Roland Ready Strat Issues
Started by chrisyork, December 05, 2013, 08:56:07 AM
chrisyork
need help, my Roland ready strat approx. 1999/2001 has stopped working, however on my GR55 it will work perfectly on 1 patch, ive reset the GR55 to factory and it also has latest firmware, it also works perfect on my other GK2A guitar. the Roland strat doesn't work at all on my GR30. all functions seem to work on both GR's including tuning, patch select etc but just no sound coming out...any ideas please?
Roland GR user since 1980
GR55, SY1000, GT1000,GR500,GR100,GR300,GR700, G505,G707,2 Boss Katana, Fender Roland Strat, various Fender, Gibson, Yamaha guitars, various Roland synth modules
If you cant solder - take it to a Roland repair center
if you can
look here and download what you need
Schematics
Problems with Roland Ready Strat Switch
https://www.vguitarforums.com/smf/index.php?topic=6980.0
How to clean and maintain Roland Gk-13 pin cables
datsunrobbie
You probably already did this, but I'll throw it out there anyway. Have you spayed DeOxit into the 13-pin jack on the strat and the cable? Using the same cable with the strat and your other GK-equipped guitar?
You also mentioned that the RR Strat works perfectly on one patch on the GR-55 - is that a mag-only patch?
When you say "all functions seem to work on both GR's including tuning, patch select etc but just no sound coming out" is that with the RR strat, or only with the other GK2a guitar? If the RR strat is getting signal to the GR-55 tuner function then the problem is probably not the strat.
chrisyork
on the GR55 user 08-3 DeepWater (openE) is the only patch that will work on roland ready strat, the toggle switch doesn't appear to do anything although the 2 buttons work fine when selecting patches, when I plug in my other gk guitar, the gr55 and gr30 work perfect. all my cables are fully working also
Quoteon roland ready strat, the toggle switch doesn't appear to do anything although the 2 buttons work fine when selecting patches, when I plug in my other gk guitar, the gr55 and gr30 work perfect. all my cables are fully working also
Actually there's probably nothing wrong with your guitar
Must Read here:
GR-55 FAQ: TOP THINGS TO KNOW
and specifically
Read here about the current Roland policy of shipping latest 13 pin processors (VG-99, GR-55, etc)   that have the GK-3 Guitar/Mix/Synth three-way switch  "non functional" on most factory presets.
* How to enable "Normal Guitar Pickups" and make the GK-3 Guitar/Mix/Synth three-way switch work with the GR-55:
chrisyork
checked all switches and pots with a meter and all working fine so it must be the small pcb...anyone else had this problem? checked all solder too
Time to contact your local Roland repair center
I understand you are in the UK
http://www.roland.co.uk/articles/default.aspx?c=4
Plug it in and check whether you're getting power FROM the GR-55 to your PCB?
..loose (or otherwise connection) either via the 13-pin jack or the PCB connection plug or somewhere else in that chain..    ???
..just a thought from Oz...
Cheers,
Peter
chrisyork
thanks Gumbo, I'll check that before I order a new pcb
