V6 Overdrive
Started by ainsoph, June 13, 2016, 04:07:33 AM
ainsoph
www.v6guitaroverdrive.com
What is V6?
With the V6 Overdrive, you rediscover the natural guitar polyphony while using full distortion.
Distortion changed guitar music and the possibilities of creation. The V6 Overdrive wants to be the natural evolution of the long distortion story.
While giving you the possibility to play chords and create clear polyphonies and distinct voices with distortion, a complete new universe of guitar playing is now given to the musicians of today and tomorrow.
After a long work of technical and sound research, the V6 system has been designed with 12 AX7 tubes to preserve a natural and deep hot distortion sound, very sensitive to the nuances of your playing, like the good valve amps do. You don't find this quality on solid state or virtual poly distortion systems.
Each string has its own alnico pick up and its 12 AX7 overdrive.
6 strings, 6 pick ups, 6 valves !
Moreover, V6 offers an unmatched range of differents sounds and spaces in mono or stereo.
Activate the "stereo disto" switch on the stompbox and you split the 3 bass strings (left) and the 3 high strings (right) on two amps, and then have different effects on each side :
For example, one octaver, no delay on the 3 bass strings / a long delay on the 3 high ones.
 Or a distortion on the 3 bass / and for the 3 high a clean sound with an harmonizer pitched to the 5th...etc.
Last but not least, a Midi output can drive synthetizers or write music scores on your computer.
The V6 system does not forget "your" sound : switch on "mono clean" and you go back to your untouched favorite guitar sound with your familiar amp distortion !
The V6 is not only one more guitar pedal but a key to enter new guitar worlds !
! No longer available
The V6 Overdrive
6 Strings  6 Pick Ups  6 Tubes !
The Revolution of Distortion : the V6 system is an hexaphonic magnetic alnico humbucker routed to a polyphonic valve distortion stompbox.
The V6 allows you to play CHORDS and NEW SOUNDS with an all tube 6 voice distortion Vintage or Modern High Gain :
MONO on one amp.
STEREO on two amps or one mixer
Bass strings 6.5.4 left
High strings 3.2.1 right
The V6 bridge pick up has a good rock / metal sound with a traditional distortion.
It is not a piezzo It is a warm alnico humbucker.
YOU STILL PLAY ALL THE THINGS YOU HAVE ALWAYS PLAYED AND YOU ENTER NOW THE NEW WORLDS OF THE POLY DISTORTION GUITAR
Kevin M
Yet another hex pickup system?
thebrushwithin
I wonder if it is 13 pin, and what the price is.
Now_And_Then
Quote from: thebrushwithin on June 13, 2016, 09:40:40 AM
Nothing on the site about availability either, although there is a gallery page with pictures of various guitars fitted with the pickup.
vanceg
Yeah, not a lot of info there... I've got an email in to them but no reply yet.
