Digitech Whammy DT - with MIDI Control
Started by Elantric, May 28, 2016, 08:25:44 PM
A few years old now, but worthy of its own thread -
This same model is currently being used by Steve Vai.
Digitech Whammy DT - with MIDI Pitch Control
OM
http://rdn.harmanpro.com/product_documents/documents/301_1454517546/Whammy_DT_Manual_5008631-B_original.pdf
Review
http://rdn.harmanpro.com/product_reviews/reviews/39_1315509554/totalguitar-whammydt_original.pdf
http://digitech.com/en-US/products/whammy-dt
Introducing a new addition to the DigiTech Whammy Family -- Whammy DT!  We've taken the premier pitch shifting effects pedal added drop tuning and true bypass to bring you the ultimate Whammy pedal, the Whammy DT.   With the Whammy DT, you can modify your tuning without having to change guitars or pause awkwardly to make adjustments for the next song.  Key changes are at the tips of your toes and take just moments, which is crucial when the audience is feeling your vibe.
Pitch shifting effects really help your guitar performance stand out and the Whammy pedal has been the core pitch shifting effect for famous artists for over 20 years.  Now add full drop and raised tuning in addition to classic Whammy shifting to your effects arsenal and find out why the Whammy DT is the premiere pitch shifting effects pedal for every guitarist.
Step down or step up 7 half steps or an entire octave: The Whammy DT gives you the latest pitch shifting technology to retune your guitar without ever touching the tuning pegs.  Step up or down in 7 half steps, or an entire octave with just one setting.
Whammy effects capabilities: With all the new tuning capabilities, you still have your true pitch shifting effects to sweeten up all moments of your gig.  With over 20 years of leading the market in pitch shifting, Whammy effects give you the comfort of knowing the pedal you are using is a proven winner.
Momentary footswitch for "hammer-on" and "pull-off" effects: You can instantly create hammer-on and pull-off effects during your performance with the momentary footswitch.  Hold it on for quick chord shifts or note changes during your solo or a gritty bridge.
Features
True Polyphonic Pitch Shifting and Whammy effects in a single pedal
Drop or Raised tuning by 7 half steps or an entire octave
Classic Whammy voicings
Momentary footswitch for Hammer-on and Pull-off effects
True Bypass
FS3X* input for hands-free selection of Whammy and Drop Tune settings
Classic style rugged metal Whammy chassis
Durable, road worthy metal footswitches
MIDI Input
¼" Guitar Input
¼" Output
9V DC Power Adapter included
*FS3X optional
Specifications
A/D/A   24-bit Analog to Digital/Digital to Analog
Dimensions   8.2" x 2.35" x 7.725" (W x H x D)
Power Supply   PS0913DC-01 (US, EU, UK); PS0913DC-02 (AU, UK)
Unit Weight   3.5 lbs
Virtual Jeff WHAMMY BAR side note
https://www.vguitarforums.com/smf/index.php?topic=16963.0
Rewatch the NAMM videos, and see the Digitech Whammy pedal on the ground on the pedal board at the Virtual Jeff NAMM Booth.
The latest Digitech Whammy supports external MIDI Control, and the Virtual Jeff simply feeds MIDI CC# data (via 5pin DIN MIDI connection) to the Whammy pedal that does the actual audio processing.
QuoteUsing MIDI continuous control commands, the Whammy's expression pedal position can be remotely controlled. MIDI CC11 adjusts the expression pedal position. A value of 0 on MIDI CC11 corresponds to a toe up position and a value of 127 corresponds to a toe down position.
So add purchase of a new Digitech Whammy pedal when considering the Virtual Jeff
alexmcginness
If you have a VG-99 you shouldnt need the wammy pedal...correct?
QuoteIf you have a VG-99 you shouldnt need the wammy pedal...correct?
Correct, (same with GR-55,  GP-10)  - but Digitech Whammy DT comes in handy when you are not using any of those 13pin systems in your rig.
