VG-99 - Can a VG99s RRC2 provide power to a TC GMinor?
Started by amagalma, May 05, 2016, 09:15:48 AM
amagalma
Hello!  :)
I would like to power my TC G Minor from my VG99's RRC2 port. The G Minor needs 9V DC (negative inside) - 2W (which I think is about 222mA - correct me if I am wrong, please!)
My questions are:
1) Will the RRC2 port of the VG99 provide enough power?
2) How should I connect the plugs to the cable? The cable will have an RJ45 plug on one side and a standard 2.1mm barrel powerplug.
Thank you in advance for your help! :)
The power supply of the VG99 is also 2 watts. 2 watts equals 2000 mW. So in theory you do not have enough power. I doubt the guitar minor really consumes that much power though.
EDIT: VG99 power supply is 2 amps = 18 watts. My bad.
I have used the RRC2 connector to power an FCB1010, which was not problem. Check out https://www.vguitarforums.com/smf/index.php?topic=783.10 for a pinout of the RRC2 connector and schematic of this solution.
Also I have done the same for my VController, which uses even more power. Also no problems here. Check out  https://www.vguitarforums.com/smf/index.php?topic=15154.msg125923#msg125923 for more information.
FWIW -
http://cdn-downloads.tcelectronic.com/media/667690/tcelectronic-gminor-manual-english.pdf
Note the G-Minor power supply at 2Watts is designed to run multiple G-Minors
I suspect less than 500mA @9VDC is required for running one  G-Minor
The manual does state 2 watts, but that is an awful lot for a simple midi controller. I think they use only one type of power supply that will suit many more products. It will make it cheaper because they can order more and keep less I need stock worldwide.
BTW You can even run MIDI through the RRC2 connector. I do the same with the VController.
amagalma
Thank you for your responses!  :)
2W=2000mW
2000mW/9V=222mA
The power supply of the G Minor is 9V, 300mA.
So the question is: can the RRC2 port provide at least 222mA?
QuoteSo the question is: can the RRC2 port provide at least 222mA?
We know VG99s RJ-45 "RRC2" port can power the Roland FC-300  - that draws 94mA
http://cdn.roland.com/assets/media/pdf/FC-300_OM.pdf
I believe it should also be able to power the G Minor
Find details here
https://www.vguitarforums.com/smf/index.php?topic=783.0
https://www.vguitarforums.com/smf/index.php?topic=28.msg3604#msg3604
http://www.naslada.net/knowhow/fcb1010/FCB1010%20Phantom%20Power%20Adaptor.pdf
Download everything here:
https://www.vguitarforums.com/smf/index.php?topic=30.0
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=30.0;attach=236
The RRC2 Ethercon RJ-45 pinout is
1 = RCV_1
2 = RCV_2
3 = +5VDC
4 = +VREF
5 = +VREF
6 = TXD
7 = GND
8 = GND
SHELL = GND
Internal VG-99 RRC2 connections
amagalma
Ok. I can make the cable and see if the current is enough or not..
How should I wire the cable? I understood that I must use pins 5 and 7 on the RJ45 side.. But where do I connect them on the 2.1mm barrel powerplug side? The negative must be inside and the positive outside...
amagalma
In case I was not clear, I do not intend to make a MIDI cable that gives power to the G Minor, as was done in the example above with the FCB1010. I simply want to power the G Minor with a special made cable that will draw current from the RRC2 port. I want to do that in order to have one less power supply to carry.
That special cable will be a RJ45 plug on one side and a 2.1mm barrel plug on the other.
Quote from: amagalma on May 05, 2016, 10:58:20 AMHow should I wire the cable? I understood that I must use pins 5 and 7 on the RJ45 side.. But where do I connect them on the 2.1mm barrel powerplug side? The negative must be inside and the positive outside...
Pin 4 and 5 are positive and pin 7 and 8 are negative. Make sure you test the polarity before connecting the G minor.
amagalma
amagalma
Just to let you know, I did it and it works fine!  ;D
Thank you very much for your help!  :)
