigs, Amp Simulator with programmable backing drums and bass  / Real Time External Stereo Audio Transposser , 80 second Phrase Trainer, Footpedal Input jack, and (not too well known) the Korg PX5D also works as a stereo IPAD USB Audio Interface for Ipad IOS Garageband, etc  - using nothing more than the PX5D + Apple Ipad Camera Kit USB adapter. (Powered USB Hub is not needed)
I actually like the  Pandora PX5D's Amp Modelling (excellent Vox AC-30 emulation), and the harmonizer works very well too.
More info on the Korg PX5D as Ipad Audio Interface is here:
http://wolfewithane.squarespace.com/blog/2011/2/15/gear-pandora-guitar-effects-for-ipad.html
paults
#43
In celebration of the 2nd Anniversary, TC Electronic Polytune is on sale for 99 cents.
PolyTune® for iPhone®
PolyTune® for iPhone works with the iPhone, iPod touch and iPad.
http://itunes.apple.com/us/app/polytune/id364009203?mt=8
The PolyTune® iPhone app is a 1:1 port of the award-winning PolyTune® pedal tuner, and it offers the exact same, patents pending tuning technology and amazing features as the pedal version.
In short, guitar tuning has been revolutionized at a stroke - or strum - with PolyTune®, the world's first polyphonic guitar tuner. This cutting-edge technology revolutionizes tuning and accomplishes what has been deemed impossible until now: tuning all strings simultaneously - it's as simple as: Strum. Tune. Rock!
Where the PolyTune® pedal is the perfect live solution, the iPhone version ensures perfect and swift tuning whenever you're off-stage - and with the iPhone's built-in microphone, polyphonic tuning is now available for acoustic instruments, too! The PolyTune app is fully compatible with iPhone4, iOS 4 and provides full Retina display support for the ultimate viewing experience when you're tuning.
The magic lies in a never before seen approach to tuning aimed at speed, accuracy and ease of use. With PolyTune® for iPhone, you simply strum all strings on your guitar or bass at once, and it immediately tells you which strings to tune, allowing you to get in tune fast, and back to doing what you love the most: playing.
Fever Pitch
Equally effective for guitar and bass, PolyTune® for iPhone is extremely flexible as well. The reference pitch can be set to your preference and ranges from 435Hz to 445Hz. This guarantees you'll be able to play along with anyone, with any instrument and in any situation.
Drop it like it's hot
If you are a guitarist that likes to play at a different pitch than standard, this is the perfect tool, allowing for dropped tunings from E-flat all the way down to B. Whatever your pitch or tuning, PolyTune® for iPhone is a sure-fire way to be spot-on, with an accuracy of just plus/minus 0.5 cent.
PolyTune App Screens
Chromatic champion
Besides the Polyphonic tuner, PolyTune® for iPhone has a chromatic tuner that can hang with the best current tuning technology out there, but we are never satisfied with the current norm and added some features to make this tuner's chromatic section stand out from the crowd.
Tuning modes
Let's start with the two separate chromatic tuning modes, which cater to your individual preferences and needs. Needle mode is for those who are used to the classic view on a tuner. If you want a little more real-time information, we have included stream-mode, which measures even the slightest pitch variation and instantly feeds the info back to you via a rotating motion on the display.
Tuning Magnet
Key to both these great chromatic modes is an ultra-fast and precise response, which is achieved by the use of the unique tuner magnet feature. This slows down the needle once you get close to the desired pitch, making it much easier to get the job done quickly.
MonoPoly
Whether you want to use the polyphonic tuner to get in tune, or prefer to go the chromatic route, this pedal has you covered. PolyTune® for iPhone features 'MonoPoly', a unique patent-pending technology that recognizes whether you play one or more strings and instantly switches to the appropriate tuning mode.
Swap the colors
PolyTune for iPhone also has a 'colorblind' feature that allows you to swap the default green/red colors with yellow/blue. Just choose whatever suits your eyes the best.
The making of PolyTune® iPhone AppTuning as it should be
PolyTune® for iPhone was our chance to build the ultimate tuning tool from the ground up and finally get rid of some of the current tuner drawbacks that guitarists run into time and time again. Tuners have been around for some 30 odd years and we felt it was high time they got in tune with today's guitarists.
We can't make tuning fun. But we can sure make it a whole lot easier.
How to make a stomp box PolyTune® from the PolyTune® iPhone AppWe want to do our part for the guitar community and truly innovate the life of guitarists. And with PolyTune® for iPhone's extraordinary features and cutting-edge technology, we feel we have accomplished just that. We are passionate guitarists ourselves and we work every single day to make all our lives easier and more rocking. We did it for multi-effects with G-Force, G-Major2, Nova System and G-System, we did it for stomp boxes with the Nova series, and now PolyTuneTM is here to give tuning a much needed kick in the A440!
Bill Ruppert
Thanks Paul!
I was waiting for that.
Bill
I love it. Really great app.
paults
You're welcome! I was glad to see it go on sale, too.  I didn't have an iPhone, back when they were free.
If anyone needs the stomp box, they are currently 49% off at Hello Music ($75):
http://www.hellomusic.com/ec/DealMain.aspx?did=12340&cat=ACCESSORIES
onemoreguitar
I was lucky enough to get it when it was free, same as the Peterson iStroboSoft.  It's weird that the TC app works better, IMO, than the Peterson whereas I find the opposite to be true with the hardware versions.  Maybe it has to do with mic sensitivity, but the Peterson app seems to have an "in tune" indent which is contrary to the whole strobe idea.  Anyways, the Polytune app has been my goto tuner, as far as app tuners go, for a couple years now.  Not as accurate as my Peterson hardware tuners IME, but great in a pinch.
Bill Ruppert
I missed the free one as well but 99 cents is a deal!
Looks like TC is coming out with a smaller version of the tuner at namm.
paults
Quote from: Bill Ruppert on January 16, 2012, 07:37:09 AM
This time of year, the best deals are always on the discontinued versions of products :)
