Power Supply For TC-Helicon Harmony G-XT
Started by tpandela, September 28, 2015, 10:55:19 AM
tpandela
The power supply for my above unit went south on the gig this past weekend and, well, I missed it. I found, and ordered,  a replacement part on Amazon but it probably will not arrive until after next weekends gig. The original power supply is rated 12V, 0.4A and 4.8W.
As a test I plugged in the 9V power supply from my GT-10 and the unit booted up, same with the power supply from GP-10 and my Zoom G3.
So my question, to those who understand this stuff: Will it harm my unit if I use one of these power supply's for Friday's performance?
Thanks in advance.
Tom
You should locate a proper 12VDC supply rated for 1A  current rating)
The factory adapter has a 1 Amp rating
with the same coax DC connector polarity
http://www.fullcompass.com/prod/273810-TC-Electronic-7E50002011
TC Helicon Ac Adapter model SA2110C-12S-1  Output 12vDC/1A
Adapter Specifications:
Voltage:12V DC
Amperage:1A
Connector Size: 2.1mm x 5.5mm
Connector Type: Barrel
Tip/Sleeve Polarity +/-: Center negative
Cable Length: 6'/2m
